Old 04-03-2021, 10:00 PM   #301
skymangs
skymangs's Avatar
Re: Orson the 49 GMC ~ Chris C.
Even though Saturday is supposed to be my day to work on my projects, I had Wyatt make patches for the areas we relived in the firewall.
skymangs is offline   Reply With Quote
Old 04-05-2021, 09:45 PM   #302
skymangs
skymangs's Avatar
Lots of progress today! Welded up the holes in the cowl
Installed the gas pedal
And painted the cab and boards (minus the roof). Still need to wetsand tomorrow.
Old 04-06-2021, 09:11 PM   #303
skymangs
skymangs's Avatar
Went to the City today and dropped a small fortune on reproduction Parts
The parking lights and glovebox door cost me $195. The parking lights are used, but they are mint.
Old 04-06-2021, 11:43 PM   #304
joedoh
joedoh's Avatar
man thats a steal on gmc park lamps!
Old 04-07-2021, 08:48 AM   #305
skymangs
skymangs's Avatar
Good to know
Old 04-07-2021, 09:03 PM   #306
skymangs
skymangs's Avatar
we got the Front clip wet sanded and started the drivers door.
Old 04-09-2021, 10:04 PM   #307
skymangs
skymangs's Avatar
we got a lot done today. But I think I got ripped off on the Wiring harness. There is a bundle of 8 wires that go to an external connection. I’ve identified 4 of them. The TCC, speedo, tach, and fan. Those are the only 4 that the pinout says there should be! There’s no instructions and the wires aren’t labeled. I bought it through messenger and since my account was hacked, I had to start a new one. So now I can’t contact the seller! If we don’t figure it out soon I’m going to have to buy another harness! We took the front clip apart. Body worked the roof. Welded in the hacked up radio hole
Old 04-13-2021, 09:13 PM   #308
skymangs
skymangs's Avatar
We finished wet sanding the drivers side. Cowl is ready for paint, roof still needs one more fill. Engine turns, but for some reason the fuel pump isn’t getting power. We are diagnosing now. I’ll stick Wyatt on it tomorrow.
Old 04-14-2021, 10:41 AM   #309
joedoh
joedoh's Avatar
looking great!
did you have the pcm software modified? you probably did, but in case you didnt gotta take out the passlock at the very least, it will keep the fuel pump from running.
Old 04-15-2021, 11:15 AM   #310
skymangs
skymangs's Avatar
I had the PCM cut by LT1swap
We got the bed and rear fenders on and drilled the new gas filter
Old 04-15-2021, 08:49 PM   #311
skymangs
skymangs's Avatar
We started painting the bed, but ran out of color. Will pick some up tonight.
Pulled the column for paint and to paint the interior.
Old 04-17-2021, 12:06 AM   #312
skymangs
skymangs's Avatar
We ran out of color, but picked up 2 more cans tonight and ordered 3 more.
Old 04-20-2021, 12:17 AM   #313
skymangs
skymangs's Avatar
We spent pretty much all day getting the door rubber off, it was like it was petrified! Then we stripped the remaining items out of the cab, in preparation for paint.
Old 04-20-2021, 12:18 AM   #314
skymangs
skymangs's Avatar
I am not satisfied with the patch on the radio hole, so Wyatt will be re-doing it on Wednesday. We started by painting the back wall of the cab, all the areas that are grey primer will be blue like the exterior and blended in with the black.
Old 04-21-2021, 09:23 PM   #315
skymangs
skymangs's Avatar
Today we got the bedsides painted and tailgate primed. We also got the inside of the cab primed.
Old 04-22-2021, 10:42 AM   #316
6DoF
6DoF's Avatar
i'm super interested to see the final product on the paint theme when it all comes together.
6DoF is offline   Reply With Quote
Old 04-22-2021, 08:53 PM   #317
skymangs
skymangs's Avatar
Thank you
Old 04-22-2021, 09:10 PM   #318
skymangs
skymangs's Avatar
The left bedside needs another coat
Right bedside is finished
Doors are off for jamb paint and new rubber
Back wall of cab in paint, but needs another coat
Old 04-23-2021, 10:40 PM   #319
skymangs
skymangs's Avatar
We got the left door wetsanded and in interior paint
Old 04-24-2021, 10:10 PM   #320
skymangs
skymangs's Avatar
Today we created templates for full door panels, tomorrow I’ll run them to my plas cutter and have them cut from 22ga. To include with the Truck
Chloe wet Sanded and painted the inside of the right door
And masked the rockers and jambs
Old 04-26-2021, 11:15 PM   #321
skymangs
skymangs's Avatar
Today we got the drivers door jamb in paint and prepped the passenger side
Old 04-27-2021, 09:29 AM   #322
skymangs
skymangs's Avatar
The radio hole is smoothed and looking good
The inside of the bed is finished
That left bedside to finally shaping up
And the tailgate is coming along nicely
Old 04-27-2021, 09:48 PM   #323
skymangs
skymangs's Avatar
We got the right doorjamb painted
And the left splashguard bodyworked
Old 04-28-2021, 10:22 PM   #324
skymangs
skymangs's Avatar
Here’s the tailgate before and after wetsanding
This is the drivers side splashguard before color
Old 04-29-2021, 10:47 PM   #325
skymangs
skymangs's Avatar
we got the rubber on both doors today.
