Old 09-19-2019, 11:32 AM   #1
LockDoc
The Older Generation
LockDoc's Avatar
Nice Used Door Locks With 2 Keys
I have 4 pairs of nice original used door locks with 2 keys each. They all look like the ones pictured. I have cleaned & lubed these and checked them out to make sure they work smooth. No ignition cylinders come with these & you will have to use your existing pawls & clips.
$15 per set plus $4 postage.
PayPal or Money Order works for me.....
Per board rules post in thread before sending PM's.
Thanks,
LockDoc
Leon
Old 10-30-2019, 03:50 AM   #2
LakeAnna
LakeAnna's Avatar
Re: Nice Used Door Locks With 2 Keys
Leon I'd like to get a set if you still have them sir.
Chris
72 RESTO
http://67-72chevytrucks.com/vboard/s...d.php?t=501870
LakeAnna is offline   Reply With Quote
Old 12-12-2019, 06:16 PM   #3
LockDoc
LockDoc's Avatar
Bumping this up. Member LakeAnna has first shot at one pair if he still needs them.
Thanks.
LockDoc
Leon
Old 12-12-2019, 06:43 PM   #4
LakeAnna
LakeAnna's Avatar
Yes sir I do need them. Let me know how to send your payment and I'll get it out to you.
Chris
72 RESTO
Old 12-12-2019, 10:09 PM   #5
LockDoc
LockDoc's Avatar
PM sent.
Thanks,
LockDoc
Leon
Old 10-12-2021, 01:26 PM   #6
duke10
Active Member
duke10's Avatar
Do you have any more of these and how difficult are these to replace. Just bought a 69 C10 and the ignition key does not work in the door lock.
duke10 is offline   Reply With Quote
Old 10-13-2021, 11:19 AM   #7
LockDoc
LockDoc's Avatar
Yes, I do have a couple of these sets left.
Did you spray any penetrating oil into the door lock cylinders before trying the key? If the ignition cylinder has been changed and the original lock cylinders are still in the doors that would explain it. Usually the hardest part is getting the screws out of the bottom of the door panels. They are usually rusted in. The lock cylinders are secured in the door by slide on clips. I suggest spraying a little penetrating oil on the clips before trying to remove them.
Remove the passenger side lock Cylinder first and see if there is a code number stamped into the side of it. It would be on the order of the one in the picture below. If there is a code number on it I can cut a key from that.
I will go ahead and send you the payment info in case there is no code number on the cylinder.
Thanks,
LockDoc
Leon
Old 10-13-2021, 12:30 PM   #8
duke10
Active Member
duke10's Avatar
Thank you very much for the information Leon. I will try that first.
Old 10-18-2021, 05:42 PM   #9
duke10
Active Member
duke10's Avatar
I will take the locks. Please PM me a total and I will forward payment via PayPal.
Thank you.
Old 10-18-2021, 11:40 PM   #10
LockDoc
LockDoc's Avatar
Thank you.
PM sent.
Thanks,
LockDoc
Leon
Old 10-18-2021, 11:50 PM   #11
duke10
Active Member
duke10's Avatar
Thank you. Money sent.
Old 10-19-2021, 09:08 AM   #12
jaros44sr
jaros44sr's Avatar
Leon, any more sets available, if so, I would like too buy a pair
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 10-19-2021, 11:17 AM   #13
LockDoc
LockDoc's Avatar
Yes, I have another set. Sending PM.
Thanks,
LockDoc
Leon
Old 10-19-2021, 07:34 PM   #14
jaros44sr
jaros44sr's Avatar
Thanks,
LockDoc
Leon, what parts do I need to buy to get these functional
SAFETY FIRST
AS usual, off topic
Jim
Old 10-20-2021, 11:05 AM   #15
LockDoc
LockDoc's Avatar
If you are replacing a set already in the doors you will just use all of the pieces from those locks. Be sure and keep the right and left separate because the lock pawls are different.
LockDoc
Leon
Old 10-20-2021, 07:36 PM   #16
jaros44sr
jaros44sr's Avatar
LockDoc
no, I have nothing, so I'm guessing, clips and paws
SAFETY FIRST
AS usual, off topic
Jim
Old 10-21-2021, 10:52 PM   #17
duke10
Active Member
duke10's Avatar
Door lock cylinders showed up today, exactly as described.
Thanks, again.
Old 06-19-2022, 10:20 AM   #18
MeanGreen72C10
Active Member
MeanGreen72C10's Avatar
Any of these available? I have locks but previous owner lost the keys
MeanGreen72C10 is offline   Reply With Quote
Old 06-19-2022, 08:46 PM   #19
LockDoc
LockDoc's Avatar
Yes, I have a couple of sets. Price is the same but postage is now $4.
PM sent.
Edit: Paid for and sent....
Thanks,
LockDoc
Leon
