09-01-2020, 12:37 PM | #76 |
polishing a turd
Re: my '59 short bed build
plenty of room for a MC under there. i went with the firewall mount to get it up higher, just in case this thing ever gets in water up to the floor boards...
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512 53 buick special - straight 8 sled - blow through turbo 47 gmc - flatbed hot rod build 99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van' |
09-11-2020, 10:20 AM | #77 |
polishing a turd
Got its shoes on!
09-11-2020, 03:31 PM | #78 |
Lookin good!
Rick 78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel 71 GMC C25 350/TH400 - Project Angie 59 Chevy SWB Stepside (next in line? Not sure now ) 2001 GMC Sierra K2500 |
09-11-2020, 07:04 PM | #79 |
aurite, great look, what did you decide on for the tire size? exciting!
09-11-2020, 07:27 PM | #80 |
polishing a turd
35x12.50x17
09-11-2020, 07:29 PM | #81 |
polishing a turd
I think I’m going to add one of these, 60” long, to stop and rear axle wrap without disturbing articulation much at all:
https://www.wfoconcepts.com/pr/WFO-T...Arm-Kits/16947
09-13-2020, 02:42 PM | #82 |
you have a lot of fab skilz, why buy when you can make for a lot less $$$?
no need for any heim joint unless you want an adjustable pinion angle no need for any type of rubber mount on the axle either solid welded/bolted to the axle with the front shackle is all you need ideal length for the torque arm is as long as the drive shaft to have the same pivot point truk is on stock springs still, axle wrap would run the driveshaft into a frame x-member my trans am rearend housing had a boss for the factory torque arm to bolt to i used a trailer shackle up front for the front mount if you google 'torque arm design' most attach rigidly to the rear end
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
09-22-2020, 12:18 PM | #83 | |
polishing a turd
but you are right, i could probably just buy the DOM, and some axle brackets, and fab it up for less than the kit. the 1 stop shopping is the temptation with that kit...
09-22-2020, 12:42 PM | #84 |
try welders series for diy parts. everything you may need. also, CAD so USD buys more for less. brackets, tubing, threaded tubing cut to lengths, joints, bushings, all kinds of fab stuff.
09-22-2020, 03:06 PM | #85 |
any torque arm needs articulation. your 14 inch travel is still limited by the length of driveshaft slip into the trans. most movement is in the rear spring shackle or 3 link if you go that way. the spring shackle at the front of the torque bar takes up any movement that is also limited by driveshaft travel. i used a trailer spring shackle for spring movement. no need for any heim joints
you could make your own shackle with a little flat bar and tubing with these
09-22-2020, 03:21 PM | #86 |
this is a pic of what you want to buy. if you make your own, no need for universal fit as the kits do.
the points in red should be welded solid. the blue is where i have a trailer spring shackle, using the rubber in the pic above and make your own shackle
09-23-2020, 11:52 AM | #87 | |
polishing a turd
09-23-2020, 11:57 AM | #88 |
polishing a turd
yes i get what you're saying. i will explore that route. thanks
09-23-2020, 03:45 PM | #89 | |
polishing a turd
i did already spent $77 on the axle brackets and 4 bushings with sleeves, so getting a tubing notcher may be the direction, plus i get a new tool then!
09-23-2020, 04:14 PM | #90 |
are you going for more articulation on the rear suspension or just concerned about axle wrap? here is a forum with a pic showing a kit like mentioned mounted up. there needs to be that shackle at the front to allow for some fore to aft movement as the springs compress, extend or wrap. otherwise the pivot point for the torque arm needs to be inline with the spring mount centerline. ensure the shackle has clearance for a full suspension travel both ways plus some room for safety.
remember, if welding on the axle tubes don't do all the welding at once because the axle tubes can warp from heat/shrinkage when cooling. https://forum.ih8mud.com/threads/fin...on-bar.278005/ https://www.pinterest.ca/pin/116460340345527180/ https://www.jeepforum.com/forum/f12/...ap-bar-517106/ http://www.how-to-build-hotrods.com/traction-bars.html and a little thread from pirate 4x4 speaking of axle wrap and one guys fix. has pics. some guys will run the center arm close to the driveshaft for shaft protection from high centering, just a thought. https://www.pirate4x4.com/threads/jb...ersion.837962/ |
09-24-2020, 05:32 PM | #91 |
Ideally the front pivot point on that type of setup is at the same spot the front U joint on the driveshaft on a one piece drive shaft is or the center U joint if you have a two piece drive shaft.
Functioning the same way the torque arms on 67/72 Chevy trucks or the torque arm on at least one generation of Camaros do.
09-25-2020, 02:50 PM | #92 | ||
09-29-2020, 10:12 AM | #93 |
polishing a turd
I am very much a diy type, but I want a clean finished look also. This part will be highly visible due to the amount of lift the truck has, and not sure if I’m keeping it or selling it to help fund my 47 gmc and 53 Buick builds. I think round tube, notched with bushing ends welded in so it can unbolt from the rear end for who knows why...if I keep this truck, I’ll likely upgrade the axles to 1-tons, so I want that to be somewhat of a straightforward swap as well. Also considering if an axle gets bent or damaged in any other way where the housing needs to be replaced, it’s just a matter of welding new brackets and shock mounts on the new axle and that’s it.
09-29-2020, 10:13 AM | #94 | |
polishing a turd
09-29-2020, 10:18 AM | #95 |
polishing a turd
I decided to plate the frame where the steering box mounts and also the two forward bolts have a small plate that they go through on the inside that’s not welded in but helps the spread the load. Shouldn’t have any issues with frame cracks here now!
09-29-2020, 10:25 AM | #96 |
polishing a turd
Also I primed the motors oiling system and installed the distributor at the proper timing.
Going to build the exhaust system soon, once the collector reducers get here, and test fire the motor. I just have a couple spots of body work left then I can get to work painting panels and start final assembly. I did paint one of the inner fenders over the weekend, really liking the royal blue! Going to switch to a chrome brake mc/booster setup then start running brake lines. Starting to see the light at the end of the tunnel here!
10-06-2020, 04:22 PM | #97 |
i just found these torque arm pics in a different folder, just for ideas
1st pic is the trailer shackle i was referring to this one has no rubber, it clanks when shifting from reverse to forward i bolted it to the x-member behind the trans the idea is simple. you could weld a spring pad on the axle and use U-bolts to attach a 2x2 square tube and a similar shackle on front and call it a torque arm
10-24-2020, 08:00 PM | #98 |
polishing a turd
thanks...looking at simplifying my design. 2x2x.25" square tube, welded to a spring perch and clamped to the axle with a bushing and shackle at the frame end. shouldn't be too expensive or complicated to build and stop any wheel hop.
i do want to be able to swap out axle housings to 1-tons later without too much work, and/or adjust the angle of the TA if needed, otherwise i know i could weld the axle end all together.
12-25-2020, 07:10 PM | #99 |
polishing a turd
Update on the torque arm. Just about complete with building the frame end of it, just need to clean it up a little bit more and then mount it on the frame and then test fit for length and then cut and weld it to the axle bracket.
Posted via Mobile Device |
07-17-2021, 08:24 PM | #100 |
Hey checking on how your build is going. Any more picks of the front end steering set up. thanks hope all is well
