Old 12-08-2020, 05:00 PM   #151
Fw190d9
Re: Project "April"
Since I had to rebuild the rear window pinch weld from the damage, The fresh paint was too nice to cover up with an ugly gasket so I went with the Fesler flush mount rear window. It fit the window opening perfectly and is urethaned in like modern windows.
Fw190d9 is offline   Reply With Quote
Old 12-08-2020, 05:04 PM   #152
Fw190d9
Re: Project "April"
Followed by a Fesler flush fit windshield. No mods needed to the pinchweld. it fit suprisingly well. Urethaned in and no more leaky gaskets.
Old 12-08-2020, 05:06 PM   #153
Fw190d9
Re: Project "April"
So since the Kid was doing so well in school, I thought a nice bonus was in order.
Old 12-08-2020, 05:39 PM   #154
MDPotter
MDPotter's Avatar
Re: Project "April"
I'm drooling all over my keyboard now. Your shop with some form of heating/cooling, perfect bodywork, Fesler glass, and what looks to be a supercharged LT engine.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 12-08-2020, 07:10 PM   #155
Fw190d9
Re: Project "April"
Thanks MDPotter. Yeah its a crate LSA engine. Same as what the ZL1 camaro had a few years back. Its a connect and cruise LSA so came with a brand new 4L80e trans and harness. It fit well in the roadstershop frame with the exception of the trans mount. I had ordered the frame for the old 5.3 4l60e combo so I had to reposition the mount.
Old 12-08-2020, 07:19 PM   #156
Fw190d9
Re: Project "April"
Complete rolling chassis
Old 12-08-2020, 07:26 PM   #157
Fw190d9
Re: Project "April"
Put the accessory drive and blower drive on, then placed the cab on the chassis with some new cab mounts from LMC truck
Old 12-09-2020, 12:30 PM   #158
Fw190d9
Re: Project "April"
The new Roadstershop frame came with a rack n pinion so I had to fab up a steering shaft to connect to the column and clear the headers. 3 steering U joints were used along with a big Heim joint to secure the mid section to the frame.
Old 12-09-2020, 12:33 PM   #159
youngrodder
youngrodder's Avatar
Re: Project "April"
Wow what an awesome repair/upgrade....Your son will be stoked...
Nice job dad....
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 12-09-2020, 12:33 PM   #160
Fw190d9
Re: Project "April"
The front fenders were junk so I got a new set from LMC. Kept the original cowl panel and hood. Alot of time was spent on getting the gaps right.
Old 12-09-2020, 12:38 PM   #161
Fw190d9
Re: Project "April"
Even brand new fenders need a bit of smoothing out. The E coat was stripped off, fresh epoxy laid down and multiple coats of K38 block sanded before color
Old 12-09-2020, 12:41 PM   #162
Fw190d9
Re: Project "April"
Front fenders out of paint prison
Old 12-09-2020, 12:55 PM   #163
Fw190d9
Re: Project "April"
The original hood was still in great shape so was block sanded, colored and cleared. The gaps came out real good.
Old 12-09-2020, 01:13 PM   #164
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Re: Project "April"
Looks awesome! Great shop too. I hope you test fit your grill surround before paint...
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 12-09-2020, 01:31 PM   #165
TA_C10
TA_C10's Avatar
Re: Project "April"
Looks great! Did the hood have any oil canning that you had to fix before block sanding?
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 12-09-2020, 02:21 PM   #166
Fw190d9
Re: Project "April"
71stepside, Yessir I did. Forgot to snap pics of that part.
TA_C10, It didn't have any oil canning or major low spots. I had to weld a 1/8" welding rod to the drivers side edge where it meets the fender as the gap was too big.
Old 12-09-2020, 02:33 PM   #167
Fw190d9
Re: Project "April"
Since there was going to be some order time for the wheels, I went ahead and bought some Michelin Pilot sport tires in the sizes that I wanted. 285/35/20 fronts and 305/35/20 for the rear. Mounted the tire on the backspace measuring tool and got the measurements I needed to order the wheels.
Fronts came out to 5" b.s. and the rears 6.5"
Old 12-09-2020, 02:37 PM   #168
Fw190d9
Re: Project "April"
Since the bed was part of the "totalled" part, I ordered a new one from Brother's . Standard fleetside shortbed with all the parts and a tailgate with the Chevrolet lettering. The bed floor was promptly cut in half to make the doghouse that goes over the frame rails. and temporarily mounted to get tire measurements.
Old 12-09-2020, 02:41 PM   #169
Fw190d9
Re: Project "April"
To clear the big 305s in the rear with the lowered stance, I went with the big large inner tubs from LMC and modified the bedsides to have them bolt in about 4" higher than normal. This is going to be a street truck so I wanted to maximize bed space.
Old 12-09-2020, 02:45 PM   #170
Fw190d9
Re: Project "April"
So since the tubs were moved up 4" I made some steel supports for where the tubs attach to the bed floor. Tubs are still bolt in and can be removed after all the mods.
Old 12-09-2020, 03:29 PM   #171
1971Stepside
Almost Satisfied
Re: Project "April"
Wow! That is just a ton of work that you made look real easy. Glad you checked the grill (I figured you had). Did you go with the chrome or aluminum? My chrome one needed a lot of work to get it to fit.
Old 12-09-2020, 03:34 PM   #172
Fw190d9
Re: Project "April"
71 Step, I went with the aluminum and a bit different one to boot. You'll see as I post later pics
Old 12-09-2020, 05:57 PM   #173
Fw190d9
Re: Project "April"
We all know how bad these splash guards fit. Had to section and re-weld to get em to fit.
Old 12-09-2020, 06:01 PM   #174
Fw190d9
Re: Project "April"
So thats the bed metal work done. Tailgate fit was rather sloppy. More on that later. The bed was then disassembled and all parts sanded down and bodywork commenced.
Old 12-09-2020, 07:02 PM   #175
Fw190d9
Re: Project "April"
The bed floor was then modified to accept the Boyd's fuel tank and a fuel filler made to mount the new fuel cap. Both sides of the floor were then sanded thoroughly and readied for the bedliner
