Old 04-14-2020, 11:45 PM   #201
Gregski
Gregski's Avatar
Re: A '54 named Busty
where the magic happens
Gregski is offline   Reply With Quote
Old 04-15-2020, 06:08 PM   #202
LT7A
Good job on the fender metal massage work. I would think that would be a difficult part of patina preservation. Getting it straight, but not wrecking the "original finish". By original, I guess I mean current.
Old 04-16-2020, 12:35 AM   #203
Gregski
Gregski's Avatar
Thanks mate, yes I lost the paint code for that paint mix so I can't risk ruining it, LOL
Old 04-16-2020, 12:38 AM   #204
Gregski
Gregski's Avatar
added some more gussets at the top, and I must say I am pretty proud of the result, but am I the only idiot who tries to use weld beads as filler, with crappy results, ha ha
Old 04-16-2020, 01:45 PM   #205
texxxan
texxxan's Avatar
Awesome build. Wouldn't be possible without the beer.
texxxan is offline   Reply With Quote
Old 04-16-2020, 07:13 PM   #206
joedoh
joedoh's Avatar
nice work!
no you arent, but I gotta tell you, I used to have trouble closing gaps on thick steel but now even a 3/16 gap on sheetmetal (you would bbe amazing how much this happens with a measure once cut once mentality) doesnt scare me any more. whether its learning better welder settings or experience, its getting easier.
Old 04-16-2020, 08:39 PM   #207
Gregski
Gregski's Avatar
Originally Posted by joedoh View Post
nice work!
ha ha, as AVE says "I measured once and cut twice and it's still too short !!!"
Old 04-16-2020, 08:59 PM   #208
Chaplain
Chaplain's Avatar
Sup
Chaplain is offline   Reply With Quote
Old 04-16-2020, 11:29 PM   #209
Gregski
Gregski's Avatar
next it was time to fabrimake the radiator frame / core support brackets which would join that contraption to the Camaro frame horns
we start with a benign piece of metal slightly thicker than 1/8th I think, I measured from the outside edge of each frame horn to the radiator frame and it was approximately 9" on each side and this scrap piece just happens to be 18" and a gnats hair long
Old 04-16-2020, 11:33 PM   #210
Gregski
Gregski's Avatar
you ever wonder why after measuring a piece, finding it's center, marking it with a SHARPIE, then cutting it, only to find out one piece is slightly longer than the other
well, today I was in a finding out kinda mood, so I measured 9 inches exactly from each side and drew a line with my SHARPIE
as you can see the lines were off, I recon it's on the account of the thichness of that pen, or it's fat shoulder, good to know either way, so for exercise we split the difference, (pun intended)
Old 04-16-2020, 11:38 PM   #211
Gregski
Gregski's Avatar
... and now Metal Fab Advice from A Guy Who Should Not Be Giving Metal Fab Advice
if you want straight / even cuts when cutting with an angle grinder, anything thicker than sheet metal, so something like square tubing or pipe, only cut through the surface on each edge, then flip or rotate the piece and cut the other side only through the surface, reason being is that as you cut downwards the blade will go slightly at an angle either one way or the other way depending if you are right or left handed, this is a common problem as you try to stare down at the cut, it's a natural bad habit, but if you only penetrate that wall then rotate the piece then you will not cut far deep enough to skew your line, kapish?
Old 04-16-2020, 11:41 PM   #212
Gregski
Gregski's Avatar
so now we had two 9" pieces, whooptie doo
oh wait...
Old 04-16-2020, 11:44 PM   #213
Gregski
Gregski's Avatar
second verse
same as the first
but a whole lot sharper
and a whole lot worse...
Old 04-16-2020, 11:47 PM   #214
Gregski
Gregski's Avatar
growing up on a farm we threw nothing away, knowing some day we might find a use for it...
Old 04-16-2020, 11:48 PM   #215
Gregski
Gregski's Avatar
now that's what I call getting your moneys worth out of the wheel of death
Old 04-16-2020, 11:52 PM   #216
Gregski
Gregski's Avatar
what the hewk is he making? he's just cutting, and cutting, until there's nothing going to be left...
Old 04-16-2020, 11:54 PM   #217
Gregski
Gregski's Avatar
and now we make the one for the other side....
Old 04-16-2020, 11:57 PM   #218
Gregski
Gregski's Avatar
after drilling crooked off center holes for 47 1/2 years, tonight... I put my foot down
Old 04-17-2020, 12:05 AM   #219
Gregski
Gregski's Avatar
... and now more Metal Fab Advice from A Guy Who Should Not Be Giving Metal Fab Advice
when drilling always use astro glide or super lube of some kind, any motor oil will do, don't listen to guys who swear by cutting oil only, that is nonsense, my godfather is an amazing blacksmith and I'm telling you motor oil is fine, you can even use WD-40, water even, hewk beer, no wait that would be crazy talk, not beer, don't do that
first of all use a corded drill, corded drills are for ... wait for it... DRILLING, but but but, my wife got me a sexy cordless drill, yes, that's awesome, cordless drills are for guys who drive trucks with leather interiors and never put anything in the beds of their trucks so they won't scratch them up (tongue and cheek people, I'm just kidding, but seriously corded drills may be more torquay and help you out)
and when you start to drill a hole don't press down on the drill like a gorilla just hold it steady and let it do it's job, ie drill under it's own weight, then as it starts it's hole then put some pressure on it, and most importantly if you see smoke give it a splash of lubricant, I just dip my tip [enter dirty joke here] in a small can of oil or what ever I have near me, and your drill remnants should look like curly long strands of pubic hair, not tiny glitter pieces, tiny glitter pieces means your drill bit is dull and most likely you drive a truck with leather interior, ha ha
Old 04-17-2020, 12:09 AM   #220
Gregski
Gregski's Avatar
so holes done on one side...
Old 04-17-2020, 12:10 AM   #221
Gregski
Gregski's Avatar
and holes drilled in both brackets
Old 04-17-2020, 12:12 AM   #222
Gregski
Gregski's Avatar
de·burr
/dēˈbər/
verb
verb: debur
neaten and smooth the rough edges or ridges of (an object, typically one made of metal).
Old 04-17-2020, 12:14 AM   #223
Gregski
Gregski's Avatar
well it's getting dark, so let's see if we can get these welded by nightfall
Old 04-17-2020, 12:18 AM   #224
Gregski
Gregski's Avatar
I have no idea how they are going to get mounted yet, but I know they will be rubber mounted in some way
shown with old core support rubber bushings from my '74 square, (these OEM rubber mounts were really really nice and well made, I wonder if any of you know where I can find them, and please don't say LMC truck, I bought the random garbage they sell, it seems like they just went to ACE Hardware and grabbed a handful of grade 5 nuts and bolts, ha ha)
Old 04-17-2020, 01:01 AM   #225
joedoh
joedoh's Avatar
nice fab! people dont realize how hard it is to visualize something that doesnt exist and then make it. I knew a guy that would think about a loft (3d term for a wing chord or fuselage feature) for a week, smoking cigarettes and just staring out the window. then he would make a point in space and just draw the loft in one line. it was a fine skill i recognized then and now, so nice work!
