Old 12-27-2019, 11:36 AM   #4226
Grizz1963
Grizz1963's Avatar
Re: Grizz's Redneck Express 1966 Chevy Short Fleetside RESTO-GO!
So.........
Cat Stevens sang “The first cut is the deepest”
Not sure if its that relevant to this truck, but once marked out, I fitted a new cutting disc and set to work cautiously
Cut through.
Then used a file to tidy up the corners and a flap disc to clean the etch primer away.
More fettling and fine tuning needed.
Everything takes time.
But got it done.
Then earthed up the front panel after practicing and lowering the power feed but increasing wire speed on some of the scrap metal.
Started tacking one spot at a time to prevent warping.
Ground back.
Holes filled, dents mostly gone, needs a skim of filler eventually
Etch primer both sides.
And all of this just to remove this bit of mess.
So that was day one.
Two hours in total, start to finish.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 12-27-2019, 12:08 PM   #4227
realvc
realvc's Avatar
Dude, you are THE MAN, great job.
You just jumped off in there and got'er done.
Looks great too. Your caravan workshop is really a nice addition to your work space.
Vince
Galatians 6:14
62 SWB stepside, 94 Wrangler, 99 Z71, 99 vette
My Project http://67-72chevytrucks.com/vboard/s...d.php?t=719086
"If it's too loud, you're too old"
realvc is offline   Reply With Quote
Old 12-27-2019, 12:43 PM   #4228
Nice work Rian!!
Palf70Step is online now   Reply With Quote
Old 12-27-2019, 01:33 PM   #4229
60chevyjim
60chevyjim's Avatar
hi Rian happy holidays , nice job on the rust repair !! great to see progress on the 66 . your resto on the new van wheels looks great too !! .
60chevyjim is offline   Reply With Quote
Old 12-27-2019, 11:20 PM   #4230
flashed
Looks great Rian .
flashed is offline   Reply With Quote
Old 12-28-2019, 09:34 AM   #4231
Grizz1963
Grizz1963's Avatar
Thank you Vince.
It has delivered as well as possible
Warm, dry, organised
Nice work Rian!!
Good enough, and better than before.
Thanks Jim, Happy Holidays to you and yours as well.
Wheels came out well.
Originally Posted by flashed View Post
Looks great Rian .
Hi John, thanks buddy.
Happy too.
So we were out early-ish to go swap some Christmas presents for the correct size.
And to pick up a new welding helmet at Tool Station.
I had previously read up on specifications and found that the £10.00 difference between two lower price helmets equated to one sensor vs four. Quicker response time. Exchangeable batteries etc.
So you get what you pay for in this game.
I bought the SiP welding mask without stickers. (Watch this space)
Spec sheet.
I guess the next step is going to be gingerly making my way toward the garage and choosing what repair to start on next.
It may be partly dictated by the repair steel availability
More later.
Old 12-28-2019, 10:25 AM   #4232
Indian113
Indian113's Avatar
That looks like a good choice for a helmet. Your right about getting what you pay for!
Indian113 is offline   Reply With Quote
Old 12-28-2019, 03:18 PM   #4233
Grizz1963
Grizz1963's Avatar
Absolutely
Works real well.
Spent less than two hours down in the shop today.
Had some stuff to deal with.
First job was to correct part of yesterday’s front panel repair, adding about 15mm weld from behind on the crest.
Dressed back.
Primed.
Packed away, along with the radiator panel and inner fenders.
Old 12-28-2019, 05:19 PM   #4234
Grizz1963
Grizz1963's Avatar
Despite all sorts of good intentions, I managed less than 2 hours in the shed today.
Part was correcting my previous weld.
Then on to a few holes in the drivers side door.
Looking at the original drivers side door, specifically where the mirror was mounted, vs the new passenger door I got, that obviously used to have convoy mirrors
So I needed to ensure I welded up all the right holes.
Using both the new mirror stalk and measurements from my old door.
It has some work to do too.
Of course it has some interesting inverse dents, but nothing a hammer and dolly could not sort, with caution.
Convoy mirror mounting points.
Prepped.
Adjustable heat sink tool.
Copper pipe.
Holes plugged.
Worked back.
Etch Primer added.
At this point I closed shop.
Next job will be cutting some rust from the door skin and replacing with fresh metal.
Done.
Old 12-28-2019, 05:21 PM   #4235
Old 12-28-2019, 05:37 PM   #4236
Grizz1963
Grizz1963's Avatar
Amazing how it takes time to do every action.
But happy to be back on it again
Old 12-29-2019, 06:18 AM   #4237
Grizz1963
Grizz1963's Avatar
Another copy and paste on here with a couple of video clip links around metal working.
I was asked the question by a mate, and am pretty certain I have not covered it fully, so happy for anyone else to add in more to enhance the response as a resource for anyone else, who like me learns as they go along.
Originally Posted by sparkplug View Post
So good to see truck time again :thumb2
As a complete novice welder - could you explain what the heatsink copper pipe was for?
I understand that it absorbs heat, but I don't understand why...
