![]() Join Date: Apr 2013
WTB - Front Left 4WD Brackets
I was at a junk yard and picked up all the brackets for a 4 wheel drive conversion except the left front side. I am looking for the front spring perch and radiator support bracket, spring stop and the rear shackle block. I have a set of shackles
1972 K10 SWB wife's driver 1967 Pontiac GTO Big Bird - 1972 Longhorn K30 http://67-72chevytrucks.com/vboard/s...d.php?t=753294 |
![]() Join Date: May 2011
Re: WTB - Front Left 4WD Brackets
I should have the stop bracket and shackle block, I'll look shortly.
I would be interested in buying a front radiator support/hanger set if someone doesn’t want to still a set up
I didn't find a shackle mount but do have a stop. I did found a spring hanger but believe it's a passenge side since it doesn't have the strap, also, it's pitted heavy.
If you don't find anything soon,, I do have this setup I'm going remove sometime next month.
![]() Join Date: May 2003
I believe I have the spring strap that gets welded across the front of the spring perch
On the driver's side. The strap I have is in this picture.
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 Last edited by CUSTOM/10; 07-31-2021 at 03:01 PM. |
Thank you. Sounds good we will see where things are at when the time comes
#8 | |
Thank you Nathan
I'll do 28 shipped on the stop if interested.
How much do you want for the front strap?
$25 +shipping.
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
6>8 Plugless........
![]() Join Date: Sep 2007
Do you still have the stop?
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
I will take the strap. I didn’t see the picture before. How would you like to be paid?
#15 | |
I'll send you a pm later. Gary
#16 |
I got all the brackets for the springs. Now looking for two front top shock brackets and front and rear axle bumper brackets
#17 |
I have all of that in better shape than the front spring hanger, lol. I'll get some pictures tomorrow.
#18 |
Sounds good. Thank you!
#19 |
Here is what I have
#20 |
How are the shock mounts for thickness of metal? The ones I have are rusted pretty thin. If they are still original thickness I will take the best left and right and the best two rear bumper mounts. Do you happen to have a set of bumper mounts for the front?
#21 |
Shock brackets aren't thin, the only bumper brackets I have are bent.
#22 |
Here’s a picture of the front rubber bumper brackets I am looking for. Also a picture of a rear bracket that attaches to the rear spring shackle mount (painted black) that I am looking for also.
#23 |
Sorry, didn't realize you were looking for the fronts. I have both brackets and the rear brackets also. I'll grab some pictures tomorrow.
#24 |
Here is what I have
Front bumper 20 pr Rear bumper 30 pr Front shock brkt 20 pr. Rear spring hanger brkt 40 pr. Everything should fit in a medium flat rate for 15 or 18 with insurance plus pp fees. |
#25 |
Looks good pm me your info and I will get you paid
