Old 04-27-2021, 06:37 AM   #101
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: “Castro” my new 72 build
Great metal and paint work Mike.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 04-27-2021, 11:14 AM   #102
Snake72
Snake72's Avatar
Fantastic build, this is a fun one to watch
Snake72 is offline   Reply With Quote
Old 04-27-2021, 11:24 AM   #103
LEEVON
LEEVON's Avatar
Coming together! I see no problems with door speakers, at least you didn't cut them into the kick panels like I did when I was 16 I'd like to punch myself for that. Dad told me to put them in the doors and I didn't do it just because I knew everything.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 04-27-2021, 11:34 AM   #104
GSFMECH
On the road
GSFMECH's Avatar
Thanks Steve
It was a fun build, thanks
Leevon, yeah I said what the heck, I ran a stock am/fm radio for years and missed having sounds. When I was a kid the thing to do was put them in the doors but later on everyone quit doing it.
Mike
Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos
72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works.
My new build thread "Castro"
https://67-72chevytrucks.com/vboard/...d.php?t=820934
My old build thread, the blue truck
http://67-72chevytrucks.com/vboard/s...d.php?t=271489
www.louisianaclassictruckclub.com
GSFMECH is offline   Reply With Quote
Old 04-27-2021, 11:37 AM   #105
GSFMECH
On the road
GSFMECH's Avatar
Masked up in a cocoon. Got the floor scuffed/ Ospho’d and ready to spray lizard skin. I used both the sound control and insulation
Mike
Old 04-27-2021, 11:39 AM   #106
GSFMECH
On the road
GSFMECH's Avatar
Fender body work, priming and blocking done, below shots are after paint. I cut in the inside of the fenders as well.
Mike
Old 04-27-2021, 11:40 AM   #107
GSFMECH
On the road
GSFMECH's Avatar
Unmasked the fenders, they came out ok.
Mike
Old 04-27-2021, 11:44 AM   #108
GSFMECH
On the road
GSFMECH's Avatar
I polished all of the SS window trim on my buffing wheel in the bench grinder. Also cleaned up the glass. I'm using the glass and trim out of the blue truck because it's in better shape. Also installed the Dakota digital GPS antenna, dash pad, speaker and center AC vent while it was easy to get to without glass.
Mike
Old 04-27-2021, 11:45 AM   #109
GSFMECH
On the road
GSFMECH's Avatar
Body and paint done here except for small pieces and parts and the black on the core support, inner fenders and underside of the hood.
Mike
Old 04-27-2021, 11:46 AM   #110
GSFMECH
On the road
GSFMECH's Avatar
Hot rod black done
Mike
Old 04-27-2021, 11:48 AM   #111
GSFMECH
On the road
GSFMECH's Avatar
The glass is in and my buddy Kevin (65StreetCruiser) polished the bed. The shine popped right back out.
Mike
Old 04-27-2021, 11:49 AM   #112
GSFMECH
On the road
GSFMECH's Avatar
Great Scott!! Still a lot do. This is only some of boxes of parts of stuff needed to put this thing back together and more parts on the way.
Mike
Old 04-27-2021, 11:51 AM   #113
GSFMECH
On the road
GSFMECH's Avatar
The dash is coming together, and I have the vintage air in position for the final time.
Mike
Old 04-27-2021, 11:57 AM   #114
GSFMECH
On the road
GSFMECH's Avatar
It doesn't look like I did much, but the AC is done on the inside, stereo done and tested. I added a Detroit speed wiper system, these are really nice and a very good hidden upgrade. The main harness is done, modified to accept all the aftermarket stuff, all circuits go through the original fuses etc. There are no hidden snipped wires. E-brake pedal is in. All that's left in dash is the Dakota digital stuff and hanging the brake pedal.
Mike
Old 04-27-2021, 12:00 PM   #115
GSFMECH
On the road
GSFMECH's Avatar
I fabricated a bracket to mount all my electronics, there’s a lot going on in that dash. I have the Dakota digital "brain" mounted, as well as the GPS BIM, and GV overdrive module. These are all mounted on one plate which bolts to the brake pedal bracket. I have another bracket mounted on the lower right that attaches to it, this plate holds the wide band module and BIM. I needed to get it into a position where I can see it from below because it has a status light for calibrating and troubleshooting. The wide band BIM mounts in the open area of the bracket, it didn’t come in until later so no pic, Covid had it delayed arriving.You can't really see it well but I installed a new firewall pad.
Mike
Old 04-27-2021, 12:02 PM   #116
GSFMECH
On the road
GSFMECH's Avatar
Door handles, side glass along with new weatherstrip etc. and mirrors are on. I scavenged a Hydro boost off a truck in my boneyard as well.
Mike
Old 04-27-2021, 12:05 PM   #117
GSFMECH
On the road
GSFMECH's Avatar
Dakota Digital dash wiring is done. Cruise is wired up, stalk is installed on the column and wires snaked through, all ready to connect. Core support and radiator is mounted
Mike
Old 04-27-2021, 12:08 PM   #118
GSFMECH
On the road
GSFMECH's Avatar
More progress, I have most of the wiring ran. I had to repair the headlight relay circuit off the blue truck because it was crushed in the wreck. I had this relay upgrade on the blue truck. I used the fwd harness off the blue truck because it was in great shape otherwise. Finished up the condenser installation. To help the AC in traffic I went to the bone yard and found a nice 11" electric fan off an OBS 1 ton dually. I had to modify the brackets to fit. I wired the fan through a relay, but the control circuit now comes off the now defunct original AC blower fan switch. With vintage air you don't use that switch. I had thought about using an automatic controller but I'm going to try it like this for a while. Got all the wiring done on the core support as far as I could till the fenders go on, painted the hood latch and brace and got them installed. Battery box and headlights are in.
Mike
Old 04-28-2021, 10:46 AM   #119
GSFMECH
On the road
GSFMECH's Avatar
A sneak preview of how it's going to look with the nice trim off the blue truck, I had to replace a few bent trim pieces. Also got the gas tank in
Mike
Old 04-28-2021, 10:47 AM   #120
GSFMECH
On the road
GSFMECH's Avatar
Cargo lamp, dome lamp and headliner in.
Mike
Old 04-28-2021, 10:50 AM   #121
GSFMECH
On the road
GSFMECH's Avatar
Installed the right front fender and start fitting up the ac and heater hoses, some trim starting to go on as well
Mike
Old 04-28-2021, 10:53 AM   #122
GSFMECH
On the road
GSFMECH's Avatar
Rear bumper and taillights in.
Mike
Old 04-28-2021, 10:56 AM   #123
GSFMECH
On the road
GSFMECH's Avatar
Working on the seat belts. Tore them apart and washed them really good and dyed them with Rit dye. Both retractors were broken so I robbed parts needed out of my stash. Also repainted the buckle covers. They are ready to go.
Mike
Old 04-28-2021, 10:58 AM   #124
GSFMECH
On the road
GSFMECH's Avatar
In the photos below, you can see one belt on the far left which I didn’t clean (this is a center one that I didn’t use), the next is one I cleaned, and the other 2 belts are after the Rit dye.
Mike
Old 04-28-2021, 11:03 AM   #125
GSFMECH
On the road
GSFMECH's Avatar
I also painted the new door panels I bought from Cheyenne pickup parts and new woodgrain inserts. When I restored my blue truck, I hunted for months for good used ones. These are pretty decent repops
Mike
