09-16-2021, 11:36 AM | #1 |
Mustang rack to spindle question
Hello all..
I am building a custom 66 with a custom crossmember and a mustang power rack..question is, whats the best way to connect the steering rods from the rack to the spindle...I know that the tie rod connection point on the spindle is tapered...on my rack, i have heim joints...I assume the proper procedure is to drill the taper out of the spindle connection point and use a bolt with the heim and misalignment spacers...thoughts? ideas? link is to a pic of what i have... https://photos.app.goo.gl/VZyo85fpGa2UCHNe8 |
09-17-2021, 09:01 AM | #2 |
Moderator
Re: Mustang rack to spindle question
You'll find a few ideas on this thread - http://67-72chevytrucks.com/vboard/s...=620584&page=2
09-17-2021, 09:42 AM | #3 | |
09-17-2021, 02:19 PM | #4 |
Some info....
http://67-72chevytrucks.com/vboard/s...postcount=1004 Look online. They make tapered inserts that the 4wd groups use but I went the route I did because of the TRE/R&P compatibility issues.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 09-17-2021 at 02:27 PM. |
09-17-2021, 04:00 PM | #5 | |
09-17-2021, 08:14 PM | #6 | |
