06-07-2021, 12:10 PM | #1 |
Fold down license plate holder
I'm looking for recommendations for a solid fold down license plate holder that would work with the TripPlus Automotive role pan. From the location of the filler neck, it looks like the hole behind the license plate will be at the top - center area of the opening where the license plate will mount. Thanks.
06-07-2021, 02:22 PM | #2 | |
Re: Fold down license plate holder
I used one like this from eBay. It worked great. https://www.ebay.com/itm/35250737815...rd!49088!US!-1 Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
06-07-2021, 02:36 PM | #3 |
Thanks. The holder on Ebay looks like it mounts at the bottom correct? I'm concerned the area where the bracket mounts isn't big enough for that bracket. The dimensions for the area is 13" wide and 5.25" tall. My CO license plate is 6" tall so if the bracket is roughly the size of the plate, it will hang down below the edge of the roll pan too far to bolt it on? Did your roll pan have the same dimensions?
06-07-2021, 03:09 PM | #4 | |
Marc
06-07-2021, 03:13 PM | #5 |
06-07-2021, 03:25 PM | #6 | |
Thank you Marc
06-07-2021, 06:02 PM | #7 |
Note I had to correct this as I was way off>>> ( don't think any 80's cars still used the behind the plate gas filler. ) it looks like a lot of GM rigs used the behind the plate gas filler a lot longer than I remembered.
Some of the aftermarket ones I am finding that cover hidden hitches say that they are pretty flimsy. Not as cheap as the aftermarket ones but this 69 Camaro unit should work pretty well. https://www.ebay.com/itm/5Pc-69-Cama...8/163600195481 Summit has it for 23.99 rather than 39.00 https://www.summitracing.com/parts/GMK-4012-885-68
Founding member of the too many projects, too little time and money club. My ongoing truck projects: 48 Chev 3100 that will run a 292 Six. 71 GMC 2500 that is getting a Cad 500 transplant. 77 C 30 dualie, 454, 4 speed with a 10 foot flatbed and hoist. It does the heavy work and hauls the projects around. Last edited by mr48chev; 06-08-2021 at 02:42 PM. |
06-07-2021, 07:14 PM | #8 | |
06-07-2021, 07:20 PM | #9 |
If you ordered an oem style one the main difference might be the locations of the mounting holes between models of vehicles. When you are drilling your own that is a non issue.
06-08-2021, 12:37 PM | #10 |
caprice used a folding license plate for gas filler 77-90
https://www.ebay.com/itm/1977-1990-C...-/133399641348
06-08-2021, 01:45 PM | #11 |
I'm going to have to back up and say that they used them a lot longer than I thought. My wife had a 79 Caprice for several years.
06-08-2021, 02:06 PM | #12 | |
Marc
06-08-2021, 04:30 PM | #13 |
G-body also had rear fill tank fill w/ fold down plate. 1970 - 1988.
06-08-2021, 07:57 PM | #14 |
Thanks for all the comments!
06-08-2021, 09:06 PM | #15 |
Late, as usual, but here's mine.
I think the holder is from a G2 Camaro. I weakened the spings so that the license plate would lay horizontally while I filled the tank - I remember fighting with them and trying to wedge the gas cap to hold it open. The magnets sit where the rubber-bumpers would be on the Camaro. I had to play with it a little to get the plate to be a uniform distance from the roll pan. The lights are from Kuryakin (I see I didn't hook up the ground - added that to my list) |
06-08-2021, 10:01 PM | #16 | |
06-09-2021, 09:03 AM | #17 |
Yes, the license plate is held on with these Kuryakyn led bolts-
https://www.kuryakyn.com/products/52...te-bolt-lights The edge of the hole for the filler neck is some stuff called "trim loc", not a rubber boot |
06-09-2021, 05:06 PM | #18 |
Awesome. Thanks
