06-14-2020, 12:49 PM | #26 |
Re: 70 gmc DIY build
Thanks. Pretty sure I follow you on Instagram.
06-14-2020, 12:57 PM | #27 |
So after the lay out and lots of double checking it was time to cut. I cut the outside skin first then marked the inner skin off of the cuts through the top rail. Ended up with this.
06-14-2020, 01:04 PM | #28 |
Proprietor of Dale's Corner
Looks great! Nice job!
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
06-14-2020, 02:00 PM | #29 |
Getting dizzy just staring @ the puzzle pieces
06-14-2020, 08:03 PM | #30 |
Absolutely the cleanest cut lines I've ever seen... How in the world did you maintain such accuracy? Cut off wheel? The sanded edges look to be a consistent 1/4"... I'm curious how you did it.
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
06-14-2020, 08:05 PM | #31 |
Looks great! Nice work.
06-14-2020, 10:38 PM | #32 |
x2!!
06-15-2020, 08:29 PM | #33 |
Thanks. I used an air cutoff tool with a 4" .030 disc. The edges I did with a mini air belt sander.
06-16-2020, 11:17 AM | #34 |
Almost Satisfied
amazing work on the bed cut down...I'm not worthy...
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
06-16-2020, 11:57 PM | #35 |
What is the paint code number and name? Great job on the cut down.
Wade |
06-19-2020, 12:06 AM | #36 |
After getting things cut apart and cleaned up it was time to stick them back together. Using .023 wire with 75/25 shielding gas.
06-19-2020, 12:09 AM | #37 |
Thanks. I think the pictures do it a little too much justice.
Medium blue I believe. |
06-26-2020, 12:25 PM | #38 |
After they were welded up. I took my time and skipped around but there was still a slight amount of warping. Probably impossible to have zero warping without body work.
06-26-2020, 01:03 PM | #39 |
Looks great to me!
06-26-2020, 02:21 PM | #40 |
A skilled TIG operator could prob get it done but that's why they charge what they do. Kudos to your effort. Looks great from here!
06-26-2020, 11:38 PM | #41 |
Holy cow that's amazing. I'll be honest I couldnt trust myself to cut down a long bed to short. I'd just have to pony up the money and buy new bedsides as I'd probably end up doing it anyway. Keep up the good work.
03 s-10: daily driver 94 s-10: late model toy 70 c10: starting frame off resto 80 c10: for sale just collecting dust 94 c1500: hauler to and from 55 chevy: hot rod project jus reborn |
06-27-2020, 10:50 AM | #42 | |
I had most of the tools I needed already and the bed wasn't in perfect shape so I gave it a shot. |
06-27-2020, 11:39 AM | #43 |
Next was the bed floor. After some research I made the decision not to splice the floor which saved me a lot of cutting and welding. The front is simple just cut 12" off the front and drill new holes in the floor and header panel. Back is a little more involved. I cut off 7 1/2 inches and removed the rear cross sill from the cut off floor to spot weld back under the floor. Then used my air hammer with a pomel to fold the extra 1/2" over like factory. If i were to do it again I think I'd leave more than a 1/2" it would probably fold over easier. I did this with the floor bolted back to the sides to ensure everything lined up.
06-27-2020, 11:47 AM | #44 |
Here's what I did in the rear corners. The bedside has 2 bolts through the rear cross sill and I tack welded it to it like the factory did so I don't think 1 less bolt will hurt.
06-27-2020, 02:05 PM | #45 |
Very nicely done!
Hope I get to see this one some day @ a show or gathering (if we survive 2020).
06-27-2020, 03:10 PM | #46 |
You have done a very nice job on your bed. Keep up the good work!!!
06-27-2020, 03:13 PM | #47 |
Subsribed!!!
06-27-2020, 08:26 PM | #48 | |
Thanks just trying to build a fun driver. |
06-27-2020, 11:50 PM | #49 |
I've never owned "car show nice" rides. They've always been fun/cool drivers. The Patina trend just helps up the status. Once the trend ends, I'll still be building budget drivers that peers will turn their necks for. The only one I ever planned to paint (& attempt to make really nice) is my RetroRod. It was perfect patina back in the late 80's until it was stolen & hacked up. It will get decent paint.
06-28-2020, 01:41 PM | #50 | |
