03-06-2018, 10:26 PM | #1 |
Active Member
Re: GIANT 60-66 parts Stash Barn Find!!
Do you have original Ram horn exhaust manifolds for a 60 283 cid? I just took mine off to rebuild the original engine and found them to be aftermarket replacements from China!!
Submariner616 1965 Chevrolet K20 350 4 speed manual |
03-14-2018, 02:47 PM | #2 |
Do you have a Shift Lever Housing for a 1966 manual shift column?
(The pivot holes on my housing where the roll pin that goes through the shift lever should press in are worn out and cracked.) |
03-24-2018, 12:32 PM | #3 |
GMCNut - do you have 1960 to 1966 power steering pump brackets? Thanks in advance for your time.
