Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 05-12-2021, 06:27 PM   #1
MDFarms
Cut 8ft bed Into 6ft Bed
Anyone know of a shop or individual that knows how to or knows someone who can cut down a 8ft bed properly preferably in Michigan or If not Indiana/Ohio? Or have the templates that show.the cut lines around the rear marker lights?
MDFarms is offline   Reply With Quote
Old 06-04-2021, 08:42 PM   #2
Asshat
Asshat's Avatar
Re: Cut 8ft bed Into 6ft Bed
I’m curious about this too, is it just as easy to find a short bed and swap it onto the frame? Can this be done to a 3/4 ton long bed - drop a short bed onto the frame??
Here’s some specs from the Wiki:
115 in (2,921 mm) (short box: ½-ton models)
127 in (3,226 mm) (long box: ½-ton & ¾-ton models)
133 in (3,378 mm) (1-ton models)
1963 C20, small window, long bed
292, 4-speed
Asshat is offline   Reply With Quote
Old 06-05-2021, 07:33 AM   #3
1slo64
frame has to be shortened as well
1964 GMC Fleetside SWB
1966 Mustang Coupe
1slo64 is offline   Reply With Quote
Old 06-06-2021, 06:25 PM   #4
Pitpig
There are tons of threads on this, two main methods if it’s diy. Cut 12 and 8 inch sections out and weld back together or cut and tip the flanges. If your paying someone, buy new bedsides. The labor costs will kill you
Pitpig is offline   Reply With Quote
