09-16-2021, 07:41 PM | #1 |
Active Member
Help with Brake Drum Part Number
I have a 66 K20 and can't to find a part number for the rear drum. It's an HO72 with 13 x 2.5 inch brakes, 8 lug. This Eaton housing is the wider version to accommodate single rear wheels. I do have a set of 13 inch drums on my dually Eaton but that housing is an inch or two more narrow and the drums are different. I have piled through the parts books, this website and the other one, and paid an online visit to suppliers. All drums listed are 11, 12 or 14 inch, no 13's. I wish to keep the original brakes on the truck. Drum brakes work well for me, especially in the rear, so no disc conversion. The old drums I have are not salvageable and any markings that were on them have disappeared with time and weathering. Is there anyone who has been down this dark alley that can offer a flashlight in the form of a part number? Appreciate your time and courtesy!
Joe |
09-17-2021, 09:17 AM | #2 |
Moderator
Re: Help with Brake Drum Part Number
Does this work? https://www.stockwiseauto.com/centri...xoCwFwQAvD_BwE
Or try LMC part # 34-3960, Rear Brake Drum, 4 Wheel Drive 3/4 Ton 60-66 And since you have a K20 here's a guy that might help with other parts - https://torqueking.com/category/1960...series-trucks/
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 09-17-2021 at 09:30 AM. |
09-17-2021, 10:04 AM | #3 | |
Active Member
09-22-2021, 10:32 PM | #4 |
I think you might try 3754300
Raybestos 2009R Parts book page attached
1960 GMC K1500 LB Fleet Side 1962 GMC K1000 LB Step Side 1988 Chevrolet C2500 |
05-20-2022, 10:53 AM | #5 |
Active Member
The Raybestos 2009R is also a 12 inch drum. Still looking for a 13 inch, SRW. Best guess I can make from the parts book is 3831784, but maybe 3857752. But I cant's cross it to modern number. Frustrating.
05-24-2022, 11:36 PM | #6 |
I understand your frustration as I went through this same thing a few years ago. Who would have guessed that brake drums for a Chevy truck would be the hardest part of my mechanical restoration.
I too prefer the original drums, and unfortunately the 3/4 ton 4x4 stuff is unique to that model and just about extinct. A couple things I learned that you may already know as it looks like you’ve done a lot of research: All 3/4 ton 4x4’s came with 12x2 drums front and rear, and unfortunately unlike the 1/2 ton’s they are not interchangeable. There were no duelly or one ton 4x4’s in 66 Sometime in 64 or 65 they changed from a separate bearing housing with slide on drums to a one piece unit with the drums and bearing housing not separate. I got a lot of help from a guy in Southern California that runs “Drum Garden” not sure if he’s still around, but very knowledgeable and he specializes in stuff that doesn’t exist anymore. Let me know if you can’t find him, I may still have info somewhere. None of the usual parts sources have drums for 3/4 ton four wheelers, I know cuz I talked to them all! Good luck Tom
65 short stepside K10 292-SM420-T221 8 lug closed D44 front NoSpin HO72 4.10 rear Last edited by Short 3/4; 05-24-2022 at 11:45 PM. |
05-26-2022, 05:07 PM | #7 | |
Active Member
05-29-2022, 01:32 AM | #8 |
My guess is that you have the original housing and someone replaced the entire brake assembly in the rear with the 13’s. It’s really easy to do, I actually have 11” drums on the rear of mine that I pulled off my old 2wd to get the truck running while I was looking for the correct parts. I now have the right stuff, but always have something better to do than replace parts that are working. Probably someone in your trucks past wanted bigger rear brakes, or more likely couldn’t find the 4x4 parts so went to the local wrecking yard and made something work. The 12” rear drums were only used on 4x4’s for 60-66, never 2wd, so parts were always uncommon. There is an interesting thread somewhere on this forum that talks about all the brake interchanges possible for the HO rear ends. As I remember you can even swap brakes from a Dana 60, so seeing the “wrong” parts on a 50+ year old truck is not so unusual.
Anyway, this is a very long winded way of saying you have a lot of options for drums if you can just manage to also find the corresponding back plate and hardware. Hope this helps Tom
65 short stepside K10 292-SM420-T221 8 lug closed D44 front NoSpin HO72 4.10 rear |
05-29-2022, 08:06 AM | #9 | |
Active Member
In the meantime, I cleaned the first original drum and wire wheeled it, then took it to the local NAPA guy. It measured 13.050. The machinist said max was 13.090 but I argued 13.190, no way to read the "max diameter" marking. I picked it up a couple hours later with 99% of the pits cleaned up - It looks quite serviceable, $26. It will work for now as I continue looking for new parts. Now I will move on to the other side. Thanks again for your thoughts! |
