Old 08-22-2019, 10:00 AM   #1
1948ChevyDumpFixer
Power Brakes on a 1948
I've been scouring the catalogs and reading here, but haven't found a definitive power brake build thread for the 48 with manual trans. It seems like there are clearance issues with the clutch linkage on a manual trans with power brakes, but hydro-boost may be an option?
I want to keep the truck looking original, but I also want to be able to drive it without fear of not being able to stop when I need to.
Thanks for any helpful advice (or ridicule)!
1948ChevyDumpFixer is offline   Reply With Quote
Old 08-22-2019, 09:33 PM   #2
1project2many
Re: Power Brakes on a 1948
If you have spent time restoring your truck to original specs and want it to continue to look original consider a Hydrovac. Hydrovac units were available on AD trucks as a factory option. For my '57 I located a Hydrovac from a '60s truck. The later HV looks different but also looks close enough that most folks won't complain.
1project2many is offline   Reply With Quote
Old 08-22-2019, 09:49 PM   #3
1948ChevyDumpFixer
Thanks for the input! My current setup doesn't have Power Steering, did/ does yours?
Old 08-22-2019, 11:18 PM   #4
nvrdone
check out performance on line. they have multiple kits and they say all will clear a manual trans
nvrdone is offline   Reply With Quote
Old 08-23-2019, 04:50 AM   #5
1project2many
My truck was built to work without luxuries. Original options included electric wipers, bed mounted spare, eight cylinder engine, oil bath air cleaner, and 16" wheels. I hope to adapt an original style power assist steering system, possibly from a 70's Ford truck or C3 Corvette, if I ever have find time.
Old 08-23-2019, 08:02 PM   #6
1948ChevyDumpFixer
I have the oil bath air cleaner, but no oil filter assembly.
Old 08-23-2019, 08:02 PM   #7
1948ChevyDumpFixer
thanks!