OK. So half your reply lies in this video.
https://youtu.be/0Iik1ftVGXI
And then some more here.
https://youtu.be/qBJwngEimZU
Half or more than half the holes and repairs on this truck will be to older holes that may have been worked before, leaving the metal thin and tired.
The copper is essentially a non stick surface where the new weld (molten steel) is laid down in order to either fill, or repair, join fresh metal.
Sheet metal is actually quite thin and the first thing that happens is that you blow holes through it, making the hole bigger when a welders amps, wire feed is not set up right. Different jobs take different settings, like most things in life.
Where old rust has eaten at the steel, it becomes fragile, like lace, with holes mixed in with thin, compromised steel in between which mostly cannot be welded up.
So you cut away the dead metal, and make and shape up a patch and weld it back in.
When heated to melting point by the weld, the metal expands and pushes (WARPS) surrounding metal.
The copper removes some of the heat fast.
I also have a copper plate, 120mm X 50mm X 6mm used for larger flat sections. As well as some bronze “round bar” part of an old shaft.
The flattened copper pipe can be shaped and bent to fit in spaces like a door window frame etc as shown.
Many places (because rust happens in tight spots often as slow evaporation and crud collection ) you cannot get in with a heat sink, so a wet rag can work, or small repeated spot welds work better.
Hence it often taking time, a lot of time to do what seems like a small job.
Practice helps with speed too. But making a shaped panel or patch adds time.
Once welded, you need to grind back, inspect, and weld again if holes appear where you did not quite get penetration or filling.
Old 12-29-2019, 08:35 AM   #4238
mjh1965
mjh1965's Avatar
Glad to see you back on it . Repair looks good. Of course I will have to come and inspect it
FINALLY PUTTING IT BACK TOGETHER AT LONG LAST
MY BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=611614
mjh1965 is offline   Reply With Quote
Old 12-29-2019, 11:29 AM   #4239
Grizz1963
Grizz1963's Avatar
Of course you will inspect it......
I just hope to pass muster
Another typical holiday start,
Only got out the house by about 11.15 or so.
No regrets though.
So this was today’s task.......
Weld up the small hole to the left once it stopped running away from me, as it was going to be paper thin up to a point.....
Where the point ended up being, that was the question.
Thought I would also just for the sake of illustration for those unfamiliar or not initiated in Mig welding, share a few of my heat sink tools.
And another important tool(s)
The grinder.
I keep three on standby, all differently set up, one with a 1mm cutting disc, one with a 5mm grinding disc, and a flap disc for finishing off.
So back to the patch, I calculated that a 50mm X 50mm patch would cover the weakness and holes.
Keep in mind, this is my very good California door for the passenger side.
It still has work on the inside too, dents and a lace finish of rust on the bottom cup.
So patch ready with a very gentle curve bent into it.
The door bottom corner has sustained some damage before at some point, resulting in a somewhat bent corner, and also some very mild extended dents on the door skin, shown later.
Marked out for cutting, xx and x marks to maintain correct orientation on gentle curve. Note existing dents next to previous weld.
And CUT !!!
Lift
Contrast
Result.
It’s a Boy !!
Part one done,
Coffee time.
Old 12-29-2019, 01:37 PM   #4240
Grizz1963
Grizz1963's Avatar
Just to illustrate how time slips between your fingers like sand on a hot summers day on the beach the next step was to go dig out the garage vacuum cleaner.
Residual grit from the media blasting down in the bottom seam of the door plus grinder dust needed to be removed.
Followed by fine tuning the fit of the patch into the now gaping hole in my door.
Nice and it actually was.
Using my magical welding magnets, I tacked the corners and then centres.
In order to prevent warping I carried on slowly, allowing it to cool between sessions.
During this time my long suffering photographer got in from work.
So I gave her a POS mask to wear while trying to get a pic of me striking an arc.
Success.
After all the welding, I ground the welds flatter, then proceeded with a hammer and dolly, trying to reshape the corner which had been damaged at some point in the past.
Eventually, etch primer and done.
Hardly visible, and I suspect it will be a skim of filler job eventually, but two long skinny dents from the past.
That concludes the welding on the outside of the passenger door.
Next job will be the rust on the insides of the door.
Time for a rum and Pepsi Max now.
Old 12-29-2019, 01:48 PM   #4241
Nice work Rian!
Old 12-29-2019, 03:13 PM   #4242
Indian113
Indian113's Avatar
Take a well deserved break!
Old 12-30-2019, 11:24 AM   #4243
Grizz1963
Grizz1963's Avatar
Nice work Rian!
Thanks Bill
Thanks Ray, I certainly did.
Sally cooked 😉
Old 12-30-2019, 11:26 AM   #4244
Grizz1963
Grizz1963's Avatar
Been over to mate Martins today to collect the Chevy cab lifter for mate @Pauly in Essex and some more steel from him for my rust repairs.
Amazed at the size of the cab lifter in the rear.
https://youtu.be/vfTC9wyQKK0
Next up back to Just Tyres to collect the wheels and new tyres.
Gone a bit wider.
