Old 01-16-2018, 07:03 PM   #176
Re: Where is my 60-66 Chevy or GMC vin number?
Vin = 1502CG2592B
Blank = 2WD (if there was a K first, it would be 4WD)
15 = 3/4 ton
02 = 127" wheelbase
C = Oakland Plant
G = 1963
2592 = Vehicle Number
B= 7000 lbs GVW
Old 01-16-2018, 11:13 PM   #177
Lobotie
Lobotie's Avatar
Thank you very much Palf70step!
Lobotie is offline   Reply With Quote
Old 02-24-2019, 12:55 AM   #178
totallytea
Red face Re: Where is my 60-66 Chevy or GMC vin number?
My vin has an H for where it was made. Can someone help me figure out what the plant is? Also I would like to know if it has the original motor or not? My vin is 4C144H159472 AND THE ENGINE HAS 5129742 AND V1121TXO. I'm having a hard time figuring it out. I have a 64 Chevy fleetside shortbed truck made 09/64. Any help would be appreciated.
totallytea is offline   Reply With Quote
Old 02-24-2019, 01:48 AM   #179
Captainfab
60-66 Nut
I'm not finding a TXO small block suffix code. Are you sure it isn't TXC?
http://www.nastyz28.com/gm-chevy-cod...s-suffix-9.php
Either way, since it has a 3 letter code, that engine is not original to your truck.
Old 02-24-2019, 02:28 AM   #180
totallytea
It might be but it looked like o to me.
Old 02-24-2019, 02:33 AM   #181
totallytea
Do you know what plant H is? I was told it is Fremont, CA
Old 02-24-2019, 07:11 AM   #182
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
H here is a link . Look at factorystock's post #8
http://67-72chevytrucks.com/vboard/s...d.php?t=594953
Old 02-24-2019, 01:42 PM   #183
totallytea
Thank you. The H makes sense now.
Old 09-03-2019, 07:24 PM   #184
1964c20_jlm
I've got a 66 C30 with a VIN # that starts with C383. Anyone know what body style this it? None of the online VIN decoders know what it is?
Thanks,
-JM
1964c20_jlm is offline   Reply With Quote
Old 09-03-2019, 11:56 PM   #185
Captainfab
60-66 Nut
I can't find the info again, but it seems like those are the numbers for a C30 cab and chassis with the 157" wheelbase. If I remember tomorrow I will take a look at my '66 C30's VIN
Thanks,
-JM
Old 09-08-2019, 01:12 AM   #186
Captainfab
60-66 Nut
I was correct in my thinking. My '66 C30's VIN starts with C3836 and is a cab and chassis with the 157" wheelbase. These typically had campers installed on them.
Old 09-08-2019, 10:39 AM   #187
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
The cab and chassis trucks typically had flatbeds installed on them.
They were made into campers, but on a far less scale.
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline   Reply With Quote
Old 09-09-2019, 08:18 AM   #188
1964c20_jlm
Thanks for the info. -JM
Old 10-15-2019, 04:56 PM   #189
67see10
67see10's Avatar
is the vin a 66? It's to a Carryall
Chevrolet DD
C146 5Z158088
67see10 is offline   Reply With Quote
Old 10-15-2019, 06:23 PM   #190
66-PMD-GMC
66-PMD-GMC's Avatar
Top of drivers door jamb
Chevrolet DD
C146 5Z158088
Projects..
440CID 2X4 Pontiac
Old 10-15-2019, 06:34 PM   #191
67see10
67see10's Avatar
I was trying to determine if this suburban was a 65 or 66
Old 10-15-2019, 11:39 PM   #192
Captainfab
60-66 Nut
The number just before the Z indicates that it is a 1965.
Old 07-12-2021, 05:18 PM   #193
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Hey guys...
Just had a customer come in with a 62 C20 where the sixth digit is an "L"
Where was this thing built ??
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 07-12-2021, 06:11 PM   #194
The Rocknrod
Moderator
The Rocknrod's Avatar
Originally Posted by ChiefRocka View Post
Hey guys...
Looks like Los Angeles - http://67-72chevytrucks.com/vboard/s...d.php?t=368286
