05-17-2021, 05:16 PM | #51 |
At the body shop.
Re: 2wd swap
It's does good til full droop.
But it's well beyond the advertised bag travel.
" That didnt make it any newer " " Dont antique the equipment " |
05-27-2021, 10:08 PM | #52 |
At the body shop.
Re: 2wd swap
Is a 1.500 id bushing enough interference?
05-28-2021, 09:48 AM | #53 |
Re: 2wd swap
05-28-2021, 12:05 PM | #54 |
At the body shop.
Re: 2wd swap
Guess you're not a mind reader.
For our rear links. Was planning in using the the rear spring hanger to locate the lower link. 2 inch x 1/4 wall dom tube is 1.490 I.D
06-16-2021, 03:22 PM | #55 |
At the body shop.
Re: 2wd swap
Wheels came in American racing rodders
20x8 and 9.5 with 245/40r20 and 275/40r20 kuhmos Can't wait to mock it up
06-16-2021, 05:08 PM | #56 |
Re: 2wd swap
Nice.
What was the outcome on the rear link bar/bushing combo?
06-16-2021, 05:54 PM | #57 |
At the body shop.
Re: 2wd swap
The bushing fits with grease. Rolled a edge of the urethane May have to hone them a bit. Still on the fence about the 2 link...
06-16-2021, 06:12 PM | #58 |
Re: 2wd swap
I would skip the poly bushed front pivots if you decide on the 2-link. I'd use a spherical joint for less bind & more articulation than possible w/poly.
06-16-2021, 09:41 PM | #59 | |
At the body shop.
Re: 2wd swap
Kid wants a 4 link. I want simple, he wants performance. Just happy we got a rack made for it to move around carrying it was killing me.
06-16-2021, 09:44 PM | #60 |
Re: 2wd swap
(2 link + 4 link) / 2 people = 3 link?
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
06-17-2021, 10:00 AM | #61 |
At the body shop.
Re: 2wd swap
2 link- 4 link- trailing arm its all in the air currently
Just happy I don't have to carry the frame around. And trying to convince myself I shouldn't 5 lug swap and lay the crew cabbie
06-17-2021, 11:30 AM | #62 |
Re: 2wd swap
HD or Lt.Duty 2500?
06-17-2021, 11:34 AM | #63 |
At the body shop.
Re: 2wd swap
HD like 8600 gvw or something.
454 4L80 126k the paint is starting to die finally and starting to show its age. Door handles window motors wonky gauges typical stuff.
06-17-2021, 01:22 PM | #64 | |
Re: 2wd swap
Mine....
06-17-2021, 02:10 PM | #65 |
At the body shop.
Re: 2wd swap
Definitely 8 lug.
Well if I go that way. You'll get a pm with a parts list. You helped me a ton with the 91 I did for my bro in law
06-17-2021, 03:24 PM | #66 | |
Re: 2wd swap
Pretty basic static drop for now. Unsure if I'll do full bag swap or just helpers @ this point. The plan was full swap but it sits good & it's nice not having to clearance the bejeezus out of everything. It high centered this past weekend pulling that load in the pic as it sits. Heavier loads will need some help.
06-17-2021, 09:00 PM | #67 |
At the body shop.
Re: 2wd swap
This is the '91 3500 you helped me with.
350 4spd now with a 3.08 10 bolt. Went ghetto tho reamed 1/2 stock spindles for the 3500 ball joints Clipped 2 coils and new axle pads cause a flip wouldn't with 3500 spring hangers. I bought when the b-i-l spun out on meth and since sold it to a neighbor
06-17-2021, 11:47 PM | #68 |
Re: 2wd swap
I just welded the ends of the flip brackets to the leaf pads on the housing. Kept them from moving. Did the welds where I could easily buzz it off if/when desired.
06-18-2021, 03:07 AM | #69 | |
At the body shop.
Re: 2wd swap
Why we used new pads.
06-18-2021, 09:38 AM | #70 |
Re: 2wd swap
Ahh.... One might expect things like that to be slightly different & those are.
06-19-2021, 02:41 PM | #71 |
At the body shop.
Re: 2wd swap
Rotor fits in the wheel center. Was really concerned they wouldn't.
But the rotor got swallowed up in a 20" wheel.
" That didnt make it any newer " " Dont antique the equipment " Last edited by KQQL IT; 06-19-2021 at 09:23 PM. |
06-19-2021, 11:42 PM | #72 |
Re: 2wd swap
What diameter rotor? 13" (12.8) or ??
06-20-2021, 02:01 AM | #73 |
At the body shop.
Re: 2wd swap
11.9 according to the order. Powerstop rotors. Seems like enough room for a pad swap with out taking the wheels off. Ha !
" That didnt make it any newer " " Dont antique the equipment " Last edited by KQQL IT; 06-20-2021 at 02:42 AM. |
06-20-2021, 11:14 AM | #74 |
Re: 2wd swap
Ahh.... Replacement C10 size. I though you might have upsized.
06-20-2021, 12:54 PM | #75 |
At the body shop.
Re: 2wd swap
Yes. Original plan was 18 inch wheels.
But they backordered til end of August so got the 20's and the rotor looks silly in there
