#26 | |
Re: 1961 Apache
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
#27 |
Re: 1961 Apache
I used a complete square body front end and used the engine perches too. I cut the tops off and welded a plate onto them cause there is a gap between them and the frame that would need a spacer. The motor mounts are stock replacement with dirty dingo adapter plates
#28 |
Re: 1961 Apache
Back from blasting
#29 |
Re: 1961 Apache
As bad as it looks the cab came out better than I thought it would
#30 |
![]() ![]() ![]() Join Date: Jan 2018
Re: 1961 Apache
Dadgum, looks like the inside of the roof was a mouse house
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
#31 |
Re: 1961 Apache
#32 |
Re: 1961 Apache
Started fixing the inner roof
#33 |
Re: 1961 Apache
That's a lot of air gap. REALLY control your heat so it doesn't shrink too much when final welding. Tack, planish, grind it, then do the next tack.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
#34 |
Re: 1961 Apache
Exactly.... i had to do 1/2 this amount and it was a pain in the butt, very time consuming.. but worth it in the end....
John 3:16 - Saved me... God Bless |
