02-19-2021, 01:26 PM | #776 |
Re: 1971 Stepside LS Build
Hey hey, glad you figured it out.
02-19-2021, 02:02 PM | #777 |
I've had the exact same issue with my new horn switch.
Took me some time to figure out it was that tab
Sander All Ideas, advice, critisism is welcome. Nothing better to learn from. ______________ '72 C/20 http://67-72chevytrucks.com/vboard/s...d.php?t=809053 |
02-19-2021, 06:39 PM | #778 | |
Question on your column. Is it an aftermarket or reman unit? It looks like it is an issue with the shaft. Too long. Check out this thread:. http://67-72chevytrucks.com/vboard/s...d.php?t=787782 .
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". |
02-22-2021, 10:19 AM | #779 | |
Almost Satisfied
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
02-22-2021, 10:27 AM | #780 |
Almost Satisfied
I did a lot of research on the fancy hood hinges, including talking to others at shows. I felt like $800 was just too high for hinges if they didn't really add something besides looks. I had one guy tell me that he wish he had purchased the CVF hinges instead of the Ringbrothers. I had never even heard of them until this point. After reading about them I felt much more comfortable taking a chance on a $575 hinge that I did and $800 one.
My first impression was that they looked well built and heavy enough to handle the metal hood. We got them bolted in this weekend and I was afraid they would take hours to get right due to all the adjustability that they have built in. I was wrong. They bolted right up and adjusters actually do adjust the hood with little input. Very happy with how the hood operates now. Goes full up and they also look nice. No raised hood in the back!! Hope this helps others on the fence about hinges.
02-22-2021, 01:12 PM | #781 |
those do look great Shannon. They sure open up the engine bay. The stock ones are pretty bulky. Your truck is coming along nicely! Keep up the fine work.
Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
02-23-2021, 07:38 PM | #782 | |
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
03-01-2021, 09:55 AM | #783 |
Almost Satisfied
Got her all loaded up for her first trailer ride. We are headed to upholstery for carpet etc. As I was loading it I managed to get the horn to honk by getting the steering wheel in just the right spot...so, that issue isn't fully worked out yet...smh.
We went by a gas station for her first fill up too.
03-01-2021, 02:09 PM | #784 |
Trailer looks great but the build looks better. Strong work on what you have done so far. The finish line is insight.
Inspired that it can be done. I am looking forward to be at that part of my build someday too.
'Hay Burner' 1969 C10 Long Bed, 454 BB, Hooker Headers, TH-400 w/3500 B & M Stall, 4.11 w/ Auburn-Pro Limited Slip. http://67-72chevytrucks.com/vboard/s...d.php?t=813448 "Wouldn't say I was missing it Bob" |
03-03-2021, 10:08 AM | #785 | |
Almost Satisfied
03-03-2021, 10:11 AM | #786 |
Almost Satisfied
The carpet turned out really nice. They ended up putting some additional material up under the dash as the ACC carpet didn't go up high enough to cover all of the Dynomat. Of course, it cost more money to do so...
Waiting on them to finish up the speaker cabinet and kick panels and the interior will be finished....except the horn!
03-04-2021, 04:11 PM | #787 |
Something about a red interior in a Chevy pickup that just works so well. I have some of my firewall showing because of the ACC carpet too...
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
03-11-2021, 10:24 AM | #788 |
Almost Satisfied
Have the speaker enclosures back from upholstery. Started installing them last night. Almost hate to cover it up with the seat.
03-11-2021, 12:14 PM | #789 |
Beautiful. Just beautiful. You're going to have to get those clear sheets that dealers use to put on the floor mats and also wear booties.
03-11-2021, 12:50 PM | #790 | |
Almost Satisfied
03-11-2021, 05:15 PM | #791 |
No shoe policy LOL.
Those kicks man. Turned out awesome. And to think back, you almost put those tweeters in the dash. Everything looks fantastic.
03-11-2021, 05:59 PM | #792 |
Great lookin' work!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
03-12-2021, 10:57 AM | #793 |
Looking great, I will kick my shoes off for a ride!
That red is poppin. Dave
03-12-2021, 11:40 AM | #794 |
I’m blown away with how nicely this truck has come together. Freaking awesome job!!
03-13-2021, 10:50 AM | #795 |
Roto Reuter thats the name...
The truck turned out great!! You took great care every step of the way. You located your ECM in the same place that I did, under the passenger seat. The only difference is that I came in through the side of the hump with my wiring. Is that bracket sitting near the ECM for bolting down the Snowden seats? I'm seriously considering those seats for my next build (71 C10 build). Again congrats on an awesome job!
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
03-15-2021, 11:11 AM | #796 | ||||
Almost Satisfied
03-15-2021, 01:34 PM | #797 | |
What's drivability like now prior to being tuned? |
03-15-2021, 02:38 PM | #798 | |
Almost Satisfied
03-15-2021, 03:01 PM | #799 |
Some fine craftsmanship has went into this build- congrats on seeing it through
71 C10 72 K20 72 K10 Super Kirk |
03-19-2021, 11:05 AM | #800 |
Almost Satisfied
Alignment Day! Also having them bleed the brakes one more time and do the state inspection. Tune is scheduled for April 2nd and then back to the paint shop for a couple touch up issues.
