Old 09-06-2021, 08:16 PM   #1
Buckthetruck
Sheared off lower coil mount bolt
I started working on the rear suspension of my ‘65 C-10 today. While working to remove the lower spring mount plate, the bolt sheared off! The top came off fairly easily so now I am stuck. What is the best way to get the lower mount off? How much tread is on the bolt of I cut off the welded nut? Will it just com off then? Is it possible to “twist” the coil to remove it from the bolt? It is rusted on pretty good. (I think I have attached photos)
Buckthetruck is offline   Reply With Quote
Old 09-06-2021, 08:29 PM   #2
SkinnyG
SkinnyG's Avatar
Re: Sheared off lower coil mount bolt
I used a LOT of penetrant, a torch, and an air hammer to remove the broken bits in mine.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 09-06-2021, 08:38 PM   #3
Buckthetruck
So you think heat it up, bang it around, and see if I can twist off the coil? Or cut off the rest of the bolt? Is it threaded at all inside the frame?
Old 09-06-2021, 08:45 PM   #4
MT65
The bolt just goes through the hole, not threaded into the arm …coca cola works good on the rust, keep soaking it and drive it out, won’t be easy but do able…if coke will work on that rust, think how your stomach deals with it…
MT65 is offline   Reply With Quote
Old 09-06-2021, 09:40 PM   #5
Buckthetruck
Thank you (I stopped drinking Coke 10 years ago!) I may go buy some and try that. With the bolt head off, should I be able to pound the bolt through from the bottom? Or should the bracket be able to be loosened since nothing is threaded in the frame?
Old 09-06-2021, 09:56 PM   #6
cwcarpenter98
cwcarpenter98's Avatar
Get a strong punch, your favorite, large hammer, and go to town on it. Since the bolt is already shared off, you'll need new hardware anyways. Once you knock the bolt out, then it will be easier to try to remove the spring holder from the bolt. Bolt in a vice and use a wrench on the square nut to work it back and forth until it unthreads. If you can, save the original spring retainers
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 09-06-2021, 10:10 PM   #7
MT65
At this point the bolt is just rusted in there, you might be able to save the spring holding parts, heavy on the might, I just sold the ones I had , changed to coilovers…
Old 09-06-2021, 11:10 PM   #8
60 Apache Shorty
Are you replacing the coils? mine broke off the same but I was replacing with drop coils. So I just cut the stock coil to get it out of my way and then just used a punch and pushed the broken bolt up and out.
60 Apache Shorty is offline   Reply With Quote
Old 09-07-2021, 02:26 AM   #9
Paul Y
Soak the bolt in PB, Coke or your own personal concoction of releasing fluid.
Clean the threads as best you can.
Put 2 nuts on bolt and lock them together.
Put ring spanner over both nuts.
Use force to break the bolt free from its rusty grip.
Once it turns use your best Tanya Harding to knock it through from the bottom.
Good luck!
P.
Woody's Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=658621
If it goes wrong, I blame the Internet...
Paul Y is offline   Reply With Quote
Old 09-07-2021, 09:15 AM   #10
Chevy Fleetside
Chevy Fleetside's Avatar
If you have a pickle fork, you might be able to put in under the spring and wedge it out. After a good soaking of course.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 09-07-2021, 09:34 AM   #11
Buckthetruck
Success!!! After sitting overnight with PB, a little cola in the morning, I was able to use a breaker bar between the spring supports that were already installed and twist it loose! Then just punched the bolt through. Thanks for the help all!
Old 09-07-2021, 09:42 AM   #12
SkinnyG
SkinnyG's Avatar
Yay!
Old 09-12-2021, 09:51 PM   #13
Barnfind46
Barnfind46's Avatar
"Don't you love it when a plan comes together"
68' with no bells or whistles unless I add'em.
Barnfind46 is offline   Reply With Quote
