10-17-2021, 04:25 PM | #1 |
leaf spring question
This bolt has gone bad. I think it is also contain in a metal tube. Does some sell this part? Also if I unbolt this will it be dangerous? Do I need to clamp the leaf springs to reduce it going un sprung?
10-17-2021, 06:10 PM | #2 |
Robert Olson Transport
Re: leaf spring question
Any spring shop should have a replacement or im sure you could replace the bolt with a grade 8 from Home depot or Lowes.. Lowes also sells a spacer you could adapt to fit
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
10-17-2021, 07:40 PM | #3 |
order a new one on ebay or a leaf spring seller near you.
Or get 1 from a u-pull-it |
10-17-2021, 07:48 PM | #4 |
Its to hold the leafs from fanning out .
You can pull it no problem . There no crazy special bolt so hardware store stuff is fine .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
10-23-2021, 05:30 PM | #5 |
before you remove that center bolt put a c clamp on it so once the bolt is removed you can release the spring pressure slowly. Its isn't dangerous like a coil spring but it does have a little pressure on it. The new correct bolt will be longer then the one you are removing. Once you tighten it up you the cut off the extra length.
10-23-2021, 08:49 PM | #6 | |
But good safety info you posted .
10-24-2021, 06:29 AM | #7 |
Check out Beattie Spring.
Rick |