Fitting will be once the springs are cut down on the suspension to fill the arches a bit more with the 17” wheels and tyres.
Almost Happy New Year time.
Old 12-30-2019, 01:11 PM   #4245
Grizz1963
Grizz1963's Avatar
Back to the evolution of the Galaxy.
On the way home I stopped at Just Tyres.....
The name says it all.
What it does not say, is super service, and watching the guys work with other customers made me feel good.
Service is still king.
So......
Remember they removed and disposed of the other tyres for me, so that I could refurb and paint the wheels.
Decent new tyres fitted.
Happy with the price too.
I chose not to have the the wheels fitted to,the car, as I have an appointment with @PaulY and Dr Grinder to lower the Galaxy.
This will happen another day.
So back home these will be waiting for attention.
Can’t wait to get this lot wrapped up.
Old 01-01-2020, 04:11 PM   #4246
Grizz1963
Grizz1963's Avatar
So it is Happy New Year day.
Last year on the 1st of January I changed the look of my 79 Blazer (now sold and in a film role)
Catscan Approved
So today I went to the garage just before 12.00 after a slow start.
After powering everything up, I added a sticker to my new mask, sent by mate Gary in Florida.
Swapped my new to me, California door for the trucks original, from California door that is so damaged.
Today’s first job was just to check out all the drilled holes from years past, mark them, weld them up.
These trucks were fixed real old Skool way, so pulling dents included holes, screws and pullers.
And after the media blasting the dents really still are there. So loads of work still to be done.
Some of the holes are quite large, and having been worked before, a lot of the steel is thin, stretched and the edges really are very thin.
So how do you fix these bloody holes ??
In my case the solution seemed obvious , thread through some 4” nails from behind, either by hand if you can find a place to get your hand and a nail in, or feed some thread, or string into the door though said hole, then attach firmly to the point of the nail and pull through and secure.
Then weld the nail in place using the head as a place to lay metal onto, and build up.
Finally, cut off the nail as flush as possible and grind back.
The track of the original dent still runs diagonally up the door and hopefully a puller and a final skim of filler would be enough there.
Finally I got all the holes in the area done.
More dents lover down, and of course a load of rust to get to next time around.
Next up would be the mirror mounting point and it’s stuck in drilled out studs and a bunch of holes on the door frame and to present it.
Seems it has convoy mirrors fitted and then they got broken off at some point, leaving more dents and holes.
But coffee, and a sandwich first, plus hand over all of Harleys stuff that was still in the house to Kevin for their cats or a cat charity.
More in a bit.
Old 01-01-2020, 04:58 PM   #4247
Grizz1963
Grizz1963's Avatar
A few years ago when I stripped the doors down, the drivers side mirror stalk screws were so tightly rusted in place that I was forced to drill out the heads, and to commit to later on adding Riv Nuts to fix the new rear view mirrors
Today I thought I would try to ease the left over studs out, using a vice grip or is that vise grip?
Success !!!
Then screwed them back in to protect the threads.
And prepped the holes to be welded.
Welded
Ground back.
Etch primer.
And done for the day.
I decided to do the door skin rust repairs another day but rather to spend time with Sally who has been good as gold.
Dinner, medium cream sherry and a fire in the lounge.
Perfect.
Old 01-01-2020, 06:50 PM   #4248
Nice to see you getting at it. I'll be looking forward to doing mine again once I get the engine back and get over this crud.
Old 01-02-2020, 05:42 AM   #4249
Grizz1963
Grizz1963's Avatar
Feeling good.
A question on another forum.
[quote author=Welsh link=topic=127490.msg4371185#msg4371185 date=1577951521]
Grizz, did you get any pictures of the Blazer, after it was prepped for its movie role? :sip:
[/quote]
Unfortunately my word is my bond.
The buyer asked me to sit on the photos he sent till end February
So I need to keep it that way.
Interestingly while in the USA in Hannibal with Craig last year we were looking for a very specific toy truck for him in Walmart. Five different stores in over 150km with no success. But Craig found me a Die Cast 1:24 model of the Blazer painted up in the colours in which it has now been painted and accessorised
Pure luck.
Bought it for $20.00 and brought home.
You can come take a look.
I also have a similar 1:24 model of my 66 C10 with great detail gifted to me years ago by a friend in America
May be a while before the C10 looks like this tough.
Old 01-04-2020, 10:06 AM   #4250
Grizz1963
Grizz1963's Avatar
Been spending the last two days trying to prepare for my year end performance review while on leave.
Not my favourite time of year.
Anyway, small lessons learned all the time.
Debenhams in Chatham are closing down and Sallys suggestion that we went to see if anything caught our eye, paid off, twice.
Got 4 work shirts and some socks valued at £114.00 for £23.00
My kinda shopping, despite two shirts being pink.
Then off to Halfords to get two more cans of etch primer.
Clever girl, suggested I look online at Evilbay for it
So........ 4x 500ml cans of UPol for £24.85 delivered vs Halfords price at £10.00 per can.
Whichever way you look at it.
Savings to be spent elsewhere.
Hope to get an hour or two in today to carry on with door skin rust repairs.
