Old 12-14-2019, 12:37 PM   #26
jimbosprint
jimbosprint's Avatar
Re: '72 Cheyenne K10
Title is in my name! I wasn't going to invest too much effort or money on this thing until that was done. What a pain when the previous owner doesn't keep paperwork. Now I can get to work!
jimbosprint is offline   Reply With Quote
Old 12-15-2019, 06:20 PM   #27
jimbosprint
Body lift is out! Looks much better.
Old 12-17-2019, 12:55 AM   #28
jimbosprint
Old 12-17-2019, 07:52 PM   #29
jimbosprint
I pulled the rotten steering components out this morning. New parts are on order: Red Head steering gearbox, Off Road Designs tie rod, Moog drag link, and front brake calipers/pads/hoses.
Old 12-20-2019, 09:11 PM   #30
jimbosprint
Made some progress today. I installed the new power steering gearbox, pitman arm, and drag link. Still waiting on delivery of the ORD tie rod and a new steering coupler. New 15"x8" wagon wheels showed up, and I picked up a set of BF Goodrich Mud Terrain T/A KM2 tires (33x12.5R15).
Old 12-21-2019, 03:30 PM   #31
jimbosprint
Damn, the front brake hoses were a royal pain! Took me 2 hours just for the passenger side. The 15/16 nut on the inside of the frame rail requires a huge wrench, plus the other brake lines and fuel lines are totally in the way.
Old 12-22-2019, 08:46 PM   #32
jimbosprint
Tires and wheels on the truck -
Old 12-22-2019, 09:45 PM   #33
Willowrun
Willowrun's Avatar
Nice work on your truck. I’m really digging it.
Old 12-23-2019, 01:03 PM   #34
jimbosprint
I read on here that the ORD tie rod and tie rod ends that I ordered will not fit on this truck, so I cancelled that and ordered some Moog tie rod ends from Summit Racing.
Old 12-27-2019, 07:28 PM   #35
jimbosprint
Steering coupling is back together. Still waiting on tie rod ends from Summit. One of them shipped from Texas despite my cart saying they were all shipping from Nevada 1-day ground.
Old 12-29-2019, 04:52 PM   #36
jimbosprint
After dropping the body, I notice the distributor is hitting the firewall. It needs to be replaced anyways (looks like it might have been on fire!), but I am hoping that I can get it out without lifting the body again. Maybe I can break the cap.
Old 12-30-2019, 03:09 PM   #37
jimbosprint
I got the cap off, but there are more melted wires than I thought. Might explain why it runs poorly. Considering the other wiring issues, I think the safest and best option is to re-wire the entire truck.
Old 12-30-2019, 04:24 PM   #38
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Looking nice! I might have good oem wire harnesses from my 72 blazer that I swapped for new.
Old 12-30-2019, 07:14 PM   #39
jimbosprint
Thanks! I just ordered an American Autowire complete harness kit, and new distributor and plug wires.
Old 12-30-2019, 08:47 PM   #40
DeadheadNM
Carpe manana
DeadheadNM's Avatar
They do good work from my experience and USA made
Old 12-31-2019, 08:00 PM   #41
landarts
landarts
If you are having issues with the HEI hitting the firewall you could go with an small cap HEI that has a external coil. that will help a bunch. Nice work on the truck!
Super Cheyenne aka the "Devil Cowboy"
71 K20 Idaho Edition
69 K10 from the Field
68 Second Chance
Fix and Sale 72 GMC 3/4 ton 4x4 K2500
The "Fixrupr" build thread
72 Cheyenne 1/2 ton " FIXRUPR " - daily driver
67 C20 all original paint
71 K20 Custom 4x4 (Idaho Edition)
72 K20 GMC Super Custom 4x4
72 K20 Custom Deluxe 4x4
69 K10 Custom package 4x4 (69 K10 from the field)
72 K10 Custom
71 K10 Custom
72 K20 Crew Cab Project
71 GMC Jimmy CST
72 Blazer
70 Blazer
landarts is offline   Reply With Quote
Old 12-31-2019, 09:48 PM   #42
jimbosprint
Well I'm hoping the cheap HEI I bought from Jegs will fit. If it doesn't I might have to go that direction. Thanks!
Old 01-01-2020, 08:28 PM   #43
jimbosprint
Just get a little done at a time...
Added power steering fluid and did initial bleed - 20 times lock to lock slowly with the engine off and keeping the reservoir filled. Red Head instructions say wait 24 hours and repeat 10 more times before starting engine and topping off.
Replaced rotten tie rod ends with new Moog parts.
Old 01-03-2020, 08:38 AM   #44
52napco
Good luck with that Red Head box..both the ones I've bought from them are junk..poor quality control. Never again for me.
52napco is offline   Reply With Quote
Old 01-12-2020, 01:20 PM   #45
jimbosprint
Previous owner told me there was an engine fire, but it kept running so he didn't fix it. The (red) wire melted to the rest with no shielding was powering the distributor!
The new wiring harness should be here in a few days. Looking forward to having a safe electrical system in this truck.
Old 01-13-2020, 01:35 PM   #46
erichevy
erichevy's Avatar
Nice truck! I love these kind of builds
1979 GMC C35 - Farm Work Truck
1986 GMC C25 Crew Cab
1987 SWB R10
erichevy is offline   Reply With Quote
Old 01-15-2020, 08:34 PM   #47
jimbosprint
Wiring harness arrived! I got the old dash harness pulled out today. First step is cutting a big hole in the firewall, so no going back now!
Old 01-17-2020, 12:01 AM   #48
jimbosprint
With the help of a friend we got right back to work on the electrical this morning. Firewall was cut out, and new bulkhead and fuses installed easy enough. Crimping the wire ends isn't fun at first, but you get better at it. This update kit is way overkill for this truck, but it will be ready for anything else I want to add - like vintage air.
Old 01-17-2020, 09:19 PM   #49
jimbosprint
More progress today. I got the new alternator installed, and most of the engine/headlight wiring complete.
Old 01-18-2020, 01:21 AM   #50
Scurry67
looking good!
67 SWB First Build
http://67-72chevytrucks.com/vboard/s...d.php?t=777171
Scurry67 is offline   Reply With Quote
ochre
