12-09-2017, 10:38 AM | #1 |
Re: 1972 Build thread.
Thanks for the pictures !! I like the idea of the mounting links at the spring perches. Would be less binding with this design. Probably a necessity with your lift kit. I see what you mean about the front cross member. I'll have to fab up some custom brackets.
12-09-2017, 01:13 PM | #2 |
No problem! I'm excited to see what you come up with for brackets.
Full top blazer or bust.... |
12-09-2017, 04:02 PM | #3 |
Front shocks in place, and the stabalizer mocked up. Not putting it on until it goes in for alignment.
12-09-2017, 04:09 PM | #4 |
This thing is gonna be sweet! Keep up the good work!
1970 1/2 ton 4x4 4spd Suburban 1972 K10 350/700R/205/ Sniper EFI Daily Driver Sold 1971 K5 on 35s Traded 1972 K5 3/4 ton PROJECT Sold |
12-09-2017, 04:30 PM | #5 |
Thank you sir!
12-10-2017, 03:44 PM | #6 | |
FWIW, I did make tapered shims as I've mentioned on a few posts to give me a bit more caster. Stock is around 3 degrees, but I increased this to around 6 1/2 degrees. This made the truck much more stable, and the steering centers itself much better after doing a turn. |
12-10-2017, 04:42 PM | #7 | |
Pic of the old white knuckle CJ below.
12-10-2017, 06:06 PM | #8 | |
12-10-2017, 11:21 PM | #9 |
I'm following you on the toe, I just didn't understand if I should go in or out . The CJ I had given up on and took to a 4wd shop in my area that shall remain unamed. They shimmed the axle so that it rotated the front of the Dana up and the rear yoke down. Similar to the shims on the rear axle, these are bolted into the spring pack. Also they put a track bar in the front. It goes down the road a lot better than it did, but squirrelly above 45 or so. I thought about a rear sway bar, but never got around to it since it is mainly used as a cruiser around town. I'm glad to hear you are cruising at 75 no problem. The Jeep issues are why I am making sure to get the sway bars installed and pay a little extra attention to the suspension.
