Old 05-20-2021, 04:46 PM   #1
Starwood
Starwood's Avatar
Transmission "Bump" at stop
Fellas,
After I put in a new crate 350 about 3K miles ago, I've noticed something little odd with the transmission - which is a TH350 auto with the standard 3 on the tree for a 64.
It shifts fine and smooth, kick-down is perfect - but sometimes when I get to a stoplight, I feel a very slight bump - like it's "resetting" into 1st gear - after it's already dropped to 1st.
Performance is great, fluid level is good - it's just a new thang. I'm curious if this is a sign of bad things to come, torque converter related (?), or the classic "Nothing to see here...".
Any thoughts/comments appreciated - as always.
64 C10 Custom
70 C10 Stepside w/67 Front End Clip
1970 Buick Ragtop
2003 Anniversary Road King Classic
Starwood is offline   Reply With Quote
Old 05-20-2021, 05:08 PM   #2
AussieinNC
Moderator
AussieinNC's Avatar
Re: Transmission "Bump" at stop
Couple of things to check:
Vacuum modulator hoses are in good condition and vacuum port in manifold is not clogged...
Engine idle speed a tad too high
Trans fluid a little low...how long since trans filter and fluid was changed?
I doubt the convertor is an issue....
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 05-20-2021, 05:54 PM   #3
Bigdav160
Bigdav160's Avatar
Driveline/driveshaft bind up like that's has been so common in modern trucks?
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 05-20-2021, 10:06 PM   #4
paul mora
Three on the tree is a 3 speed manual shift on the steering column. It is not a automatic transmission
Pulatoy
paul mora is offline   Reply With Quote
Old 05-20-2021, 10:58 PM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Originally Posted by Starwood View Post
Fellas,
Kind of confusing... but I'm guessing you have an automatic.
Check to see if the torque converter bolts are tight at the flex plate.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 05-21-2021, 09:10 AM   #6
geezer#99
geezer#99's Avatar
What carb?
Maybe fuel level isn’t ‘great’ once in awhile. Could be A very slight bit of sloshed fuel. Gives a little surge.
What distributor?
Weights could be hanging up.
And is vac advance hooked to ported or manifold vacuum port?
Old 05-21-2021, 10:29 AM   #7
Starwood
Starwood's Avatar
Yeah, automatic. Don't know why I keep thinking that...sounds pretty cool though, right?
64 C10 Custom
1970 Buick Ragtop
Old 05-21-2021, 01:20 PM   #8
Dead Parrot
Might double check the motor and trans mounts for tightness. Several hundred pounds of engine/trans settling back into place can often be felt.
Also check the bolts holding the engine/trans together plus the bolts on the flex plate.
Something loose/worn in the rear end/spring shackles?
Dead Parrot is offline   Reply With Quote
Old 05-21-2021, 06:01 PM   #9
vince1
Like has been suggested I would remove the driveshafts and check out the U joints.
vince1 is offline   Reply With Quote
Old 05-23-2021, 10:04 AM   #10
Starwood
Starwood's Avatar
Originally Posted by geezer#99 View Post
What carb?
What distributor?
