07-07-2021, 07:45 AM | #501 |
Re: New 64 Stepper Project
That is perfect, now drive the wheels off it and enjoy it…..
07-07-2021, 08:17 AM | #502 |
Having a bit of sidewall height looks great. It gives the truck a hint of historical originality.
07-07-2021, 10:27 AM | #503 |
Very classy and nice, i like it! Beautful truck
John 3:16 - Saved me... God Bless |
07-07-2021, 01:59 PM | #504 |
I'm just glad to be here!
Truck looks amazing, Well Done Master Chief!
Hope to see it out someday. Do you ever go up to the Hill Country Swap meet in Fredericksburg? It is the weekend of July 23-25th this year. I plan on having a spot to sell some stuff and possibly buy other stuff...LOL.
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
07-07-2021, 03:27 PM | #505 | |
Moderator
Thanks Thank you. Thanks for that. No to tell you the truth I have never been to Fredericksburg.
07-08-2021, 12:40 PM | #506 |
Moderator
I took it out on Wortham bend today, it's a 65MPH road. Drove up and down to get a feel. Need an alignment, that happens Monday AM at China Spring Collision. The trans shifts just like advertised by Lonie at Extreme Transmissions, easy when your easy, put your foot in it and it's around 3-3500 RPM nice and firm Couldn't ask for more.
07-09-2021, 06:27 AM | #507 |
Moderator
I tried to do a scrub line check on the rear so I laid some tape on the cement ran the rear tire over the end and pulled it over to the other side rim tight to see. Darn tape twisted but it's clear as far as a scrub line. I know the fronts clear as I had that moment previously.
07-09-2021, 08:29 AM | #508 |
I’m missing something. What is the purpose of the scrub line test?
07-09-2021, 09:34 AM | #509 | |
Certain methods of lowering alter the scrub-line so when making changes you need to be aware.
07-09-2021, 09:34 AM | #510 | |
Moderator
https://www.steffysgarage.com/downlo...line-chart.pdf
07-09-2021, 01:07 PM | #511 |
Having lost a wheel before I can get the idea here, problem is it looks like your ok if the tire goes flat and peels off rim but if studs fail (or someone steals your lug nuts like what happened to me) then the shock mount\U-bolt is going to become your skidplate.
07-09-2021, 01:35 PM | #512 | |
One doesn't expect to lose the entire assembly & I don't think you can prevent something else under the chassis from becoming 'next in line' unless you build it for that failure.
07-09-2021, 03:22 PM | #513 |
Moderator
Anyway, that's what a scrubline is and I'm looking good in that regard. So I'm happy about that.
07-11-2021, 02:30 PM | #514 |
Good information, thanks.
07-12-2021, 01:06 AM | #515 |
For sure man, I dont think many people will ever have a situation where the whole assembly comes off.
07-12-2021, 05:33 AM | #516 |
Moderator
Since you could see the long ends of the U-Bolts through my wheels , I trimmed them down with a 4.5" cutting wheel and painted the ends. Looks much better now.
07-12-2021, 06:03 PM | #517 |
Moderator
So here is a pic from the rear to the front under the truck. Wonder if they make shock mounts that sit higher? Maybe I could swap them, but then I'd have to trim them. Probably just overthinking it in that regard.
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 07-19-2021 at 03:13 PM. |
07-12-2021, 08:31 PM | #518 |
Originally they were flipped vs. how they are oriented now. Thats one of the first low buck mods (flip the lowers upside-down & re-locating the upper mount position).
07-12-2021, 08:47 PM | #519 |
I just caught up on your thread...dude! Love your truck! Great job!
07-13-2021, 09:25 AM | #520 | |
Moderator
Thank you.
07-13-2021, 09:49 AM | #521 |
I assumed they were aftermarket based off of their shape. The pre-67 lower brackets are beefier than the 67-72 brackets. That being said, you make some that keep the bottom of the shock flush w/the bottom of the T/A hardware if you're concerned.
07-14-2021, 11:29 AM | #522 |
Moderator
Getting the alignment at China Spring Collision this morning.
07-19-2021, 03:15 PM | #523 |
Moderator
Did the front scrub line also.
07-21-2021, 06:05 PM | #524 |
Moderator
I just checked and it's been six years since I started this build. The pinstriper came by today to put the cherry on the cake.
07-22-2021, 07:53 AM | #525 |
Moderator
Some of the finished product, didn't want to overdo it. Haven't wiped the sweat and hand prints off yet but you get idea.
