10-08-2021, 12:54 AM | #1 |
4x4 Hubcaps why are they different?
I found a couple different sets of 4x4 hub caps today. I noticed the cap on the left is raised like it was meant to cover a wider axle where the cap on the right is flat like the 2wd applications BUT both caps have centers stamped out for the 4x4 front axle from the factory.
Why are they different? What application(s) would they go to? Posted via Mobile Device |
10-08-2021, 07:58 AM | #2 |
Re: 4x4 Hubcaps why are they different?
One on left is for Dana 60 1 ton
Fairly pricey when you find them One on right is standard 1/2-3/4ton cap
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 10-08-2021 at 08:43 AM. |
10-08-2021, 10:34 AM | #3 | |
I was under the impression that the 15" rims got the five spoke hubcap. The 16" rims got the six spoke hubcap. The six-spokes intended for the dana-60 had a larger hole than the ones destined for the 10-bolt/dana-44.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
10-08-2021, 10:49 AM | #4 |
Good question...I didnt even pay any attention to it being a 5 spoke cap..
I do know those raised centers were a 1ton d60 thing .maybe it's a GMC thing for the one on the left if his pic.. Puzzling is the one on the right with 5 spokes and a hub hole
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 10-08-2021 at 11:38 AM. |
10-08-2021, 10:52 AM | #5 |
10-08-2021, 02:02 PM | #6 |
While I can't tell you why there are two different styles- neither of those shown are 3/4 or 1 ton versions- those have 6 spokes and measure 12" in diameter.
This site shows both styles you have - https://www.hubcaps.org/chevtruck.html Heres a snip from the parts catalog; #6 is is the cap you're looking at and it shows several versions for Chevy only or GMC only and the part number changed throughout the years too.
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
10-08-2021, 06:19 PM | #7 |
Maybe Keith can shed some light on this
10-08-2021, 08:04 PM | #8 |
I have an NOS one I picked up with other parts PN 472586
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
10-08-2021, 08:49 PM | #9 |
thats NOT a dana 60 hub cap front . the center portion next to the hole is to FAT . it needs to be almost paper thin and rolled over .
i have a pair on my 1 K30 truck
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
10-09-2021, 09:15 AM | #10 |
Its for a 1/2 ton much smaller diameter than the ones on my K20
10-10-2021, 04:11 AM | #11 |
Just a guess, but it seems like my grandfathers 78’ with full time hubs had the necked one, my 80 with lock outs had the flush ones. Could it be the smooth capped full time hubs had the necked ones?
61 GMC 4x4 1-ton flatbed 4bt cummins, ranger od, sm465, np 205, d60F, d70R 4.11 10,000 ramsey PTO winch.... SOLD 73 k5 gm crate 350-265 / sm465 / np205 3.73 posi |
10-11-2021, 07:45 PM | #12 |
i have a 75 1/2 ton 4x4 full time org. owner has the raised ones hope this helps
10-12-2021, 09:35 AM | #13 |
I have a dana 60. I have a dozen 6 spoke caps and none of them fit the Dana 60. I need a set of Dana 60, 6 spoke caps. Help this brother out.
10-15-2021, 03:02 PM | #14 |
Some of you guys need your eyes checked... those are clearly 1/2 ton caps.
But to answer your question, i'm 99% sure the ones on the right were on trucks with NP203 cases. The ones on the left came on 1/2 tons with 205 cases and ALL 81+ trucks. Since trucks with lockouts or 81+ autohubs stuck out further, they have the left version.
1982 Sierra Classic K15 RC/LB 6.2L Diesel 700R4 1988 GTA Trans AM 305 TPI 700R4 1993 Formula Firebird LT1 T56 1995 GMC K2500 ECLB 6.5L 4L80E 1996 GMC K3500 CCLB LB7 6L90 |
10-15-2021, 03:19 PM | #15 |
Seems like I read somewhere that the 5-spoke caps were for 1/2 tons and the 6-spokes were for 3/4 ton. My K20 has the 6-spoke caps on (EDIT) -> 16" rims which I assume are original...
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 Last edited by sick472; 10-15-2021 at 04:36 PM. Reason: 16" not 15" |
10-16-2021, 03:41 PM | #16 |
While I cannot say for sure, I believe the ones on left with neck, were on later 1/2 ton. I had a 76 K1500 when it was near new, with full time hubs, and it had the style on right (actually still have the caps off that truck). Seems like 77 or 78 they went with those
10-16-2021, 05:02 PM | #17 | |
10-16-2021, 09:57 PM | #18 | |
1965 c/10 swb 1969 c/10 lwb |
