60-66 Nut
Re: '60-'62 Power Brake Booster Adapter Bracket
Thanks.
Here is what I ended up doing.
1965 GMC drum/drum Power booster CARDONE 503715, 67-70 C10 application Cut the eye off the end of the rod, threaded it 3/8”, 16 NC Used a locknut, with a threaded 1.75” long union on the pushrod, drilled the union and rod, cotter pin. Shortened pushrod length to 4.25” Threaded the end which bolts up to brake pedal longer. |
