Just when you think your out (64 Fleetside)
I just picked this 1964 Fleetside custom
No running gear was an Auto Non PS/PB . I'm going to merge this very rusty (Michigan) 02 silverado . . ![]() . ![]() . ![]() . . ![]() . ![]() . ![]() . ![]()
My Spelling is Not Incorrect...It's 'Creative' . . 1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E http://67-72chevytrucks.com/vboard/s...d.php?t=789617 59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341 Last edited by Softpatch; 06-21-2019 at 10:47 PM. |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Re: Just when you think your out (64 Fleetside)
Are you saying you're going to put it on the silverado frame?
Yes.? .
My Spelling is Not Incorrect...It's 'Creative' . . 1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E http://67-72chevytrucks.com/vboard/s...d.php?t=789617 59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341 |
Active Member
![]() Join Date: Aug 2012
I think I would try to keep the original frame. The frames on the '99-'07 trucks are very bad about rusting through.
If you are set on using the '02 frame, make sure it doesn't have serious rust issues in the boxed areas. |
![]() Join Date: Aug 2004
Stance on the newer is 6” wider than the 60-66
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
60-66 Nut
The '88 and up frames are drastically different from the '63-'87 frames. You are in for a LOT of fabricating and work.
Btw... The fender emblems are from a 66.
Very rusty?!?! Man if you were from Michigan that would be considered a pretty darn clean truck! No rust on the box,rockers still on, that thing must have migrated your way a long time ago.
Cab corners too!
Thank you for that ....
The dash cluster should have been a give a way. you are correct it is indeed a 1966 not a 1964. and thanks for the heads up on the wider frame on the 02 . .....W
Personally, I think the 66 is best of the generation.
If you decide to skip the frame swap idea, are wanting to stay with the 3/4 ton, or were you thinking of converting it to a 1/2 ton?
I don't have a clue.?
I have a problem I like to rescue cars/Trucks that have been passed on. The 02 silverado 1500 was a $200 truck its is rusty it has a 4.3 and a 4L60E Trans need love it's to light for what a need.. the 66 custom was rusting in a yard under a pine tree the owner just wanted the Drive trane 454/T400 then back out under the tree..... I had to save it . not my favrote yr I'm a knee knocker guy . My old truck . ![]()
once you are in, you are never out..... even if you think you are...lol
#15 |
#16 |
Never Ending Projects
Closing this thread as OP started a new thread instead of updating this one.
Part II found at http://67-72chevytrucks.com/vboard/s...d.php?t=789617
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
