Re: 1950? S-10 tdi
Re: 1950? S-10 tdi
Yes it is.
Today I got the front end hanging on it's own, front clip body mounts are tacked in. I need to do a bunch more work to the inner fenders before I can take them off to clean and paint.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
Re: 1950? S-10 tdi
On the weekend I got the cold side of the intake put together. Then put in a crossmember and bumper supports. 2x4 1/8" then 2x2 1/4", I added a lower brace but forgot to take picture. The bumper is the tow truck bumper that came with this truck it is 1/4" thick
Re: 1950? S-10 tdi
I think you are having too much fun, enjoy, looks great
https://67-72chevytrucks.com/vboard/...=797726&page=3http://https://67-72chevytrucks.com/...=797726&page=3 51 Chev 5 window on S10 with SBC 1958 Pontiac Wagon build https://67-72chevytrucks.com/vboard/...d.php?t=849781 |
Re: 1950? S-10 tdi
Re: 1950? S-10 tdi
Working on getting the running boards installed. Brackets are 1x2" tube getting bolted to the frame. I cut all the old bracket off.
Re: 1950? S-10 tdi
Working on the motor wiring. This motor came out of a swap, who ever did this swap should not do wiring. I already cleaned up a bunch when I got the motor running, now on to the rest.
This is what I started with last night and this is the type of thing I found 2 wires in 2 wires out and a ball of extra taped up, like just cut it and twist the wires together with tape would be better imo. Now its all cleaned up ready to make the harness fit.
Tags |
chevy, custom, diesel, gmc, s10 |
