#751 |
![]() Join Date: Sep 2015
Re: My 1970 GMC “Project Splice”
#752 |
Now that I'm getting back into working a labour intensive job, the first couple weeks were hard. I was so exhausted by the time I got home that I basically ate and went right to bed.
#753 |
I need to stop setting deadlines for when I think primer will happen. I never hit it anyways!
#754 |
I know the feeling. I set my sons cab aside to focus on finish welding the frame and trailing arms. All I needed to do was install a 220V outlet on the outer wall of my house so I could run an extension cord to the garage and plug in my new 220 welder. I bought everything and it still took me over 2 weeks to install the outlet. Feels like nothing has been getting done in a long time.
#755 |
Well I finally have something for you guys to look at other than dust. It's not quite primer yet but I did get the last of the filler done today and did a decent cleanup in the shop. It's finally ready for primer prep!
#756 |
Lots of work to get to that point. Looks good.
#757 |
Thanks! It feels good to get to this point.
#758 |
Ladies and gentlemen, we officially have primer!
#759 |
Right on man. That’s an awesome milestone. Keep at it.
#760 |
Looking good. How did you manage to spray in what looks to be your home garage?
Didn't you have primer everywhere including outside? |
#761 | |
Thank you!
Haha well being that primer is very thick and heavy, I find that if falls to the floor quick and dries before it gets there. I wouldn't do anything more than prime in there. |
#762 | |
#763 |
Today I started fabricating a new cab mount nut as I somehow lost one of mine.
![]() On a side note, I finally found the leak in my air system that has been driving me crazy for months. Unfortunately my secondary air tank that I painted up and hung on the wall has sprung a leak in the bottom. The previous owner must have left water in the tank for years and it rusted through so now I'm back down to 20 gallons of air until I can afford to replace it. ![]() |
#764 |
Well now that those are done and mostly out of the way (still need to be installed) I decided to start playing around with my seats, console and behind seat audio box. I put in my driver's side seat on some blocking to get to a height and pitch that I'm happy with. Near as I can tell with measurements off my dad's truck, I've settled on stock height at the back, down an inch in the front and slid back as close to the rear panel as possible. This gives me just a bit more headroom as well as legroom since I am 6'-2". Once I had that established, I started creating the skeleton of my behind seat box. It will follow the same slope as the seatback until it hits a level line from the tip of the rear floor hump, then it will drop vertically till it hits the floor. I think that will look best.
#765 |
There we go, the skeleton is complete.
#766 |
Nice use of the gas tank mounting threads.
#767 |
Thanks, now I just need to figure out speaker sizes and locations and such. I've got lots of time to change my mind before I get speakers.
#768 |
Alright so now that the skeleton is mostly complete until I figure out speakers and such, I figured I should decide how to do the corners. After some though between trying to make it out of sheet metal and fiberglass, I've landed on fiberglass. This could be interesting as I've never worked with it before. Any advice or tips would be appreciated. So far as I know, I should be able to apply some resin and some matting directly to my cardboard backing and just build up from there?
#769 |
![]() Join Date: Apr 2008
Do you want the cardboard to remain? Guess it wouldn’t hurt anything. Not a fiberglass expert, but I would recommend using adequate hardener in the resin. If you don’t, the resin remains somewhat gooey- not good
71 C10 72 K20 72 K10 Super Kirk |
#770 |
Skeleton looks really good!
#771 | |
Thank you! |
#772 |
Unless you want the cardboard there permanently make sure to use a mold release agent.
Also, work in stages allowing the resin to flash off before adding more matting on top. Looking good. Good luck. |
#773 | |
#774 |
Well I got the first coat of resin and cloth on. I won't say it turned out amazing but I think it will work after more coats and some matting. Here's hoping!
#775 |
After you are done laying down matting get ready for body filler work. More spreading and sanding.
