10-01-2018, 05:36 PM | #26 |
Re: 1969 C50 crew cab build
Well here are a few more pics of progress.
10-01-2018, 05:37 PM | #27 |
Found another mistake. If you ever build a frame for a C50. The drop amount from the top of the frame to where the front clip sits across the frame rails is 4.25". Not the 3" I somehow measured off the C50 when it was fully assembled. Other than that, everything on the frame seems to work well.
10-01-2018, 05:39 PM | #28 |
If anyone is interested in WAS running and driving C50 without the cab and front clip let me know. Everything is there except the cab, front clip, and radiator.
10-01-2018, 08:55 PM | #29 |
Whereabouts?
10-10-2018, 06:33 PM | #30 |
Near Union, MO.
10-13-2018, 02:07 PM | #31 |
Here is the front end after cutting another 1.5" off the top to fix my mistake. I will make a 3/16" plate that I will weld inside the frame rail to beef it up. My jeep frame is the same height and thickness on the front and I have beat the tar out of it and never had an issue. The extra 400 lbs of the diesel won't be a problem for a road driven vehicle.
10-13-2018, 02:09 PM | #32 |
With any luck I will get the top plates made and welded on today.
10-13-2018, 05:47 PM | #33 |
Moderator
Nice fab work keep it up! This is what I want to do long term with my 67 c50.
Alex 1967 C50 292ci Lumber truck 1967 C50 292ci Dump truck 1967 C60 366ci Fire truck |
10-13-2018, 08:13 PM | #34 |
Got it all sewed up tonight. Looks like where I was 2 weekends ago! Will try the front clip again tomorrow when I get some help from a buddy. The next step is to remake all of the rubber body mounts out of polyurethane.
10-13-2018, 08:16 PM | #35 |
Now to settle in and listen to the Mizzou vs Alabama game. Hopefully they can stay within 18 points and cover the spread!
10-14-2018, 05:51 PM | #36 |
Mizzou got spanked...
Got the front clip on and have the mount for the front grill all measured out and ready to mill. For the front cab mounts I used the factory C50 brackets. I bought a body mount kit for a C-10 from energy suspension (3.4108G) and the bushings marked "4010" are a perfect fit. The back cab mounts are 3.50" tall and will have to be made. Hold on to your shirt when you go to buy 3" diameter 85A polyurethane!!!! Expensive stuff. |
10-14-2018, 07:33 PM | #37 |
why not do like the off road guys do and make a spacer block out of aluminum ? if you have the right size bushing minus its height .
lots of guys doing this for 1" -1.5" body lifts these days .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
10-23-2018, 09:45 PM | #38 |
Got the 2nd cab this weekend. It needs rockers and corners. The crossmembers and underneath are very nice. One of the nicest cabs I have ran across in a while. A neighbor of mine had it. I got lucky on this one!
10-23-2018, 10:19 PM | #39 |
Looking good.
I like your progress. Looks like you have a great Plan. I am watching because my cab is at the sandblast Man's place. After that will be my CC journey.
11-03-2018, 04:28 PM | #40 |
Haven't had much time to work on it lately. Busy, busy like everyone else now days. I included a pic so everyone can see how the clearance I had to redo on the frame for the front clip worked out. Measure twice and cut once, right?? Not in my shop I guess...
11-03-2018, 04:29 PM | #41 |
So is this going to be a 2 cab conversion? In other words no burb? I'm excited to see this
11-03-2018, 04:32 PM | #42 |
a couple more pics
11-03-2018, 04:35 PM | #43 | |
That's the plan anyway. I have no body work experience at all but I think I can get it figured out. Not sure how I am going to mate the cabs yet. After deer season I will start cutting the back of the 1st cab off and the front of the 2nd cab off. Then we will see what it is going to take. |
11-03-2018, 08:49 PM | #44 |
Awesome!! I am in the no body work club too, but I have thought it over quite a bit, Especially since I have 4 cabs setting in my barn. I had to call a friend to talk me out of cutting 2 of them to pieces last week Haha
11-03-2018, 10:54 PM | #45 |
Lucky you! I wish I had 4 cabs to work with. I have looked long and hard for these 2 cabs. There is this guy in Hermann MO that I went to look at some parts at. He had at least 6 perfect cabs...and I mean perfect. He also had 3 primo Blazers. Dude wouldn't sell anything. I guess he just wanted to brag and tease me. I don't blame him, I am sure he has a lot of time in finding them. But why advertise and then not sell.
11-03-2018, 11:27 PM | #46 |
This looks like a great build . Can I ask why you didn't want to use the original frame ? I would guess there plenty strong ? Keep up the great work . I'd love to build a reg cab truck like this with a big flat bed .
56 gmc 4X4 Cummins 5 spd 60F 70R 2005 Ram 3500 DRW cummins 4X4. 2006 Conolift 9/15. 2011 F 350 winter beater New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new ! My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908 |
11-04-2018, 02:35 PM | #47 |
The original frame had several fire truck items that had been welded on and cut off over the years. It probably would have been fine but would have required a BUNCH of cleanup, etc. I really have no reason other than I wanted to I guess. In hindsight I would probably be much further along than where I am.
11-12-2018, 12:11 PM | #48 |
Question. I bought a 69 c50 and Im going to swap in my 79 K3500 DRW axles in. Any idea how close the spring perches are to a 3500 axles? I dont have my hands on the c50 yet.
11-16-2018, 02:36 PM | #49 |
The frame width on a C50 is 34" to the outside. Not real sure what the perch width is on a 3500DRW. It will depend on the spring mounts you choose to use to mount the springs to the frame. It's easy to cut the perches off and weld a new set on when you get all shackles and springs, etc mounted to the frame.
11-16-2018, 05:57 PM | #50 | |
