08-24-2017, 10:10 AM | #26 | |
meowMEOWmeowMEOW
Re: Repost here: lq4 turbo'ed swap
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
08-24-2017, 09:44 PM | #27 | |
08-24-2017, 10:36 PM | #28 |
6.0, 5.3, 4.8....I'm not sure it even matters. The turbo is doing all the work!
1970 C10 Turbo LM7 5.3/LS6 cam PT7675/4L80E/Holley Dominator EFI/E85 Moser 9" 3.25/4 wheel discs 11.16@121.07 |
08-25-2017, 09:18 AM | #29 | |
I'm just glad to be here!
He had a 6.0 in that Colorado before the 4.8 with a different cam and turbo that put down just over 1000 rwhp.
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
08-25-2017, 03:15 PM | #30 |
I think its hard to recommend a cam without the turbo size. I am surprised neither of them asked for it.
I am in the process of doing my turbo build just commenting to see what other people have to say. Oh and pictures because everyone likes those.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
08-25-2017, 06:49 PM | #31 |
I think I'll go with the 76mm turbo
08-27-2017, 08:57 PM | #32 |
Seems like a good size for street use. You going to get the larger hotside right?
08-28-2017, 08:47 AM | #33 |
Looks like their size shows the 78 as a 75 hotside? All things considered seem like this would be a good option for room to grow and an ok spool time considering the 6.0 displacement.
08-29-2017, 08:09 AM | #34 |
I've read a ton of stuff on cleaning. It appears I can clean th exterior of the block with oven cleaner. I'll pressure wash after that. My concern is getting oven cleaner on ant internal bearing surfaces. I'd oil right after cleaning to prevent flash rust but can oven cleaner possibly damage or microscopically pit any of these detrimental surfaces? I will try to avoid them but if I clean all the carbon out of the inside of the block, inevitably some of the cleaner will contact the bearing surfaces. Same goes for the crank.
The Pistons I thing I'll chem dip and clean the ring landings with an old ring. Pretty happy with the way the intake turned out. I was told o could use a set of ctsv 55lb injectors and they'll swap right over. If this ends up being the case it seem like a good option |
09-13-2017, 10:42 PM | #35 |
Any updates?
71 C10 Finally took a leap and did the 5.3 4l80e swap. Running the Holley Terminator Xmax. Still working bugs out. |
09-14-2017, 02:45 AM | #36 |
Still moving forward little by little. Decided to do cam bearings but having an issue with the clocking of the oil holes in the first bearing. Just need verification. I'll get that figured out soon.
Block clean as a whistle. Started to prime and paint. All valves lapped and waiting for pac springs to arrive. Going with the Elgin cam mentioned earlier. It'll be here soon. Got a 320 grit 4.0" flex hone to match with new rings. Think the consensus is to gap both first and second ring right at .032? I'll get some pics real soon. It's looking good. |
09-14-2017, 10:11 PM | #37 | |
https://www.briantooleyracing.com/tr...e-iii-cam.html Specs are 218/224 .553/.553 113+3 I'm looking at the BTR Truck Stage IV cam for my NA 5.3 and thought the above specs were a little big for the truck stage III cam. Also, have you read the Hot Rod magazine article where they turbo'd an LS motor? Very good insight I think... http://www.hotrod.com/articles/hrdp-...g-bang-theory/
Doug Old Build Thread - 383/T56 http://www.67-72chevytrucks.com/vboa...d.php?t=540838 Updated Build Thread - Modern Relic - 66 C10 536 Dark Aqua 5.3/4L60E - BTR Stage IV Truck Cam - Vintage Air - Dakota Digital http://67-72chevytrucks.com/vboard/s...d.php?t=778784 Last edited by 66 C10 383; 09-14-2017 at 10:29 PM. |
