Old 05-07-2020, 04:08 PM   #1
forestb
forestb's Avatar
62 Stock front shocks
Does anyone know length of the stock front shock fully extended and fully compressed?
forestb is offline   Reply With Quote
Old 05-08-2020, 10:24 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: 62 Stock front shocks
I found a thread that lists a couple but doesn't have the measurement. But you can probably extrapolate the info.
http://67-72chevytrucks.com/vboard/s...d.php?t=165389
Old 05-08-2020, 04:31 PM   #3
forestb
forestb's Avatar
Are the 60-62's the same as the 63-66's that thread is talking about a 65
Old 05-08-2020, 06:50 PM   #4
LVPhotos
LVPhotos's Avatar
Take a measurement at ride height add at least 3" then -3" unless you're going long travel then Jack it up for full droop. If anyone has messed with torsion bars that just adds to fun
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 05-08-2020, 07:00 PM   #5
forestb
forestb's Avatar
My truck has a 77 front clip with 2 inch drop coils so I can not do this to find out the stock spring height.
Old 05-09-2020, 08:33 AM   #6
bhap
bhap's Avatar
RockAuto says:
Front:
Shock Stroke 5.11 IN
Body Diameter 41.40
Fully Open Length 14.64 IN
Type Vintage Gas Charged
Alternate/OEM Part Number(s): 88946138
Rear:
Shock Stroke 10.61 IN
Body Diameter 41.40
Fully Open Length 25.54 IN
Alternate/OEM Part Number(s): 88946176
Length - stroke = collapsed length
bhap is offline   Reply With Quote
Old 05-09-2020, 06:26 PM   #7
forestb
forestb's Avatar
Awesome thanks. Should I then assume that fully compressed is 9.53”
Old 05-11-2020, 09:49 AM   #8
verdell
verdell's Avatar
Yes Sir,
14.64" expanded
9.53" compressed
5.11" stroke
verdell is offline   Reply With Quote
