#51 |
![]() Join Date: Jul 2015
Re: Next steps for the 63?
Took the carb apart, only thing w I noticed was the accelerator pump was sticking. Replaced it, bit still no luck. Doesn’t start and acts like it is out of time.
Next step is to pull the valve cover and maybe pull the front timing cover.
1963 C20, small window, long bed 292, 4-speed |
#52 |
I know you check the coil, ut all those symptoms jive with a failing coil. Even a failing coil can deliver a spark. They act up when they get warmed up and a failing coil gets hotternhell to the touch after a short drive.
#53 | |
Active Member
![]() Join Date: May 2019
#54 |
Who Changed This?
![]() Join Date: Jan 2013
OK, the only real change was that rebuilt distributor, right? Worst case, pop the old one back in and see what happens. Nothing to lose, at this point.
#55 | |
Tomorrow I will try this and pickup a new ignition coil.
#56 |
WTF?
I tried a coil first, no deal - wouldn’t start. Put the old distributor in and it started right up. Someone please explain this!
#57 |
Who Changed This?
Old is the electronic one, right?
On the points distributor: Pull on the wire that goes into the condenser. If it pulls out, you have the culprit. Not a common failure. If you have an ohmmeter, check the condenser resistance. The meter will (maybe) give a little blip, and then settle to infinity. Anything less than infinity, the condenser is shorted. Check that the breaker plate ground wire is intact.
#58 | |
#59 |
Who Changed This?
OK, so now you need to go and see if you can take that hill with the throttle opening all the way...
![]() Maybe just return the distributor? They are dirt simple, and should be easy to fix. But if it's running well enough with the old distributor, I wouldn't bother with it.
#60 | |
The condenser test resulted in OL. It must be faulty. I’ll get out there and drive it again this week, just feels a little sketchy. Hoping I don’t get stranded again. I wonder if the condenser failed because I didn’t have a ballast resistor wired up.
#61 |
Who Changed This?
If you had no ballast resistor the points are probably toast, but it usually takes awhile to scorch bad enough to fail. Possibly the coil is now walking wounded.
#62 |
Right now I have the Pertronix conversion installed(old distributor), no ballast resistor, and a new coil.
I may take it for a drive tomorrow. In case anyone is wondering what’s under the plate (this is the new distributor) in the pic.
#63 |
Drove the truck to work this afternoon, no problems at all. It was a relatively short drive; the actual commute if I go straight to work is 1.9 miles. However, today I drove it a bit more, about 10 miles.
Got a few compliments at work too. I think I may take it to the muffler shop this weekend and get the exhaust all done, the right way.
#64 |
Who Changed This?
More importantly, did you take that hill?
#65 |
Great, hopefully this is it. You've really busted your arse trying to solve these issues and stuck with it. A lesser man might have gotten discouraged and thrown in the towel. I hope it hauls the hill with pride.
#66 |
Pleased to see that you have resolved the truck issues.
We NEED a hill report. Preferably with video, drone footage and a voice over done by the Marlborough Man.... P. ![]()
Woody's Build - http://67-72chevytrucks.com/vboard/s...d.php?t=658621 If it goes wrong, I blame the Internet... |
#67 | |
Who Changed This?
#68 | |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
#69 |
Who Changed This?
Digging the Marlboro Man up and animating him would be the most expensive part.
Hey George, with all us guys pulling for you, that truck oughta cruise right up that hill!
#70 | |
Failing that I am available for a reasonable fee... P. ![]()
#71 | ||||
I shift through the gears, into 5th gear, cruising along at 50 (4:10 rear), it starts up this hill and it just continuously gets slower and slower. I shift down to 4th and the engine is revving up pretty good, but I’m going slower of course. Then I turn the corner and start up this other small hill, going in 4th gear and as it gets up half way it just slows again, just no power. I don’t know, it’s just gutless. Don’t have a tach, so I’m not sure what rpm I’m at, but it must be getting up at least 3000, pretty loud inside that cab.
#72 | |
