Old 03-18-2021, 08:37 AM   #26
nsb29
nsb29's Avatar
Re: Exhaust/Mufflers
so basically it’s a small glass pacts thanks sounds like a solution
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 03-20-2021, 02:27 AM   #27
Gregski
Gregski's Avatar
just wanted to share some pics of me ditching my DroneMasters and going with some Magnaflows, honestly still loud without cats, these were hacked out of some GTO
rig is a 4.8L LR4
I built my dual exhaust out of stock Tahoe and Suburban exhaust pieces from Pick N Pull by reversing the passenger side to the driver side, here is a link to the build post if anyone wants to take a peak
https://67-72chevytrucks.com/vboard/...postcount=6059
Gregski is offline   Reply With Quote
Old 03-22-2021, 03:53 PM   #28
Steve Cole
Originally Posted by nsb29 View Post
I have the cast manifold that came with the motor which is from a Pontiac G8 I believe similar to the Camaro cast manifolds from there is 2 1/2 inch exhaust back to the mufflers and then exit behind the rear wheels I did not use an H Or X pipe driving down the highway it really isn’t that loud but going through the gears it’s louder than I wanted I am considering installing two small glass packs behind the mufflers in a straight area about a foot and a half from the end I also wondered if it was because I did not install an H or X pipe ????? I also wondered if it was the brand I bought and maybe I should have bought magnaflows but if you’re having the same problem that’s obviously not it if you figure out something before I do post it I’ll do the same
Here is how mine is routed. Are your mufflers this far back? I am using 2.5" pipe as well.Name:  Exhaust.jpg
Steve Cole is offline   Reply With Quote
Old 03-23-2021, 02:10 AM   #29
Gregski
Gregski's Avatar
Originally Posted by Steve Cole View Post
Here is how mine is routed. Are your mufflers this far back? I am using 2.5" pipe as well.Attachment 2090869
Attachment 2090870
Attachment 2090872
beautiful exhaust, and I don't want to be a dingleberry but I would question your O2 sensor placement you want them pointing down to avoid moisture and sediment not up, I know sometimes there is interference and we have to get creative
Old 03-23-2021, 12:13 PM   #30
Steve Cole
Gregski,
You are talking about the part that goes inside the pipe right?
Old 03-23-2021, 12:52 PM   #31
Gregski
Gregski's Avatar
Gregski,
yes, and where the bungs are welded, I have circled them here in this pic
NOTE: The oxygen sensor should be mounted in such a way that the condensation in the exhaust tubing will not enter the sensor. Mount the O2 sensor in the upper half of the exhaust tubing, with the angle “x”, shown above, being greater than 10°. The diagram below indicates that the sensor can be mounted on either side of the exhaust tubing.
Old 03-23-2021, 05:58 PM   #32
Steve Cole
Sweet, thanks! That is how the muffler guy had them positioned when I picked it up and I didn’t think twice about it but what you said makes sense. I just realized he screwed me because it is welded now and I can’t rotate the bung!
Old 03-23-2021, 07:06 PM   #33
jweb
jweb's Avatar
I have Magnaflows similar to these on my '51 (LS1) and it sounds pretty good.
https://www.magnaflow.com/products/1...rmance-muffler
When I had the exhaust made, they recommended two things.
1: Keep the mufflers close to the headers. They said this would reduce the drone because the further you let the exhaust travel before passing through a muffler the more drone you will have. Due to the sound waves bouncing around in the pipes.
2: Run the pipes all the way to the back. This way, even if it's a little loud it will be further away from you.
Adding a resonator before the muffler may be a good fix for this problem.
1951 Truck, LS1/4L60
1964 Suburban, current project
2014 Silverado daily driver
1953 Westerner "canned ham" trailer, rebuilt
1974 Prowler trailer, rebuilt
jweb is offline   Reply With Quote
Old 03-24-2021, 11:57 AM   #34
Steve Cole
Thanks for the info jweb. My issue isn't really drone, it is that it just sounds like crap. I think nsb29 doesn't like the sound of his either.
Old 03-24-2021, 11:59 AM   #35
Steve Cole
Jweb, Do you have pics of your exhaust system?
Old 03-24-2021, 12:59 PM   #36
jweb
jweb's Avatar
No, I don't have any pics. It's fairly simple though. I have an H pipe then the mufflers are near the back of the cab. After that the pipes run to just behind the bumper with turn downs.
I also added electric cut outs but I never use them, it sounds terrible when they're open.
Old 03-24-2021, 01:07 PM   #37
Steve Cole
Are you happy with the sound?
I was just on the phone with tech help at Magnaflow. I explained what I had before with my old system and what I have now. He said not having an X or H pipe has a much more significant impact on the sound than muffler placement does. He said the H pipe has a deeper tone and the X pipe has better scavenging. I am going to have an H pipe installed and see how it sounds then.
Old 03-24-2021, 06:10 PM   #38
nsb29
nsb29's Avatar
You got that right
I’m about ready to replace them with a pair of glass packs LMAO
Old 03-25-2021, 08:17 AM   #39
Steve Cole
You got that right
Before you replace the mufflers, consider installing an X or H pipe. The tech guy at Magnaflow said it would make a huge difference in sound. It is a cheap thing to try too.
Old 03-25-2021, 05:00 PM   #40
nsb29
nsb29's Avatar
Just kidding around but I am seriously thinking about putting cats or glass packs in front of the mufflers as I do have a lot of straight pipe before the mufflers for the sound to rattle around in as well as An H pipe we put flowmaster 40s on my buddies 64 283 El Camino had a decent sound they advertise their 50s series as quieter I guess the big difference is a 6.0 LS isn’t a 283 with a mild cam
Old 04-22-2021, 11:29 AM   #41
OutlawDrifter
H-pipe will give it a deeper sound, X-pipes sound similar to a 2-into-1 exhaust. Both help it sounds "better".
OP, I would suggest 18" bodies if you don't want it super loud. 2.5" exhaust pipe would be plenty, and I would go with an H or X after the transmission/xfer case. Skip the Magnaflow premium, and buy Jones/AP/Cherry Bomb copies. The 5x8x24 would be a great option as well, that would keep it super quiet until you smashed the go pedal.
If you end up with drone, you can use Helmholtz resonators on the tailpipes. @aknovaman, has done some write-ups on it, great guy and very helpful!
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
