Old 01-02-2021, 07:43 PM   #1
superchevy
Got big-block?
superchevy's Avatar
'78 GMC SC 454/T400 long to short bed build
restoring a nice '78 GMC Sierra Classic...plans are tu cut it down to a short bed, new paint, refresh the interior, reseal the 454, add tbi and a 4L80e...maybe some other mods. Here's a pic of it as found in the backyard of the original owner in San Antonio about 3 years ago...and back at my place.
'68 CST SWB factory 396/T400
buddy buckets, a/c, ps, pb
'72 Corvette convertible 454/4spd/ac, ps, pb
'73 GMC Sierra Grande short wide 454/T400 ps, pb, ac
'77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original
'78 GMC Sierra Classic short wide 454/T400 ps, pb, ac
'72 GMC Sprint SP454. 1 of 38 built.
'73 GMC Sprint SP454. 1 of 71 built.
'75 GMC Sprint SP454. 1 of 25 built.
SOLD! '72 GMC K25 4x4 468/4L80e/NP205
build thread
http://67-72chevytrucks.com/vboard/s...23#post4324423
SOLD!'55 Chevy gasser 496/4spd
build thread
http://67-72chevytrucks.com/vboard/s...96#post4324396
superchevy is offline   Reply With Quote
Old 01-02-2021, 07:48 PM   #2
superchevy
Got big-block?
superchevy's Avatar
Re: '78 GMC SC 454/T400 long to short bed build
I traded the bed off it for a set of 67-68 buddy bucket seats.
build thread
build thread
Old 01-02-2021, 07:53 PM   #3
superchevy
Got big-block?
superchevy's Avatar
about 6 months ago I took the 78 to buddy's chassis shop, where we cut it down to a short bed.
build thread
build thread
Old 01-02-2021, 08:02 PM   #4
superchevy
Got big-block?
superchevy's Avatar
now it's Jan 2021 and time to build it...rolled into the shop...working on the rear of the truck first...I still need to trim off 5" of the rear of the frame so the short bed will fit...i did get the rear crossmember relocated forward...here's a pic of the 1" lift shackle...that's right, I'm going up instead of lower on this one....now for a new diff cover, brake lines ordered, new rear brakes, some paint
build thread
build thread
Old 01-03-2021, 07:47 PM   #5
superchevy
Got big-block?
superchevy's Avatar
Got a little done today...cut 5.25" off the rear frame rails so the short bed will fit ....removed the diff brake lines...waiting on new ones from inline tube...removed the 2 piece driveshaft and carried bearing support...removed an exhaust hanger that's in the way of relocating the rear fuel tank...
build thread
build thread
Old 01-03-2021, 09:01 PM   #6
evan
evan's Avatar
Looks cool. How much did you take out of the center of the frame? 14"? Do you have any pictures of the inside of the weld? I'm thinking of trying the same thing and wondering about options for reinforcing it.
Edit: What I mean is, do you have any pictures of the inside of the frame where it was welded? Any more of the measuring/cutting process would be great too.
Evan B.
evan is offline   Reply With Quote
Old 01-03-2021, 11:53 PM   #7
Willowrun
Willowrun's Avatar
Interested in watching your progress.
Old 01-08-2021, 11:53 AM   #8
SCOTI
SCOTI's Avatar
Curious about this.... What brand did you use? Did the shackle fit the leaf properly?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-09-2021, 06:01 PM   #9
superchevy
Got big-block?
superchevy's Avatar
Hey SCOTI, not sure yet as haven't installed it yet. I've got to rebuild the front suspension and install some new front springs with coil spring spacers...I need to see what the front end height is before I do the rear....limited options on the front for 2wd
build thread
build thread
Old 01-10-2021, 01:42 PM   #10
SCOTI
SCOTI's Avatar
I bought/used some Western Chassis units that required 're-shaping' so they would work. Was curious if it was isolated or if it was more common.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-17-2021, 09:07 PM   #11
superchevy
Got big-block?
superchevy's Avatar
Got a little time to work on her today....what do you do when the shoes are up in the drums and the adjuster hole plugs are rusted in? You get the angle grinder out and some access to the shoes/springs/retainers....
build thread
build thread
Old 01-17-2021, 09:10 PM   #12
superchevy
Got big-block?
superchevy's Avatar
after getting the drums off, I could get the axles so I could replace the bearings and seals...simple right? mr. cross shaft pin said not so fast....ugh
build thread
build thread
Old 01-17-2021, 09:13 PM   #13
superchevy
Got big-block?
superchevy's Avatar
finally got the new bearings and seals installed....now to get some new brake hardware and finish the rear...
build thread
build thread
Old 01-24-2021, 06:20 PM   #14
superchevy
Got big-block?
superchevy's Avatar
with the new axle bearings and seals in, and a new diff lock bolt installed, I was able to get the new diff cover on and filled this weekend....also got the new shoes and brake hardware installed....getting closer
build thread
build thread
Old 02-24-2021, 09:28 AM   #15
superchevy
Got big-block?
superchevy's Avatar
Got the rear brake lines run, rear leaf springs and u bolts back together, new shocks and hardware
build thread
build thread
Old 02-24-2021, 09:30 AM   #16
superchevy
Got big-block?
superchevy's Avatar
the rear of the chassis is now complete and detailed...time to move to the front
build thread
build thread
Old 02-24-2021, 09:32 AM   #17
superchevy
Got big-block?
superchevy's Avatar
Finally got nearly all of the new suspension and steering parts in
build thread
build thread
Old 02-24-2021, 09:34 AM   #18
superchevy
Got big-block?
superchevy's Avatar
time to get the front clip disassembled...got a start on it last night
build thread
build thread
Old 02-24-2021, 01:25 PM   #19
JJH Jimmy
JJH Jimmy's Avatar
I think every open diff that I took apart that bolt was broke? The work on the back end looks great!
1972 GMC Jimmy 4x4 LS Swap
1985 Chevy K20
1994 GMC Yukon
2021 GMC 2500HD Duramax AT4
My "It's a Jimmy Thing" Build
http://67-72chevytrucks.com/vboard/s...d.php?t=583528
Budget Build 1985 K20
http://67-72chevytrucks.com/vboard/s...d.php?t=801565
JJH Jimmy is offline   Reply With Quote
Old 02-24-2021, 04:07 PM   #20
superchevy
Got big-block?
superchevy's Avatar
Thanks! I got lucky on that bolt, lol. I was able to use a pick and rotate it out. Should've bought a lottery ticket that day!
build thread
build thread
Old 02-28-2021, 06:16 PM   #21
superchevy
Got big-block?
superchevy's Avatar
got the front clip fully disassembled and the 454/T400 out to rebuild
build thread
build thread
Old 02-28-2021, 06:20 PM   #22
superchevy
Got big-block?
superchevy's Avatar
today started stripping the interior...
build thread
build thread
Old 03-02-2021, 09:35 AM   #23
superchevy
Got big-block?
superchevy's Avatar
I got the passenger door disassembled yesterday evening. I think I'm going to reuse the lower carpet/panel trims as both sides are near mint.
build thread
build thread
Old 03-02-2021, 09:36 AM   #24
superchevy
Got big-block?
superchevy's Avatar
door panel carpet
build thread
build thread
Old 03-02-2021, 10:15 AM   #25
SCOTI
SCOTI's Avatar
This is coming completely apart
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
