04-21-2020, 09:30 AM | #1 |
Cigarette lighter
I added a cigarette lighter to my 50 3100 and am thinking it should be fused. Not sure it was that way to begin with but I have gone up to 30 amp fuse and the lighter blows it as soon as it is pushed in in.
I won’t likely use it for it’s original purpose but would like it to work. I would also plan on using a USB charger. Should I remove the fuse (12V coming straight from ignition switch or would I risk burning up the charger. Anyone know if it was fused originally? |
04-21-2020, 02:58 PM | #2 |
Re: Cigarette lighter
ok some background:
cigarette lighters were originally cigarette lighters, in older gm cars and trucks they were typically on the same circuit as the dome light and fused in the fusebox at 20A. the way a cigarette lighter works is, on the socket the outside barrel is ground and the center pin is 12v+. when you push the lighter in, there is a bimetal spring that is in contact with the outer barrel of the lighter and the center of the spring contacts the 12V+ pin creating a dead short through the spring. this short heats the bimetal spring until it changes shape enough to "pop" the lighter off the center pin. the spring stays hot enough to light a cigarette. most cars since the late 90s have only had a "power port" socket which is in the same shape as a cigarette lighter but is lower amperage and cant handle the heat of a lighter, being mostly plastic. heavy and metal socket = lighter, light and plastic socket = power port. if you are blowing a 30A fuse as soon as you plug it in, you either have a lighter in a power port, the center pins are slightly different and the lighter will bypass the bimetal spring and the fuse will see a dead short = blown fuse, or you have a bad lighter that has a broken spring and = dead short. I put power ports in all my trucks, they fit in the place of the original lighter AND the original key, so I usually double up. I wouldnt use a lighter in them. there is a lighter in the s10s (a holdover?) ashtray, but I rarely take it apart far enough to get it out.
04-21-2020, 03:10 PM | #3 |
I'm thinking "power ports" came later yet.
The 2K Cad DTS I had had lighters front and back including in each rear door. No power ports. My 98 BMW and 02 VW both have lighters and no power ports. The question for Jemezcrusher is do you actually need a lighter? Not a social or lifestyle comment but some folks still need them some are more than happy with just a power port. One thing I found out years ago is that you can't mix and match lighters and sockets all that often. I had one that wouldn't pop out when hot that way once. Came close to burning the wiring up on that one as it wasn't fused.
04-21-2020, 09:24 PM | #4 | |
04-21-2020, 10:20 PM | #5 |
I like the working lighter even if it doesn't light anything. They make some cool vintage "on the road" accessories that plug into them. You can always hide a couple of power ports somewhere. I bought one for my golf cart that has 2 power ports and 2 usb"s for not much money. They come on a mounting plate.
04-21-2020, 10:37 PM | #6 |
the ones I use from the s10 have a plastic cover on them, you can close them when not in use and when you open them the cover stays right there instead of rolling around like a lighter would.
04-22-2020, 08:07 AM | #7 |
https://www.lmctruck.com/1948-59-che...ard-components
I think I bought mine at LMC, item 12, can't remember what fuse I used but I am sure I did fuse it. Mac |
04-22-2020, 09:18 AM | #8 | |
04-22-2020, 10:59 AM | #9 |
I guess you could ohm the lighter part and see if it has a dead short
05-09-2020, 11:16 AM | #10 |
Yes to making it fused.
I like to run everything through a relay. Less strain on the wiring system and power comes from the battery and not through a switch. I found this great video explaining why relays are safer. https://youtu.be/MvvXGCbA5YM I'm mouting a power socket and a usb port in the glove box. See below for the links to what I bought. https://powerwerx.com/panel-mount-du...er-high-output https://powerwerx.com/panel-mount-ci...ket-automotive https://powerwerx.com/two-hole-panel-mounting-plate
'59 Apache Fleetside, 3100 w/235, all stock, 15 inch rims Last edited by sshamu; 05-09-2020 at 02:59 PM. |
