12-25-2021, 05:27 PM | #51 |
Re: 1972 Highlander (Forum Truck)
I've been slammed busy at work and was out of the state for work for a bit. Moving along but, still slower than I would like. I'm almost ready to install inner fenders, core support, grille, bumpers, and hood. Doing a few final checks to make sure I have everything buttoned up on the engine before I install those parts. I wanted to do some day 2 hickey items like differential covers etc. but, I may hold off until the truck is done before spending money on those. I found some subdued differential covers, transmission pan, and flywheel cover I've liked using on other trucks. I also did a new engine compartment wiring harness. Bluetooth radio is in. Front carpet, console, sill plates etc. Driveshafts are in. New heater core and all the HVAC tubing. I had the emissions lines in the back remade by Williams Oil Filter in Tacoma, WA. Hood hinges rebuilt by Wilson Antique Auto Parts. Tilt column, console, and instrument cluster rebuilt by Randy here in Tacoma. Used the van shifter arm as it fits better with the 15" wheel. Exhaust manifolds were coated by Performance Coatings in Auburn, WA. Lots of other little details I'm forgetting. It is scary how close I'm getting. I always seem to drag my feet at the end because I enjoy the building aspect most.
1970 C10 to K20 conversion 1974 GMC Jimmy 1968 50th Anniversary Short Bed 1968 Chevelle 1964 Comet Caliente 1990 W250 Cummins |
12-25-2021, 05:35 PM | #52 |
The door panels are original. I was able to clean them up with SEM soap and no need to dye them. I got my upholstery in from SMS. I ordered the front and rear covers back in the spring and got them last month. Need to get those installed once I get my seat foam in from ACI. It is a challenger building anything with the delays right now.
12-25-2021, 05:42 PM | #53 |
Some more pictures
12-25-2021, 05:43 PM | #54 |
some more pictures
12-25-2021, 06:05 PM | #55 |
Proprietor of Dale's Corner
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
01-15-2022, 08:46 PM | #56 |
Thanks Dale. Your Dually went to a good home. I let it go to another truck guy. He flew in and drove it home to Texas. Even picked up a C10 project along the way and towed it home. Once I calculated paint and all the other things I wanted to do to it, I figured it was best to send it down the road to a guy that had the time. Too many projects on my plate.
Posted via Mobile Device |
01-15-2022, 08:52 PM | #57 |
Got the roll bar in. It’s a motor city K5 piece and I’m happy with the look and quality. I was shorted 4 mounting bolts but, a quick run to the hardware store will solve that. The CST rear panels are in. Wasn’t too bad locating all the brackets back into position since the holes had to be located and drilled since the reproduction bedsides/ floor don’t have them. Next challenge will be the seat mounting and spare tire carrier. I also painted the dash top as the windshield is going in soon.
01-15-2022, 10:01 PM | #58 | |
01-15-2022, 10:12 PM | #59 |
I think I got them from Brothers a while back. I believe the brand is PUI. The fit was about as good as reproduction parts fit. They’re much puffier than original but, most reproduction door panels I’ve used are puffier than originals. I've used Chevelle, Nova, and Camaro PUI door panels and they are all overstuffed. I think Legendary interiors makes the nicest stuff but, not sure if they make the CST panels. Not many options though as finding originals is not going to happen.
1970 C10 to K20 conversion 1974 GMC Jimmy 1968 50th Anniversary Short Bed 1968 Chevelle 1964 Comet Caliente 1990 W250 Cummins Last edited by HeloCrewChief; 01-15-2022 at 11:14 PM. |
01-15-2022, 10:23 PM | #60 | |
01-15-2022, 11:59 PM | #61 | |
01-18-2022, 05:46 PM | #62 |
Condenser and some of the A/C hoses and lines are in. Also the windshield and wipers are on.
01-18-2022, 06:10 PM | #63 |
I'm trying....
Looking good! Love the progress, love the build (and love the shop).
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
01-18-2022, 10:05 PM | #64 |
I agree with all points!
01-24-2022, 12:44 PM | #65 |
In all of your photos do you have one that shows the bottom ( drain ) part of the A/C housing?
01-24-2022, 04:38 PM | #66 | |
This is the only picture I could find. Not the best.
01-24-2022, 04:40 PM | #67 |
01-29-2022, 12:39 AM | #68 |
Gotta asked Oliver, where did you find hose clamps to match the paint? Looking at the picture of the fuel tank.
02-02-2022, 02:16 PM | #69 |
Brandon, not too sue what you are seeing. Guessing it must be some sort of reflection. The gas tank straps are originals that I powder coated. Clamps are just regular worm gear style from NAPA. Hope all is well. I have a buddy building a 70' K10 Suburban now. Sure do miss that K20. It drove so well. Have a feeling I wont love how squirly these Blazers are.
02-02-2022, 02:18 PM | #70 |
Brandon,
Just looked back through my pictures. I see what you are talking about now. I got those clamps at Mclendons in their hardware section. Just a weird OCD thing but, trying to match up all the clamps and clips in the correct colors they were originally. I've had to paint some to match as well.
02-02-2022, 08:04 PM | #71 |
Active Member
Really nice looking Blazer..great work
02-04-2022, 01:07 AM | #72 |
Well it’s looking great buddy. We need to organize some WA cruise when she’s finished.
04-13-2022, 11:12 AM | #73 |
Back seat, carpet, spare tire in. Just need to source a spare tire bolt.
04-13-2022, 01:17 PM | #74 |
Carpe manana
Boom! Nice CB too...
04-13-2022, 09:41 PM | #75 |
It's looking great Oliver! I love it!
