Old 10-31-2018, 09:54 PM   #1
CJM72
Name that Miscellaneous Blazer Part
So I'm not selling anything here, but I am trying to identify some parts I have lying around. When I bought my Blazer, it came with a random box of hardware and other parts that were removed or replaced. So I'm calling all you Blazer experts to point out what I have here!
1. Top Bracket?
2.
3. Seat Belt Bolts?
4.
5.
6.
7.
8.
9.
10.
11.
12. Rear Seat Hold Down?
13.
14. Rear Seat Bolts (Back)?
CJM72 is offline   Reply With Quote
Old 10-31-2018, 10:10 PM   #2
Jennandrand
Re: Name that Miscellaneous Blazer Part
4 is the window vent
5 is a steering column bracket
6 I believe is a side mirror gasket
Jennandrand is offline   Reply With Quote
Old 10-31-2018, 11:22 PM   #3
1rippen6
1. Correct top bracket
2. Starter bracket
3. Correct seat belt bolts
4. Flapper for fresh air on an A/C blazer goes under the cowl on the passenger side.
5. Mounts to dash under steering column
6. Mirror gasket
7. Lug wrench and jack handle mounting hardware goes behind drivers seat.
8. Goes with 7
9. Door shim gets screwed to the door and makes contact with the bronze one on the body.
10. Hatch stop goes with number 1
11. Mirror bracket goes inside the door for the mirror to screw to.
12. Rear seat hold down
13. Tube for start wires I think but not sure if correct for first gen. blazers.
14. Seat belt bolts or possible rear seat
Did I win anything LOL
1rippen6 is offline   Reply With Quote
Old 11-01-2018, 06:07 AM   #4
CJM72
Holy smokes, Rip! Very impressive! The knowledge and helpfulness on this board is second to none. Thanks for the time!
Question. I thought both sides of the door got brass wedge plates? My blazer came with a truck door on the driver's side and possibly some other cannibalized parts, so I'm not 100% sure what's original.
Old 11-01-2018, 09:05 AM   #5
1rippen6
Doors get the stainless plate body gets the brass wedges.
Old 11-01-2018, 09:27 AM   #6
CJM72
Huh, well that explains why I only have one of the stainless plates. I'm sure the other is on the original door along with the reinforcement plate! I wish the previous owners held onto more of this stuff when the fixed it up over the years. I also wish I looked through this box and asked more questions before I bought 4 of the brass wedge plates! Looks like I'll have a few for sale. Thanks aga in Rippen.
Old 11-01-2018, 09:43 AM   #7
1rippen6
Yep, one of the first things that sells when parting one. Seems like everyone removes the doors and doesn't strip them before throwing them out.
Old 11-02-2018, 10:32 PM   #8
Blazerowner
Blazerowner's Avatar
Stainless plate? Is it under the mirror? Anyone have a picture?
Kirk
72 Blazer CST 4wd highlander
66 Nova
Blazerowner is offline   Reply With Quote
Old 11-02-2018, 10:53 PM   #9
CJM72
Item #9 in the above pictures. The only part with orange paint. It mounts on the door in the door jamb. A brass plate mounts on the tub side of the door jamb. They are supposed to just barely touch and keep the doors from wedging shut when the top is off. Gives you an idea how 'not' ridgid they were even brand new. I can imagine the engineers surprise when they were stuck in the prototype trucks with doors jammed shut. Makes me want to weld giant I beams in place of the torque boxes and fully box the frame!
At least I'd have a good mounting surface for my drop down power steps!
Old 11-03-2018, 07:17 PM   #10
Blazerowner
If I ever do a frame off that might be what I do. I would like to have some power steps as well eventually.
Kirk
66 Nova
Old 11-04-2018, 10:35 PM   #11
CJM72
Round 2! You guys are so good, you inspired me to dig through the parts bin again to look for some other parts that I might have been overlooking. Fair warning, it appears random fasteners, clips, shims, and general garage junk may have made it in this box at the previous owners house.
15.
16.
17.
18.
19.
20.
21.
22.
Old 11-04-2018, 10:38 PM   #12
1rippen6
I know what everything but 18 also 19 isn't oem
Old 11-04-2018, 10:59 PM   #13
CJM72
18 is a funny piece of sheet metal with a stud/screw in it.
Glad to know 19 is just an add on. I'm excited to find a few hidden gems in here. I'll box up all the loose fasteners and hang on to them. Already found all the jack handle clips and fasteners. Thanks!
Old 11-04-2018, 11:02 PM   #14
1rippen6
If a had to guess I would say a fastener to the tailgate trim is it a CST?
Old 11-04-2018, 11:18 PM   #15
CJM72
I don't think so, but it was totally debadged and had no original interior when I got it. The front roll cage is also preventing me from opening the glove box to see the spid! Damn PO's!
Old 11-04-2018, 11:38 PM   #16
1rippen6
15. Dash bezel trim for the wiper and headlight switch.
16. Radio cups
17. Radio knobs
18. Took a guess
19. Strap anchors not OEM
20. Drivers seat track catch
21. Looks like optic light that plugs into the back of the dash and illuminates the gear selector on the steering column.
22. Headlight switch
Old 11-05-2018, 08:19 PM   #17
dozerbill72
dozerbill72's Avatar
18 looks like the stud out of a dash pad.
dozerbill72 is offline   Reply With Quote
Old 04-02-2021, 05:57 PM   #18
ipoo
ipoo's Avatar
I think # 18 is the hardware that holds heater core assembly to the firewall.
ipoo is offline   Reply With Quote
