03-17-2022, 11:42 AM | #1 |
Can I see some pictures of a 1" or 2" lift?
Hi all. I am looking for pics of a 99-02 half ton 2wd - with a 1", 1.5, or 2" lift. I really like the trucks but they sit a little too low for me. I'm kind of new to lifts, so is this something that may be covered by a "leveling kit"? Anyway any pics would be greatly appreciated, although I would like to aim for street trucks if possible. As I will not be purchasing a 4wd truck. Thank you!
03-18-2022, 08:40 PM | #2 |
Moderator
Re: Can I see some pictures of a 1" or 2" lift?
You have to be careful modifying the front suspension.
Much over 1-2" you'll need to change control arms, shocks, or spindles. https://www.duramaxforum.com/threads...82/#post-35565
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
03-23-2022, 11:00 PM | #3 |
Thank you for the reply. I will take that into account when I modify the truck.
1. Can anyone tell me how to make 100% sure the engine is a 5.3L? I heard it can be somewhat difficult to tell sometimes. 2. Has anyone ever put the steering wheel from an 06 in an 02? That way you can have steering wheel controls for the radio. Last edited by bennylava; 03-23-2022 at 11:10 PM. |
03-24-2022, 01:55 PM | #4 |
He's got mean nasty FANGS!
The only way to know for sure is to measure the stroke. Does it have signs of being swapped out? 8th digit on the vin should b a T if it was equipped with a 5.3, V if its a 4.8.
2004 K2500 Burb 1999 C3500 1985 Cutlass Supreme 1969 C-10 1967 C-10 Panel josh@67-72chevytrucks.com |
03-24-2022, 01:58 PM | #5 |
The steering wheel.controls would require a lot to swap. They feed through the bcm, steering column clock spring, and others. I swapped my 06 to steering wheel controls and had to reace the wheel, clockspring, and get a custom program from GM for them to work. 99-02 use a different radio, bcm, dash harness etc.
03-25-2022, 09:55 AM | #6 |
Eliminating the possibility of it being a 6.0, you can look at the piston top thru the sparkplug hole
The visible difference between a 4.8 and 5.3 are.. A 4.8 has a flat top piston, a 5.3 has a dish top piston Or as Josh said, measure the stroke
03-25-2022, 09:55 PM | #7 |
Don't they put numbers on the blocks or the heads anymore? Something you can just read and see that it's a 5.3L?
I do have a camera I can fit down into the spark plug hole. |
03-26-2022, 08:06 PM | #8 |
Moderator
The LR4 & LM7 blocks have the same casting number.
03-30-2022, 09:51 PM | #9 |
Would there be any real reason to get a 6.0L instead of a 5.3L? I planned to modify the engine some, in order to make more power. But keeping it naturally aspirated, and not going hog wild with it so that it doesn't destroy the gas mileage. Is a 5.3L better for this task? Or can a 6.0L make more power NA with less hit to the fuel economy?
03-31-2022, 01:57 PM | #10 |
Moderator
The LQ4 6.0L is noticeably less fuel efficient than the LM7 5.3L
The stock LQ4 is 330hp and 370ft-lb of torque. https://www.onallcylinders.com/2018/...ads-cam-specs/ The stock LM7 is 295hp and 335ft-lb of torque. https://www.onallcylinders.com/2018/...ads-cam-specs/ The stock LR4 is 280hp and 295ft-lb of torque. https://www.onallcylinders.com/2019/...ads-cam-specs/ There's no replacement for displacement but you will pay for it in fuel. The LM7 5.3L typically runs mid to high teens highway mileage. My 6.0 runs 12-12.5 highway. The lower displacement engines will need to turn significantly more RPMs to generate the HP numbers the bigger engine will generate at low RPMs. Comparing the LS4 5.3L in my 2009 Impala SS to the 3.6L in my 2012 Impala LTZ is a good case study. My bone stock SS will spank the LTZ off the line and continue to do so all the way to the 1/4 mile. They come in at roughly the same 300ish HP numbers but the LS4 will shove you back in your seat from a dead stop while the 3.6L needs to be wound way up before it begins to wake up. By the time my LTZ is tached up it's playing catch up for the whole stretch. The 5.3L SS has run a 13.98 and the 3.6L LTZ did 14.74 seconds. Close but no cigar. My Front Wheel Drive Aluminum LS4 5.3L actually gets higher mileage than the tuck motors. 24 highway and 19 in town. Lighter vehicle and lighter engine. I looked into cramming an LS4 out of a wreck into a 1980s S10 in place of a 90° V6. The LS4 is a Gen IV with the 60° FWD V6 bellhousing bolt pattern and FWD motor mounts so it's really not straightforward to put one in a longitudinal engine bay. Not to mention that the ECM/TCM combo wouldn't like manual transmissions.
And please let us know if and how your repairs were successful. Last edited by hatzie; 03-31-2022 at 02:16 PM. |
04-04-2022, 06:04 PM | #11 |
Sounds like you'd want to get the one that came after the LM7... iirc there is a 330hp/350tq 5.3L. But it may not be an LS, it may be an LT engine.
04-07-2022, 01:09 PM | #12 | |
Moderator
Direct Fuel Injection is excellent for power and fuel economy. However... AFM or DOD, whatever you want to call it, is bad juju. AFM engines tend to have lifter failures that do a fair amount of internal engine damage. GM didn't learn anything from the Cadillac 4-6-8 engine debacle. Installing a Gen V in place of a Gen III is non trivial.
And please let us know if and how your repairs were successful. Last edited by hatzie; 04-07-2022 at 01:17 PM. |
04-10-2022, 05:44 AM | #13 | |
04-29-2022, 10:55 PM | #14 |
Any pics of 4WD ext cabs with a 1.5-2" lift?
_____________________________________________ 69 C-20 292, 4 spd O/D, 4:56 rears. No a/c p/s p/b p/w......restoration project,"Operation:Stovebolt" 78 C-10 305 TH350 new (old) daily driver 02 Suburban Z71 a.k.a. the family truckster 99 Silverado 1500 Z71 |
04-30-2022, 03:18 AM | #15 | |
That TPI intake on the 90's LT1's always made my pants a bit tighter... with the center bolt valve covers... So sexy
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill |
04-30-2022, 04:23 PM | #16 | |
Moderator
I always figured TPI was a heckuva lot sexier than the 91-97 LT1. The reverse flow cooling Optispark 1990's LT1 looked like this.
