Old 07-10-2019, 03:47 PM   #1
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Hood poppers
2020 price = $70 a set---shipped
Email: frankeham@comcast.net
Phone: 360-956-7170
PICKMUP is offline   Reply With Quote
Old 07-10-2019, 03:59 PM   #2
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Re: Hood poppers
Pull the handle and the hood opens 1"-2". No prying or chipping paint or grills.
Bolts to your stock hood without any modifications or drilling.
I just finished a new batch and the cost of everything I use went up!
I have to make or modify most of the components.
Springs: cut, heat, bend, grind/polish. ***(2020: new custom made stainless springs).
Retainers: cut, grind, sand and punch. ***(Corvette=$$$).
Straps: cut, grind/sand and drill.
Hardware
Instructions
These little suckers are a pain in the butt to build. Please feel free to copy or duplicate these, if you like.
2020 price= $70 a set---shipped
NOTE: The "hood latch" assy is not included...use your existing one.
Phone: 360-956-7170
Old 07-10-2019, 10:12 PM   #3
Merican68C10
Merican68C10's Avatar
Retainers: cut, grind,sand and punch.
Hardware
Instructions
$60 a set---shipped
Merican68C10 is offline   Reply With Quote
Old 07-10-2019, 10:14 PM   #4
Merican68C10
Originally Posted by Merican68C10 View Post
This may be a stupid question, but does the spring leave any kind of wear mark on what it rests upon while in closed position. Or even when you slam the hood?
Old 07-11-2019, 05:19 PM   #5
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Re: Hood poppers
It does wear a little spot. You can just slip a piece of 1/4 OD clear tubing over the bottom coil, if that bothers you.
I will include that with all Hood Poppers from now on.
Thanks, Frank
Phone: 360-956-7170
Old 07-12-2019, 10:30 AM   #6
72LB
72LB's Avatar
Re: Hood poppers
If you don't mind me asking, where are you getting the springs? I have an idea for my truck but aren't finding springs.
1985 C10 shortbed, current project.
Member of the Upstate SC GM Truck Club.
72LB is offline   Reply With Quote
Old 07-12-2019, 10:47 AM   #7
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Re: Hood poppers
I can only tell you that I finally had to make them from larger ones, made by a spring company. They still have to be cut, ground, sanded, heated, bent and polished. The spring tension has to be just right to open the hood, but still not "bind" when closed. That is all the specific info I can offer.
Phone: 360-956-7170
Old 07-12-2019, 08:38 PM   #8
cheyenne-man
Re: Hood poppers
i'll take one.
cheyenne-man is offline   Reply With Quote
Old 07-12-2019, 08:43 PM   #9
cheyenne-man
Re: Hood poppers
payment sent via paypal
Old 07-13-2019, 01:02 PM   #10
69cam
Re: Hood poppers
I'll take one. Sending payment. Thanks!
69cam is offline   Reply With Quote
Old 07-14-2019, 03:45 AM   #11
un4gvn!
un4gvn!'s Avatar
Re: Hood poppers
I'm interested in one. Can you tell me if instead of being flat on top, if you can make it more like a bee hive? You know, like a bee hive valve spring.
un4gvn! is offline   Reply With Quote
Old 07-14-2019, 10:04 PM   #12
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Re: Hood poppers
No. I can't do that.
Phone: 360-956-7170
Old 07-20-2019, 09:14 PM   #13
cheyenne-man
Re: Hood poppers
got the hood popper today , works great ! thanks Frank !
Old 07-25-2019, 06:07 PM   #14
ajgriffin
ajgriffin's Avatar
Re: Hood poppers
Payment sent! Thank you!
69 C10 SWB -- Left to me by a loving father. Finishing the build we never got the chance to do together
ajgriffin is offline   Reply With Quote
Old 08-07-2019, 06:02 PM   #15
ajgriffin
ajgriffin's Avatar
Re: Hood poppers
Received and installed my popper...works like a charm! Thanks!
Old 05-07-2020, 07:50 PM   #16
NorCalC20LWB
Re: Hood poppers
Frank, are you still selling these? If so, I will take one.
Thanks,
Brian
NorCalC20LWB is offline   Reply With Quote
Old 05-08-2020, 01:14 PM   #17
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Re: Hood poppers
Yes. I have them done and ready-to-go. Just send PP, shipping info, and ITEM NAME. Thanks, Frank
Phone: 360-956-7170
Old 05-08-2020, 01:24 PM   #18
NorCalC20LWB
Re: Hood poppers
PM sent, thanks Frank.
Old 05-08-2020, 01:31 PM   #19
71gmcC15
71gmcC15's Avatar
Re: Hood poppers
Can I just say that looks like a nice GMC. With out the hood letters I can definitely see why you would need this.
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original )
94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless
07 gmc sierra classic rcsb 4.3 lt 5 speed w/t
04 chevy Silverado 1500 ext cab 5.3 4l60e.
81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green)
71gmcC15 is offline   Reply With Quote
Old 05-15-2020, 10:58 PM   #20
Astro-Balls
Astro-Balls's Avatar
Re: Hood poppers
So, I guess this is a solution to a problem i don't know I have, or Might have in the future.
My hood opens fine with the pull of the handle, do they overtime not just pop open? does this Assist the opening so you dont have to pry the hood open at some point?
Looks like a nice addition.
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline   Reply With Quote
Old 05-16-2020, 11:31 AM   #21
NorCalC20LWB
Re: Hood poppers
Astro, mine started not popping up at all, just sitting there when I popped the release. After fiddling with it for a while I got it to work just "ok". Basically lithium grease on the hinges made a huge difference, plus adjusting the hood "spike", not sure what the real name is, to fit more center in the support hole. I think the biggest problem comes from nearly 50 year old hinges. I like the idea of the spring that Frank makes, looking forward to installing it.
Old 05-21-2020, 04:40 AM   #22
a Good Man
a Good Man's Avatar
Re: Hood poppers
Is it possible to provide Hood poppers and hood latch ?
MY Facebook
( saad_alhajri ) on Instagram
a Good Man is online now   Reply With Quote
Old 05-21-2020, 11:39 AM   #23
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Re: Hood poppers
??? Hood poppers work with all stock 67-72 hood latches.
Phone: 360-956-7170
Old 05-21-2020, 08:38 PM   #24
a Good Man
a Good Man's Avatar
Re: Hood poppers
I know sir but what I mean I want to replace it all with new ones number 1 and 2. I sorry my second language and use the translator sometimes
MY Facebook
Old 05-21-2020, 09:13 PM   #25
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Re: Hood poppers
The originals are better than the imports, so I don't sell the import/repops. No new originals available right now. Frank
Phone: 360-956-7170
