Old 08-08-2019, 02:40 PM   #76
72c20customcamper
72c20customcamper's Avatar
Re: My "new" 1968 c20
Mar-K usually ships their parts in wooden crates to prevent damage.
Including all of the side mouldings they sell.
sounds reasonable.
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 08-08-2019, 02:41 PM   #77
72c20customcamper
No more holes.
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 08-23-2019, 06:08 PM   #78
72c20customcamper
Did some floor repairs today and used the new streacher/shrinker for the first time makes life much easier
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 08-25-2019, 02:37 PM   #79
72c20customcamper
Welded it all up today. Just need to prime and seam seal it
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 08-27-2019, 04:40 PM   #80
72c20customcamper
Hung the radiator support and bolted on the door and fender . Both OEM pieces everything lined up pretty well even the rocker with a few 5 pound sledgehammer plows on a 2x4 . Came to the cab corner . It was a cluster ###! . It was almost like it was for an extended cab . Had to cut it into 3 pizza slices just to get it to line up. 5 hours I would rather not repeat. Other side is getting a few small pieces.
If anyone is doing cab corners stay away from the CHL brand
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 08-27-2019, 04:41 PM   #81
72c20customcamper
Also did the passenger door pillar and kick plate yesterday
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 08-27-2019, 05:41 PM   #82
68panelman
68panelman's Avatar
Nice work, gittin her done before the winter come!!!
68panelman is offline   Reply With Quote
Old 10-14-2019, 04:00 PM   #83
72c20customcamper
Should update the build. New cab counters and passenger rocker. Should have just made my own corners had to cut them all up to fit the truck. Drip rails so far are perfect
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 10-14-2019, 04:06 PM   #84
72c20customcamper
All painted today . I'm piecemealing it. Can't do the whole truck at once. Finish up the door jambs and cowl area next if the weather cooperates. Roof is going to be white not original to the truck but I want it that way
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 05-01-2020, 01:51 PM   #85
72c20customcamper
Bed is on did it last fall been to cold and rainy for much work .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 07-09-2020, 07:16 PM   #86
72c20customcamper
Been doing the gutter/ firewall this past week made someprogress
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-23-2020, 10:08 AM   #87
72c20customcamper
Few new pics
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-23-2020, 12:34 PM   #88
Corts60
Just here to tinker
Corts60's Avatar
Wow! Great work! That top is smoooooth.
Old 09-23-2020, 12:53 PM   #89
SkidmoreGarage
I’m in the process of doing the same rust repair/bodywork, and know how much work it is. Keep it up.
SkidmoreGarage is offline   Reply With Quote
Old 09-27-2020, 08:06 PM   #90
72c20customcamper
Finishing up the floor
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-27-2020, 08:10 PM   #91
72c20customcamper
First coat didn’t come out so nice . This is the second coat Omni single stage
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-28-2020, 02:09 PM   #92
68Gold/white
Nothing wrong with single stage. Looks Good!!!
Carry on, man!!!
68Gold/white is offline   Reply With Quote
Old 09-29-2020, 10:30 AM   #93
72c20customcamper
Carry on, man!!!
I like it specially for solid colors . Talked to a painter after the first coat didnt go well. He told me to not add the reducer . It calls for 4:1:1 he recommended just 4:1 .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-29-2020, 10:36 AM   #94
72c20customcamper
Finished the drivers floor yesterday lots of stitch welding got sunburn on my arms ,coated everything I could with por 15 prior to welding. Also coated the passenger side going to let it cure then paint it body color when I do the inside of the cab
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 10-18-2020, 10:47 AM   #95
72c20customcamper
New cab bushings . Still need to tourqe them down but it did raise the cab a good bit. Around 1/4 inch but it should come down after it torqued and settled. Decided black for the underside still needs another coat . Truck was basically only primed underneath no saddle paint that I could find
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 11-10-2020, 09:22 PM   #96
72c20customcamper
I keep plugging away
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 11-10-2020, 09:32 PM   #97
72c20customcamper
Noticed I forgot the cab prep pictures
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 11-11-2020, 12:37 AM   #98
cornerstone
cornerstone's Avatar
Looks great Mark.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 11-11-2020, 08:40 AM   #99
72c20customcamper
Originally Posted by cornerstone View Post
Looks great Mark.
Thanks . I'm really into it more than I wanted to be . Been neglecting my other cars but I can see light at the end of the tunnel.
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 11-11-2020, 01:43 PM   #100
Low Elco
Good lookin' work!
Low Elco is offline   Reply With Quote
