Old 10-30-2021, 08:25 AM   #1
Bench To Buckets
Can I just bolt factory buckets in my '95 bench seat Suburban? I believe the outer mounting points are the same, but are provisions made for buckets in all floor pans?
Old 10-30-2021, 07:02 PM   #2
b454rat
Re: Bench To Buckets
Want to do this to my crew cab. I've read that the outside brackets will bolt up, and when bolt the inners on, just need to drill holes. Don't forget some large washers or fender washers. Just a nut/bolt might pull thru if stressed too much.
Old 10-31-2021, 11:11 AM   #3
So the reinforcement/threaded holes for the inner mounts is only there for bucket seat trucks. No biggie, thanks for the reply. I'll look and see if I can make a plate.
What I bought were the '94-earlier hi-back cloth seats in blue, just what I wanted. My '92 K3500 I ordered low-back vinyl because it was a work truck. That was a mistake because that vinyl was the base level crap that started coming apart in less than 20k miles. After three driver seat bottom replacements and 60k warranty was up it was either redo seats in another material or find new take outs. I did find this style seat in light beige and I really liked them. I can't wait to put them in
Old 11-02-2021, 10:07 AM   #4
sntrym95
sntrym95's Avatar
I did this on my old 95. You have to drill the inside holes and use fender washers on the underside. Pretty easy though. Don't forget to plug the holes in the transmission hump.
Mike
sntrym95 is offline   Reply With Quote
Old 11-05-2021, 09:29 AM   #5
jocko
jocko's Avatar
Tim I’d like to see pics when you’re done. Mike, do you have any pics of yours installed?
Old 11-05-2021, 09:36 PM   #6
CrewCab59
CrewCab59's Avatar
Tim ,
Hope you don’t mind but here is our 2001 3500HD with leather buckets and center console with the upper console setting upside down. This is only mock up was during the interior getting upgraded.
1972 Custom Deluxe 20 4x4 burb
1971 GMC SWB CST 4x4
1972 GMC k20 4x4 (X- brush truck )
1971 Chevy CST Blazer 4x4
1971 Chevy C/10
1970 Cab Chassis C30 157"
1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica )
1988 Chevy V30 4x4 wrecker challenger 4812
CrewCab59 is offline   Reply With Quote
Old 11-08-2021, 06:01 AM   #7
Thanks for confirming it's no big deal. It sounds like I won't need a huge amount of time to get it done.
Will do. I only have the seats right now. I'm on the lookout for a console. I almost tore into it yesterday. I got a screw in a tire Saturday at Lowes. Took it down flat by the time I came out. Tires are needing replacement and I decided to steal the wheels and rims off the '72 (same age, no wear) and get the new tires for that one. So did that swap and fixed an exhaust leak. It was either get into the seat swap or wash the dirty dog. I decided to give it a much needed thorough wash.
Originally Posted by CrewCab59 View Post
Tim ,
So you swapped those in? I bet that's a nice improvement.
Old 11-08-2021, 10:14 AM   #8
CrewCab59
CrewCab59's Avatar
Yes those will be going in , we are doing the Kilmat sound deadening and are still waiting on the headliner material to get here. We bought a 1999 Suburban to get all the item we wanted.
I will have to start a new thread on this truck.
1971 Chevy C/10
Old 11-09-2021, 06:39 AM   #9
I'm not sure the pictures will be much to look at. This is not a restoration, it's a retired base Suburban that was a Sherriff Dept K-9 search and rescue unit that I use as a work truck. The door panels are faded, dash is busted up (I will be replacing), and I have no console. But the seats are the right color and I know how comfortable they are. I also have no console at this point. I'll take pictures of the seats today.
Sounds nice. I've been wanting to buy a more economical (better mpg) vehicle to run back and forth to work. But I'm getting urges to buy a nice clean well-optioned GMT Suburban. I'd have the beauty and the beast thing going on. I'd take the present 'Burb farther in the rugged work truck direction and a nice one to enjoy on occasion in better weather.
Old 11-09-2021, 08:40 AM   #10
sntrym95
sntrym95's Avatar
Sorry I don't. It looks just like it came from the factory though so I don't know that pics would help.
Mike
Old 03-12-2022, 10:54 AM   #11
I got the seats in last weekend. Now I really want a console
