11-16-2021, 09:07 PM | #1 |
Dash Cam
I checked and all I was able to find were old discussions. I have a '65 C10 and was wondering if anyone had hardwired a dash cam into their similar truck. In modern vehicles I tuck the wire up under the headliner, I think I could probably tuck it in the windshield rubber but don't know if it would cause the rubber to not lay flat. Just wondering if anyone has done this and could show pictures. Thanks.
11-16-2021, 10:57 PM | #2 |
Moderator
Re: Dash Cam
Do you just need power? Or some kind od data cable?
11-17-2021, 06:23 PM | #3 |
Re: Dash Cam
The PO of my C10 installed a "hidden windshield antenna" by tucking the wire behind the windshield seal, it's never been an issue and I don't notice a bulge. Sorry, no pics to share.
My truck ain't dead, it just smells funny. |
11-17-2021, 08:04 PM | #4 |
Re: Dash Cam
11-18-2021, 06:57 AM | #5 | |
Moderator
Re: Dash Cam
If I were putting it overhead I'd go via the inside cab light route. If I were putting it on the dash I'd use the speaker grill, I'm sure if your carefull...
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 11-18-2021 at 07:21 AM. |
11-18-2021, 11:47 AM | #6 |
Re: Dash Cam
I have a couple in other vehicles. Usually powered by a micro-usb. I'm debating about drilling a hole, slipping the usb through, and prettying it up with a rubber grommet.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
11-18-2021, 01:24 PM | #7 |
Moderator
Re: Dash Cam
So there is a USB cable used?
11-18-2021, 06:05 PM | #8 |
Re: Dash Cam
Yes, USB cable. Most kits come with a USB cord that plugs into the cigarette lighter, but aftermarket ones are available that wire into a spare fuse.
11-18-2021, 10:53 PM | #9 |
Re: Dash Cam
Tap a hole under mirror or wherever your mount camera. Pull through visor hole via fish tape or the like...and follow through with dash to visor hole
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
11-18-2021, 11:07 PM | #10 |
Re: Dash Cam
I just went out and looked and I believe that would work. They used a Corvair mirror on my truck and there is a gap between the mirror mount base and the roof. I could pull the mirror down, drill a hole and fish the wire through it. Then there would only be enough wire showing between the mirror base and the camera.
