Old 02-20-2022, 05:53 PM   #651
Paul Y
Re: New 64 Stepper Project
Until I get mine all back together I am guessing when it comes to tyre size and the amount of coils to lop off the front end but, if it comes close to what you have achieved, I will be a happy camper.
I am wavering between a 225/70/15 and a 215/75/15 both on a 7" rim but that purchase can wait another month yet.
P.
Woody's Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=658621
If it goes wrong, I blame the Internet...
Paul Y is offline   Reply With Quote
Old 02-20-2022, 06:07 PM   #652
The Rocknrod
Moderator
The Rocknrod's Avatar
Thanks again. I wish you the best.
Old 03-07-2022, 08:36 AM   #653
The Rocknrod
Moderator
So I drove out to the new So-Cal shop in Waco this weekend it was 56 miles round trip and I got 17.9 mpg. The route had 65 MPH, 55 MPH 60MPH and city driving stop signs to and from. I don't want to go any leaner. Still have some choke tweeking to do though. It's a process.
I guess I'm going to find a local job now cause I need the gas money.
Old 03-07-2022, 09:37 AM   #654
SCOTI
SCOTI's Avatar
Impressive.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-07-2022, 09:43 AM   #655
The Rocknrod
Moderator
Originally Posted by SCOTI View Post
Impressive.
I wasn't sure if that was good or not. I was getting like 10mpg when I started.
Old 03-07-2022, 09:51 AM   #656
SCOTI
SCOTI's Avatar
Over 16mpgs for a 350ci/auto trans/3500# brick is impressive for a carb set-up.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-07-2022, 10:05 AM   #657
The Rocknrod
Moderator
Okay that's cool. I'll take it.
Old 03-07-2022, 10:22 AM   #658
MT65
Impressive.
How do the plugs look…..I started putting wideband gauges in everything, takes the guesswork out…..
MT65 is offline   Reply With Quote
Old 03-07-2022, 10:34 AM   #659
The Rocknrod
Moderator
I'll have to pull a couple and see. When I first started this they looked terrible, too much fuel.
Old 03-07-2022, 06:21 PM   #660
clemdaddy
clemdaddy's Avatar
Nearly 18 mpg is great especially doing 70mph. Sounds like she's dialed in. If it starts easy and burns clean... great job.
clemdaddy is offline   Reply With Quote
Old 03-07-2022, 10:24 PM   #661
SCOTI
SCOTI's Avatar
Any more details on the carb you're using?
I'm familiar w/the Demon brand but not so much their current product line & that particular model. Is it for a spread-bore intake or standard Holley square set-up? Easier for tuning vs. Q-jet or Edel/Carter style? What about vs a Holley?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-07-2022, 10:33 PM   #662
The Rocknrod
Moderator
It's a Street Demon 1901BK. Square bore. Super easy to tune and work on. I hate working on carbs but this one makes it a pleasure, if you can call it that.
Old 03-08-2022, 04:30 PM   #663
The Rocknrod
Moderator
Spark plug:
Old 03-08-2022, 09:45 PM   #664
MT65
Color is definitely getting better….
Old 03-08-2022, 09:47 PM   #665
The Rocknrod
Moderator
Thats as good as it gets.
Old 03-25-2022, 08:25 AM   #666
The Rocknrod
Moderator
When I changed the metering rods from 60/52's to 58/50's the mileage went from 18 to 12. Albeit the quick trip I checked it on was only 6.2 miles up and 6.2 miles back and I passed a slow-poke on the way up. That may have hurt it some.
You know the deal they were doing 50 in a 65 on a two lane road, I had to conduct a high speed fly-by.
And then starting out I had to floor it to get into traffic.
On second thought that whole run was completely different than the rest, too short ect.
I'll try again latter.
Old 03-25-2022, 09:16 AM   #667
SCOTI
SCOTI's Avatar
BIG difference. 33% variation definitely requires more evaluation.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-25-2022, 09:59 AM   #668
The Rocknrod
Moderator
Ya I don't see it as normal either. I checked timing, vacuum etc. as soon as I got home, ensured everything was snug. Doesn't seem right to me either.
Hey on a good note volts are awesome.
Old 03-25-2022, 12:06 PM   #669
Braunschweiger
Follow with interest, they have achieved a great result, I will do the same with my engine and have also put an AFR connector in the Header
Greetings Harald
My 62 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=829782
Braunschweiger is offline   Reply With Quote
Old 03-25-2022, 12:44 PM   #670
The Rocknrod
Moderator
That's an idea I have been considering and should have done.
Old 03-26-2022, 06:50 PM   #671
The Rocknrod
Moderator
10.8 mpg after a 30 mile round trip. I might be off a bit because I'm using a wooden dowel dipstick and a ruler instead of the gas gauge.
So in the AM I will put the old metering rods back in and see what the deal is.
I just feel like at 18mpg it's lean as in no balls engine wise. Better today for sure.
Oh on another note I went to the Waco So-Cal store show where they had a car show. They had six plaques for awards. I received Best of Show Truck and Fan Favorite.
Old 03-26-2022, 08:58 PM   #672
cwcarpenter98
cwcarpenter98's Avatar
Man, you're going to need a dedicated shelf for all the awards you keep getting. Congrats!
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 03-27-2022, 09:30 AM   #673
MT65
As CW said, your carpenter skill will be next for these awards, shelves will be necessary….congratulations…
Old 03-27-2022, 11:35 AM   #674
Braunschweiger
The Shelf will be necessary, the Awards will increase in the Summer with the Great Truck.
Greetings Harald
My 62 build thread
Old 03-27-2022, 01:37 PM   #675
The Rocknrod
Moderator
I dont know, maybe I'll give em away latter this year.
So I dropped in the 60/52's today drove 15 miles to the lake, turned around put the AC on and drove back. 15.4 mpg. This drive had a stop sign and a turn around. Driving 65/70 mph then into a small townish area 35/40 to the turn around and back. I should add that it is a hilly route to and from so a lot of extra accelerating trying to keep the speed the same.
Just doesn't seem as good with the 58/50's in it but I will live with it for now I guess.
