12-17-2017, 12:42 AM | #201 |
Re: 1972 Chevy Pickup Project.
Yep that would be sweet. If only...
1972 chevy pickup/ 2004 chevy tahoe merge... My build -http://67-72chevytrucks.com/vboard/s...d.php?t=731246 |
12-17-2017, 06:49 PM | #202 |
So back to the salvage yard this morning I went. I picked up a new wiper switch. I brought it back looking up and the wipers are working like it supposed to now. I tried to find a clock Spring while I was there but everyone has already taken all of them. So when I got back I wanna head and took my clock Spring out and took it apart and sure enough it is ripped at both ends.
12-18-2017, 01:56 AM | #203 |
Well glad that fixed the wipers. New clock spring and you should be set!
12-18-2017, 05:41 PM | #204 |
Well here is what I have decided. I picked up a different steering wheel yesterday and I put it on the truck. This morning I ordered a new 7" touch screen with navigation. I think I am going to like this route a lot better
12-18-2017, 06:14 PM | #205 |
That should be super nice!
12-18-2017, 07:46 PM | #206 |
Ok I just found another problem.....I took the truck for a drive (man was it fun) and the issue is when I put the shifter into park it clicks the clicker for the blinkers. It dont flash any lights but I can hear the clicker click 4 or 5 times. I can duplicate the results anytime I put the shifter into park. even without the engine running. anytime you shift back to park it clicks. any ideas? thanks
12-18-2017, 07:51 PM | #207 |
Have you replaced the multi function turn signal switch/wiper switch
12-18-2017, 07:54 PM | #208 |
Yes thats how I fixed the wipers. That was my thought as well that it was causing the problem but I put the old one back on and it does the same thing. everytime its put into park it clicks.
12-18-2017, 07:57 PM | #209 |
Does it click both signals or just one side? Is hazard switch stuck?
12-18-2017, 08:07 PM | #210 |
it actually dont light up any lights, it only clicks the clicker that in the fuse box. Its the same clicker that clicks when the trun signals are presed.
12-18-2017, 08:24 PM | #211 |
Let me look it up for you
12-18-2017, 08:33 PM | #212 |
12-18-2017, 08:38 PM | #213 |
Are you running the Tahoe body control module
12-18-2017, 08:55 PM | #214 |
12-18-2017, 09:03 PM | #215 |
Do you have door switches hooked up and wired to bcm so it knows when doors are ajar
12-18-2017, 09:07 PM | #216 |
No there are no door sensors hooked up.
12-18-2017, 09:09 PM | #217 |
Does it click five times after the key is shut off or with the key still in the running position
12-18-2017, 09:17 PM | #218 |
While it is still on. As soon as you put it into park it does it.
12-18-2017, 09:21 PM | #219 |
I don't know if it will fix that problem or not but you definitely need door switch signals going to the body control module. If your truck does not have door ajar switches it is not that hard to install I did it on my project
12-18-2017, 10:08 PM | #220 |
Do you know which wires from the bcm are for the door adjar?
12-18-2017, 10:50 PM | #221 |
I'll look at a wiring schematic for you. You can also wire it so your dome light comes on when door is open. Your door switches will provide a ground when door opens.
12-18-2017, 10:54 PM | #222 |
I found the wiring diagrams for the bcm I believe. It seems I need to show the rear doors closed as well as the rear hatch. Now that I think about it my instrument cluster keeps saying replace lift gate fuse. but i find no such fuse.
1972 chevy pickup/ 2004 chevy tahoe merge... My build -http://67-72chevytrucks.com/vboard/s...d.php?t=731246 Last edited by thetucks; 12-19-2017 at 09:43 AM. |
12-18-2017, 11:14 PM | #223 |
Yeah just trick bcm to think there closed except for front doors.
12-19-2017, 12:31 PM | #224 |
i grounded the wires from the bcm that are for the rear doors and the rear lift gate. Now the instrument cluster says those 3 doors are open. Which wire goes to the dome light? I need to hook it back up so I can test if its on?
12-27-2017, 12:11 AM | #225 |
Any luck with the wiring issues you were having
