Old 07-30-2017, 06:49 PM   #401
namloc
namloc's Avatar
Re: The Snortin' bull
Well all running well though my stereo did not like the MSD .And the good used refurb one wire alt I used did not like it either.I installed an MSD cap. and from TUFF STUFF a new 120 amp one wire alternator. All better now.
The Snortin' Bull
namloc is offline   Reply With Quote
Old 07-30-2017, 06:51 PM   #402
namloc
namloc's Avatar
Originally Posted by jcramsey View Post
If the bull is a budget build....then mine must be a food stamps build....
Glad to hear it's running even better now with the MSD, you've got to love that!
Thanks .Too funny.Sometimes ya just gotta stretch the budget
The Snortin' Bull
Old 07-30-2017, 06:54 PM   #403
namloc
namloc's Avatar
The Snortin' Bull made it out to it's second GOOD-GUYS event. Had a great time. Made a lot of new friend's.
The Snortin' Bull
Old 08-20-2017, 09:41 PM   #404
namloc
namloc's Avatar
Off with the neck.The fuel tank neck.I had a dummy neck in for the past year. Time has come to smooth thing's out.
The Snortin' Bull
Old 08-20-2017, 09:54 PM   #405
namloc
namloc's Avatar
Cut out an initial patch piece,20 Gg. Trimmed.Bent a slight compound curve into the patch.Set in after some minor prep.Started to tack in. Dinner is ready gotta come back to this later.
The Snortin' Bull
Old 08-27-2017, 01:31 PM   #406
namloc
namloc's Avatar
Got some part's for parking brake install.From the Control Cables company.
The Snortin' Bull
Old 09-11-2017, 10:15 PM   #407
namloc
namloc's Avatar
A new accessory.A back window hat rack.
The Snortin' Bull
Old 09-11-2017, 10:18 PM   #408
namloc
namloc's Avatar
Static buzz still from MSD .I installed this BOSS noise filter for the radio and no more buzz or static. It work's.
The Snortin' Bull
Old 09-30-2017, 11:32 PM   #409
namloc
namloc's Avatar
Back earlier in the build I had found a parting out truck and got a rh sun visor.As the Bull originally was lh only.Well the left had one fell apart while driving the other day.So I had to refurb it.Now it matches the right.Sans the original vinyl.
The Snortin' Bull
Old 09-30-2017, 11:35 PM   #410
namloc
namloc's Avatar
Headliner kept sagging between the mounting points.LMC kit is nice though I had to add extra mounting point's.
The Snortin' Bull
Old 10-01-2017, 08:48 AM   #411
bj383ss
bj383ss's Avatar
Do you have any pics of your parking brake install? Was curious if you used the factory rear cables? I went to their website and the prices for their stuff isn't bad.
Bret
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955
bj383ss is offline   Reply With Quote
Old 10-01-2017, 08:54 PM   #412
namloc
namloc's Avatar
Bret
I have not installed the frt. cable and handle yet.I did install original cables in rear,The first rear cables that I ordered from LMC are incorrectly listed,NAPA still offers the correct for pre 63. I will show the install when it comes about.
The Snortin' Bull
Old 10-09-2017, 08:47 PM   #413
namloc
namloc's Avatar
Kept having some water come into the cab after the Seattle rain or washing.None from the windshield it seemed to be thru the cowl and down to the vents.Even in the center from the wiper motor area.I seam sealed anything of question.
The Snortin' Bull
Old 10-16-2017, 10:52 PM   #414
namloc
namloc's Avatar
The sealed beam headlamp's in the dark in Seattle rain weather are not good.So out they will go.I got a h4 conversion set to install.An updated harness with relay's also.
The Snortin' Bull
Old 10-28-2017, 11:01 PM   #415
namloc
namloc's Avatar
I had read this on the forum and you do have to open up the hole behind each lamp on the headlamp retaining plate's.
The Snortin' Bull
Old 10-28-2017, 11:04 PM   #416
namloc
namloc's Avatar
New front lighting harness installed.Scrubbed down everything and painted buckets and retaining plate's,Relays in for high beam and low beam.
The Snortin' Bull
Old 10-28-2017, 11:06 PM   #417
namloc
namloc's Avatar
All work's just waiting for the dark to align headlamps. Just posin' with the halo ring's.
The Snortin' Bull
Old 10-30-2017, 10:54 PM   #418
62stepside longbox
62stepside longbox's Avatar
Have a part number for the 60-62 rear cables?
Looks great!
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 10-30-2017, 11:14 PM   #419
72cs20
No pressure, but I'm looking forward to the parking brake install also.
1966 K20 flatbed build thread - http://www.67-72chevytrucks.com/vboa...d.php?t=768827
62 C20 build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=703583
72cs20 is offline   Reply With Quote
Old 10-31-2017, 10:33 AM   #420
namloc
namloc's Avatar
Ya .Still got that to to finish.The rear cable's are on .Just keep changing my thought's on where the handle and frt cable is to go to work best.
The Snortin' Bull
Old 10-31-2017, 10:37 AM   #421
namloc
namloc's Avatar
Looks great!
Thank's .I will look back and see what number the rear cables where.
The Snortin' Bull
Old 10-31-2017, 11:20 AM   #422
namloc
namloc's Avatar
Looks great!
Cable's I used on the rear NAPA # UP92240 .
The Snortin' Bull
Old 10-31-2017, 09:33 PM   #423
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Which kit did you get?
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 10-31-2017, 10:22 PM   #424
namloc
namloc's Avatar
I bought an Octane lighting H4 KIT and harness.Best pricing at Amazon.
The Snortin' Bull
Old 10-31-2017, 11:00 PM   #425
LostMy65
LostMy65's Avatar
