05-19-2021, 12:27 PM | #1 |
CA 67-72 Tow Hitch, Camper Mirrors, Eaton HO72 & More
Used 67-72 C10 / C20 Tow Hitch. Draw Tight brand, Class IV
Max Gross: 10,000(Weight Dist.) 6000 (Weight Carring Ball Mount) Includes Hardware & Round Plug $65. Local pick up only. $65 SOLD Eaton Axle HO52/HO72 4.10:1 ring & pinion gears. Excellent condition. This includes the ring & pinion along with whatever bits in pieces I can fit in a USPS large flat rate box. Shipped anywhere in the U.S. $400 SOLD 67-72 Camper mirrors, there is a small dent in the passenger side. $20. Contact me for shipping quote. SOLD 67-72 C10/C20 Leaf Spring Axle perch & U bolts for 2.25" Leafs. $20, Contact for shipping quote.
Made in America by Americans Last edited by Big Kev-O; 07-06-2021 at 11:38 AM. |
05-20-2021, 04:59 AM | #2 |
Re: CA 67-72 Tow Hitch, Camper Mirrors, Eaton HO72 & More
Pm sent
1972 K20 Cheyenne Super |
05-21-2021, 12:52 AM | #3 |
Active Member
I will take the camper mirrors. Shipping cost to 99645.
05-23-2021, 04:14 PM | #4 |
907burb, jfj537 inquired about the mirrors first, if he doesn’t buy them I will let you know.
jfj537, I noticed some plier marks on one of the mirror stems when packaging the up. They are on the same stem, other one is fine. Photo attached.
Made in America by Americans |
05-23-2021, 09:50 PM | #5 |
Mirrors sold.
06-14-2021, 06:42 PM | #6 |
I disassembled the axle now Eaton HO52/72 ring and pinion available. Excellent condition gears look very clean.
06-15-2021, 02:08 PM | #7 |
Location: Herculaneum MO (20 minutes south of St. Louis
Would you take $300 for the Eaton gears
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
06-15-2021, 05:03 PM | #8 |
How about $320 including shipping? The last set I saw on ebay sold for over $400. I would prefer they go to a forum member.
06-15-2021, 10:33 PM | #9 |
Yes, I will go $320. Pm sent
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris Last edited by 67 twins; 06-15-2021 at 11:22 PM. |
06-16-2021, 10:26 AM | #10 |
06-17-2021, 02:24 PM | #11 |
PM sent. Photo attached of everything you will receive. There is one small spacer that goes around the pinion shaft that I forgot to add to the photo. Here is what you will receive.
06-18-2021, 12:25 AM | #12 |
Payment sent
06-24-2021, 01:41 AM | #13 |
I’d love to have the hitch assembly any part numbers so I may check if it will work on a 72 blazer. Also where in simi I’m off topanga on 118
Some progress is better then no progress |
06-24-2021, 12:35 PM | #14 |
Hi Tmend, I will look for a part number when I get home from work. It bolts to the bottom of the frame rails. If your rear frame rails are 33.95" wide (overall) then it may work. I will PM you my phone number. My house is off Erringer Road if you want to come check it out.
