12-21-2020, 03:29 PM | #701 |
Almost Satisfied
Re: 1971 Stepside LS Build
Saturday night I decided to do an easy project since I didn't have to much time to spend in the garage. Thought I would go ahead and wire up the radio. The AAW harness gives you two wires for the radio. A battery wire (yellow) and a brown wire (acc). Add in the ground and you are good to go. I hooked it all up and the radio wouldn't come on. I checked the fuse(s) and no luck. Finally, after a good hour or so I just went in the house aggravated. I couldn't believe the RetroSound was bad.
The next morning I thought I would try again. I consulted with bearterku and was confident I had it wired correctly, but my volt meter was not giving me a good reading on anything so I went and bought a test light. Long story short I discovered that the yellow wire had no power from the harness. The fuse was good. I pulled out the wiring schematic and could see the brown wire and yellow wire went to different locations on the fuse block so I traced it back and discovered the yellow wire doesn't go to the radio fuse, but to the clock fuse and sure enough....it was blown. Replaced the fuse and it worked. Simple job that took 3 to 4 hours
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
12-21-2020, 05:13 PM | #702 |
Glad you figured that out for us . Makes sense, clock is constant battery, radio is ACC power. But odd AAW didn't give us 2 radio circuits for such.
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". |
12-21-2020, 06:30 PM | #703 |
Don't get real excited about the "options" for tuning in KC. They just dump a canned tune in, run it on the dyno twice and kick it out the door, at between 3 and 400 bucks. My favorite one have been through the guy that's done 2 of my harnesses, 150tunes.com in Washington. Kind of weird to communicate with, email only, but the tune on our 5.3 and both harnesses have been great. I'm considering pulling the computer out of my 09 to send to him to try to cure the stinky rich idle.
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
12-21-2020, 06:53 PM | #704 | |
Almost Satisfied
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." Last edited by 1971Stepside; 12-21-2020 at 06:54 PM. Reason: typo |
12-22-2020, 04:57 PM | #705 |
You had me stumped too. Most of the time, the answer is staring you in the face. I can't count how many times I was scratching my head with something and it was right there in front of me. I had great luck with LSXKilr. My tune is rock solid.
12-29-2020, 10:24 AM | #706 |
Almost Satisfied
Hope everyone had a great Christmas and had a chance to work on their truck. I was able to get out and get my speaker cabinet pretty well wrapped up for behind the seat. I have some mounting tabs and tweaks to do, but real happy with how it turned out. Hope to finish up the wiring this week and see how it sounds before it all goes to the upholstery shop.
12-29-2020, 10:29 AM | #707 |
Killer job Shannon, it's gonna look awesome when finished and sound just as good as it looks
12-30-2020, 02:41 AM | #708 |
Wow that looks awesome. You may have already mentioned it, but did you just wing that or did you have a set of plans? I’m digging the updates
12-30-2020, 11:40 AM | #709 | |
Almost Satisfied
12-30-2020, 11:43 AM | #710 |
Almost Satisfied
They finally shot some color on the bed and remaining parts yesterday. Who knows how long it will now take to get them buffed out and ready for assembly, but it is progress after 8 months.
12-30-2020, 04:17 PM | #711 |
I think if I were to do it all again, I would do just one sub in the middle. Two is definitely overkill and it would be nice to have a little storage like you do.
Exciting to see some more parts in color!
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
01-04-2021, 11:49 AM | #712 |
Almost Satisfied
Liner is shot on the backside of the fenders and bed side. Hopefully, the cut and buff will be done early this week and I will get the bed back by the weekend.
Knowing that the bed was getting close I decided to pull the wood out that I had finished weeks ago. I had it stored in the house under a bed and was really disappointed to see how yellow it had gotten. I decided to strip it all off and start over. I'm thinking a bright red stain on the wood. I finished the speaker box and wired up the amp and speakers. It sounds better than I had hoped and the Retrosound radio is pretty slick with Bluetooth. The doggo liked the bass and wanted in.
01-04-2021, 11:57 AM | #713 |
What kind of finish did you put it on it originally? The water-based Minwax clear finishes aren't supposed to be as yellow, or you can go with an automotive clear coat.
And what is that screw in your door just below your vent window handle? I had never noticed it until now. Neither of our trucks have that.
01-04-2021, 12:15 PM | #714 | |
Almost Satisfied
HAHAHA! The second person to ask about the bolt. In 72 the doors had these to keep the metal from splitting like they were prone to doing in previous years. I put 72 doors on mine because I wanted to go with the 72 door panels and I had a clean rust free original on the passenger side. ...and yes, I know my door hinge bolts are black
01-04-2021, 03:39 PM | #715 |
01-12-2021, 12:20 PM | #716 |
Almost Satisfied
After 9 long months the bed is finally starting to be assembled. We hung the fenders last night. Hopefully, it will come home tonight.
01-12-2021, 01:02 PM | #717 |
It's going to look like a complete truck in short order! Is your bed wood ready?
01-12-2021, 01:22 PM | #718 |
Awesome news Shannon. That's a great looking silver. It will be great to have it all back in one place...You place.
Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
01-12-2021, 01:26 PM | #719 | ||
Almost Satisfied
01-13-2021, 12:12 AM | #720 |
Hot diggity! Looks Terriffic, hope to see it in april.
01-13-2021, 06:34 PM | #721 |
What's goin on in April do tell...
Dave
01-14-2021, 10:24 AM | #722 | |
Almost Satisfied
01-14-2021, 10:27 AM | #723 |
Almost Satisfied
I'm just hoping for some sunshine so I can get her outside to take a couple better pics. Bed wood should be back before the weekend so I can get the bed pretty well buttoned up. Had them re-shoot the cowl as it had two dirt spots under the clear that wouldn't come out. I'm kinda freaking out that this thing is about done!
01-14-2021, 10:32 AM | #724 |
Beep! Beep!
Looks awesome!
1972 Chevrolet C/10 shortbed, stepside, 350, HEI, Fire Engine Red, Black Interior, Former Army cargo transport 2003 Chevrolet 2500HD CC 6.0 4wd 2004 Jeep Rubicon some aftermarket stuff... 2019 Jeep Unlimited Rubicon (the wife's baby hauler) |
01-14-2021, 11:41 AM | #725 |
Nice!!!
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
