02-14-2019, 05:59 PM | #51 |
6>8 Plugless........
Re: C20 to K20 Conversion "Simply Toxic"
Nice build and great work on it! Nice work on those cab mounts. I have a 72 gmc cab that is on a 03 half ton burb chassis and the guy put the front cab mount bolt straight through the frame. It works, but IDK if I'll complete the project or separate it.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
02-15-2019, 08:32 AM | #52 |
Thanks Dieselwrencher, I did a good bit or research on how the cabs fit the frames before hand. Came up with something that looked better then some of the ones I saw. If I was to this frame swap again I think I would have picked a burb or a avalanche frame to start with.
1967 Chevy C20 to K20 Conversion "Simply Toxic" http://67-72chevytrucks.com/vboard/s...d.php?t=749409 1971 Chevy C20 Custom Camper LS Swap http://67-72chevytrucks.com/vboard/s...d.php?t=763775 |
02-25-2019, 09:00 AM | #53 |
Worked out in the garage almost all day Saturday tearing the cab apart. Found a bit more rust, so I need to order a few more pieces before I can start going back together. I want to thank 72_tigger for helping with the cab last weekend. Not going to explain all the rust, I'll let the pictures do the talking.
02-25-2019, 09:01 AM | #54 |
A few more pictures of the rust.
02-25-2019, 09:31 AM | #55 |
landarts
Nice job on the cab mounts and I really like your rotisserie the cab is on. That will really help in repairing the rust on the cab. Nice job!
Super Cheyenne aka the "Devil Cowboy" 71 K20 Idaho Edition 69 K10 from the Field 68 Second Chance Fix and Sale 72 GMC 3/4 ton 4x4 K2500 The "Fixrupr" build thread 72 Cheyenne 1/2 ton " FIXRUPR " - daily driver 67 C20 all original paint 71 K20 Custom 4x4 (Idaho Edition) 72 K20 GMC Super Custom 4x4 72 K20 Custom Deluxe 4x4 69 K10 Custom package 4x4 (69 K10 from the field) 72 K10 Custom 71 K10 Custom 72 K20 Custom Deluxe 4x4 72 K20 Crew Cab Project 71 GMC Jimmy CST 72 Blazer 70 Blazer |
02-25-2019, 10:18 AM | #56 |
Thanks landarts, glad I took someones offer on letting me use the rotisserie, its made life way easier.
03-11-2019, 08:34 AM | #57 |
Figured after two days of working on the cab I'd have more done. I got the new driver side floor welded in and the cab corner started. Still have to do everything to the passenger side.
03-11-2019, 01:04 PM | #58 |
Making good progress- always surprising how much thin metal you find when you dig into it
03-11-2019, 02:03 PM | #59 |
Yeah, the more I vibrate the cab taking the driver side apart, the more I see I need to replace on the passenger side. Just ordered a floor board for the passenger side, it looks like Swiss cheese since I took the rocker off.
03-13-2019, 09:57 AM | #60 |
Forgot to post the floor pan pictures the other day. Got the rocker and cab corner lined up last night. Need to take the outer rocker back off to finish the inner rocker. Give everything a final grind, then time to move on to the passenger side.
03-13-2019, 11:33 AM | #61 |
landarts
Floor patch looks great, keep up the good work on bringing it back to life.
03-13-2019, 12:54 PM | #62 |
Nice work- do you think you should take the cab off the rotisserie and mount the doors before you weld the outers on? Just to make sure everything lines up? Just my .02
03-13-2019, 01:15 PM | #63 |
Normally I would say yes to taking the cab off and fitting the doors first. But in my case the bottom of the doors are rusted out and I have all the metal to fix them, so I'm just going fit the doors to the cab. Kind of a backwards way of doing it.
03-13-2019, 01:16 PM | #64 |
03-14-2019, 08:40 AM | #65 |
Finished up the Driver side last night, now just have to seam seal and grind everything smooth. Should see the new passenger side floor board before the weekend, hopefully be able to get that started and finished in the next week.
03-14-2019, 11:36 PM | #66 |
Looks great!
Can I mail you my truck? Mine's slightly better to start, but even southern ones rotted. |
03-15-2019, 07:28 AM | #67 |
Thanks, I don't think there are too many of them that don't have rust on them.
03-22-2019, 10:01 AM | #68 |
No pictures to post today, but after having to wait to get a second passenger side floor board shipped to me, I got the passenger side installed last night. Got both in from Fedex damaged so I ended up using the one with the least amount of damage.
03-25-2019, 07:50 AM | #69 |
I got the passenger side floor board welded in and the passenger side rear cab cut completely out this weekend. Was only able to work on the truck here and there as the wife wanted to go to IKEA and furniture store. But first couple pictures are of the completed driver side I forgot to post. Then some in process of the passenger floor.
03-25-2019, 07:55 AM | #70 |
Shows how much I had to cut out of the passenger side cab corner. I have to remove the plates that are in the back of the cab too and weld in some new metal under them. I followed a bunch of rust the more I cut into it. Since the new rear cab support isn't exactly the same as the original, I decided to put the cab corner on first and make sure that is all lined up before I messed with the floor and brace.
03-25-2019, 10:04 AM | #71 |
Almost forgot to post this. Decided to scrap the Dana 44 front axle, went and bought a Dana 60 king pin axle. Came out of a '79 Ford F-350.
03-29-2019, 10:43 AM | #72 |
So this passenger side has been fighting me the entire way. The lower A-pillar and B-pillar are completely different then stock. To the point I had to cut the B-pillar apart and add metal to it, and on the A-pillar I'm going to have to modify the outer rocker. Once I figured that part out I ended up building a piece for the rear of the cab and modifying the inner rocker piece. Still need to grind the welds and do a bit of metal finishing and it'll be all good. Have I said how much I like this re-stamped metal yet?
03-29-2019, 09:34 PM | #73 |
You’re burnin’ up some wire! Going to be a solid cab when you’re done
03-30-2019, 02:52 PM | #74 |
landarts
Looking good, a little grinding and paint and she will be like new again. Nice job saving this one!
04-02-2019, 11:21 AM | #75 |
Proprietor of Dale's Corner
Subbed
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
